Archived from groups: microsoft.public.windowsxp.hardware (More info?)
I installed linux FC3 and I have some free space where I want to install XP
my bootloader is in MBR
I copied the bootloader with dd into a file on an existing fat partition
so I can access it later when my xp overwrites the MBR
I have a problem starting the pc with the windows XP cd
it stops when detecting hardware, I believe the XP cd can't read the
geometry of the disk
I can start the pc with win98 cd I ran the dos fdisk /mbr that overwrote
my bootloader I could not boot the pc at all so I had to restart again
with FC3 cd in single user mode and run grub-install /dev/hda to get my
bootloader back
I have no clue how to get the xp setup working I have a free partition
all have to do is just format it and install XP
the XP just does not want to recognize the hard drive
is there any dos tool I can use to make it work?
here is my partition table if it helps
Device Boot Start End Blocks Id System
/dev/hda1* 1 10 80293+ 83 Linux (/boot)
/dev/hda2 2161 14593 99868072+ f W95 Ext'd (LBA)
/dev/hda3 11 2160 17269875 83 Linux >>> free partition I want my XP here
/dev/hda5 8202 10107 15309913+ 7 HPFS/NTFS
/dev/hda6 10108 14593 36033763+ b W95 FAT32
/dev/hda7 2161 4072 15358077 83 Linux (/)
/dev/hda8 4073 4333 2096451 82 Linux swap
/dev/hda9 4334 8201 31069678+ 83 Linux(/home)
any help apreciatd
bootloader back
any help apreciatd
