G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.msi-microstar (More info?)
I’ve got a couple of problems with this board that I need help with.
1. I can’t use any USB devices. I used to be able to, but I updated the
video and directX drivers and now any usb device reports a code 28
errors. How can I remove the standard usb drivers and reinstall the
nvidia ones for the board.
2. wise scholar’n’quiet reports wrong values. My cpu is either at –123 C or
+152C or any value in-between. Also, if I do a reboot from the start
menu, then the fan stops when the screen goes blank, and doesn’t start
again until I get the starting windows message, the cpu is really
cooking by then.
3. if I go to the bios and check the system health, I cant exit that
page. I can only reboot.
All my drivers are the latest, off the MSI site, but I still get the
above problems
System specs;
K8N Neo Platinum
A64 2800
512Mb
ti4200/128
W2K & WinME dual boot
cooking by then.
above problems
System specs;
K8N Neo Platinum
A64 2800
512Mb
ti4200/128
