Help! XP trashed my drive!
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
I have an old 120MB drive that I was trying to copy
on to my XP Pro drive. Every 10MB or so, XP would
stop the copy citing an error with one of the files.
To speed things up, I decided to have XP check the drive
and repair it, using the "TOOLS" tab under drive properties.
Well after this, I found NO more files listed on my old drive,
the only thing showing was the "Recycled" icon! However,
Properties showed the size of the drive was pretty close to
what it was before, meaning the data was still on the drive.
(All files are set to "visible" on my system, so thats not the
reason I couldn't see the files). Furthermore, stupid XP renamed
the drive volume to the exact same name as my primary drive.
DOS doesn't show any files on the drive either, and using Norton
Disk Doctor for DOS to repair the drive didn't work.
Running CHKDSK under WinXP shows that most of the drive has data,
but it wants to convert the lost chains to files. I do not want
to allow this, because I don't think CHKDSK has a "unrepair" option.
Norton found over 5,000 lost chains when I ran it, and then said it
couldn't find the drive any longer, after I allowed it to convert
to files (so I undid the repair). Thus I don't want to risk letting
XP trash my data even further!
I don't get what happened exactly, or how I can repair it. All
I know is I've some important docs on this drive I'd like to get
back. Any clue as to how I can fix the XP damage?
4 answers Last reply
More about help trashed drive
  1. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    "Joe Samangitak" <joesamang@address.com> wrote in message
    news:5e231d22.0501231821.1cd82a79@posting.google.com...
    I wouldn't blame XP for your drive's demise, as it may just be on its death
    bed, or have already effectively died. Try the drive on another computer,
    although I doubt if the results will be different.
  2. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Age killed your drive.. it has to be 10 yrs old or more..
    Mike Hall
    MVP - Windows Shell/user
    http://dts-l.org/goodpost.htm
  3. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    BAR@discussions.microsoft.com wrote:
    T> When crying out for help, it is not appropriate to issue abuse to
    those
    T> potentially eager to help.
    When those are too dense to read a simple query, and arrogantly state
    their clueless opinions and have nothing but childishly useless advice
    to a serious problem, yes it is appropriate. They have no business
    responding or playing "computer expert", their help is of no value
    whatsoever, and is better not given.
    T> As for kindergarten: yes there is a place for you to start.
    I know you are, but what am I?
    T> One usually fnds that solutions are found when proper explanation of
    T> problems is provided.
    I gave an excellent, above par explanation of the problem. Your
    clueless buds decided to ignore 98% of it.
    T> You do not suggest what application or tool was used for this
    T> 'copy' and indeed why it was important to copy every BIT from the
    T> old to the new. Does the old drive have an operating system and
    T> applications installed - if yes, then why copy all this unusable
    T> baggage across.
    Yes I did "suggest what application was used to copy the files". I
    even called it by name, "Windows XP". I never said it was "important"
    to copy all the files, it's simply the simplest thing to do. Why NOT
    copy "all this baggage" as you call it? That right there tells me how
    little experience you have, and how little you know what you're
    talking about. FAT 16 files copied from a slave drive to a folder on
    an XP drive don't activate the WPF system, and it is of no relevance
    what type of files they are.
    T> Other problems with this are painfully obvious to T> all but a
    T>novice PC user.
    I've been using PC's since before you were born, son. The only thing
    that's painful is your ignorance of all these matters.
    T> Did you attempt to do this on a file by file, folder by folder or
    drive to
    T> drive [as in copying the whole of n-Drive to a folder in C-Drive or
    all of
    T> n-Drive to C-Drive?
    All of D drive to a folder on C drive.
    T> One would expect that if you attempted to perform the copy in the
    manner of
    T> the last process, then you'd have dozens of error messages [or
    messages where
    T> the system could not complete the specific task for an individual
    file ofr
    T> folder due to conflicts].
    WHAT conflicts?? Why don't you explain in your wondrous elegance what
    is inherent in the design of XP that would make it unable to copy
    every 10th ZIP file from one drive to another? That should be good for
    a laugh.
    T> As for renaming the drive etc...that's most peculiar. One would
    want to
    T> know exactly what messages or promts appeared during this sequence.
    Again it
    T> would normally appear only due to confilcts with device types etc.
    No prompts, just said there were errors with the occasional file. Only
    when I placed the supposedly erroneous file in XP's recycle bin, would
    XP skip the error and continue the process. But since XP is too stupid
    to recover from the smallest error, the entire process of copying the
    drive had to be repeated each time it refused to copy a file. There
    were no conflicts with "device types", XP had no problem recognizing
    my old Samsung upon boot, Device Manager showed it working fine. In
    fact, the drive worked fine on its own, away from the clutches of XP.
    T> As for the drive conbtents not being visible, perhaps along the way
    you've
    T> managed to 'delete' them. If so then they are recoverable from the
    recyle
    T> bin: thus the space allocated to the files has not altered as they
    are now a
    T> subset of the recyle bin.
    Sorry, you're grasping at straws in the dark, and not even CLOSE to
    getting a clue. NO, I did not "delete" the files by accident, without
    realizing it. You, Curly and Moe have one thing in common, I notice:
    your utter REFUSAL to implicate XP as a culprit in the thrashing of my
    drive. Until you're ready to do that, you'll never be able to problem
    solve a computer problem if your life depended on it.
    T> A successful result could be better achieved if one were to use
    Partition
    T> Magic or Ghost. Now go and read more about these at Symantec's web
    site.
    There you go again, assuming you know everything. Which is why you
    shall always remained cursed with cluelessness. I already have those
    two programs and you're the one that needs to read a lot more about
    computer systems before you stand on a high chair pretending your
    phenomenal ignorance passes for computer knowledge. The only reason you
    think
    cloning or imaging the drive partition, a far more complicated (read:
    error prone) process is a more viable solution, is not because you
    "know" it will achieve a more successful result, but because you
    clearly have no clue as to what happened in the first place. So
    instead of acquiring knowledge about how XP's repair function
    interacts with older FAT systems, you figure commercial software is
    always be the magic bullet.
    You might be a hero to the ladies in the secretarial pool when they
    can't figure out how to save a document in Word, but you don't even
    figure in the ranks of a rank amateur to me.
  4. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Joe..
    Hear me.. my two computers work flawlessly, and yours doesn't.. so who is
    the one without ability here?.. if you don't like XP, don't use it.. load
    Linux and take your assumptions to the Linux newsgroups..
    Mike Hall
    news:1106724049.298369.15720@f14g2000cwb.googlegroups.com...
    > those
    > T> baggage across.
    > T>novice PC user.
    > drive to
    > all of
    > manner of
    > messages where
    > file ofr
    > a laugh.
    > want to
    > Again it
    > you've
    > recyle
    > are now a
    > Partition
    > site.
    > think
Windows XP
