Archived from groups: microsoft.public.windows.networking.wireless (More info?)
I have a Dlink router which links two desktops. I recently bought a wireless
Access Point, which I connected to the router and for a few daysit worked
perfectly with my laptop (AcerTravelmate 2300) but has all of a sudden
stopped working.
There was a problem with the Network at work and the technician there had to
put on Microsoft AntiSpyware to everyone's laptop.
Is this likely to have changed settings or something? And therefore is this
likelyto have caused the wireless connection to stop working?
Anyone got any ideas?
> stopped working.
MS Anti-Spyware should not have killed you connection, however, the
removal of some spyware/malware after it has made changes to you WinSock
can kill a connection. You did not say what your OS was on this PC. You
may try the following links and then post back with the results.
