Archived from groups: microsoft.public.windowsxp.hardware (More info?)
New GA K8NS - 939 M/B. No game port on this so added a
Creative PCI sound card with game port for the Sidewinder.
Unable to load driver for this device as my game port is apparently not
correctly configured.
Under Properties in Device Manager I get this:
"This device cannot find enough free resources that it can use. (Code 12)
If you want to use this device, you will need to disable one of the other
devices on this system.
OK.
Go to Set Configuration Manually. Under Resources I have 3 choices: Current
configuration (automatic), Basic Configuration 0000 and also ditto 0001.
Regardless of what I/O range I select a conflict is always flagged up. If
I ignore the conflict the bloody driver won't load for the same original
reason.
I'm at a loss. Is there any chance that loading FS 2004 will automatically
sort this out or must I get this sorted out before I load Flt Sim 2004?
Help really appreciated here!!
OK.
reason.
