Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > SATA RAID Matrix problem with XP Home
Forum Windows XP : Windows XP General Discussion - SATA RAID Matrix problem with XP Home
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
Mainboard is Asus P5GD1 (based on i915x), there are two SATA drives
connected (WD Caviar 160GB 8MB Cache).
Windows XP Home with SP2 installs withot problems when those SATA HDDs
are configured as Standard IDE, S-ATA Mode on BIOS.
I've changed those HDDs to RAID mode, created new raid matrix (using
BIOS) and windows doesn't see those HDDs anymore (during installation,
before partitioning).
I've tried providing drivers during installation (F6) mentioned in the
manual - ITE 8212F IDE RAID Drivers - and got the same problem. I've
tried using dirvers existing on mainboard's CD-ROM but not mentioned in
the manual - SiI3114- Serial ATA Windows RAID Driver. Got exactly the
same message about HDDs.
Any ideas?
Will below drivers that I found on Intel's web page work with mentioned
Asus mainboard?
http://support.intel.com/support/chipsets/imst/
RAID Software - Intel® Application Accelerator
ftp://aiedownload.intel.com/df-su [...] readme.txt
X
Sponsored Links
The intel F6 downloads for RAID are located in the downloads section,chipset-
software,drivers for floppy disk set-up.The trick to installing at F6,is
select
the proper controller for youre board,press enter,then press S,then press
enter
after controller is re-selected,then press S again,this time you should
recieve
the option to use drivers on floppy,not to use the windows drivers,after that
press enter,then proceed to install xp or to recovery.
> Any ideas?
> Asus mainboard?
> X
Reply to Anonymous
There are 1227 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
