G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.msi-microstar (More info?)
Hi all,
I have a new msi 6330 KT7 Turbo Raid board and the weirdest thing is
happening. It will boot and run fine ONCE. However on subsequent
attempts to boot, it freezes and gives light error code: 0100 which
indicates a memory problem.
If I remove the power cord from the power supply and let it sit for a
few minutes it will boot again, but only once. If you try and reboot,
it will lock.
I have never seen this. I have tried three known good sticks of RAM
and same results. The only thing that seems to clear the error (and
only once i might add) is removing power to the power supply and
waiting. HELP. Anyone with the same experiences? What did you find
out?
Thanks!
Hi all,
it will lock.
out?
Thanks!
