CPU speed on MS-6541 ??
Anonymous
Motherboard Authority
CPUs Authority
Archived from groups: alt.comp.periphs.mainboard.msi-microstar (More info?)
HI.
What is the maximum CPU that the MSI Ms6541 motherboard support ??
This motherboard can't be found on MSI's website and on compaq's too.
It is the motherboard of Compaq EVO D310
Thanks in advance
More about : cpu speed 6541
"altuiste" <njaworsky@tolede.com> wrote in message
news:a8fft0l2bs19hs68e26vvvdmcjeahh6s45@4ax.com...
> HI.
> Thanks in advance
You can email compaq and they will tell you. I had similar questions
regarding a laptop.
Drake
Excuse me for the delay... :ange:
MS-6541 Motherboard: CPU SUPPORT with BIOS 3.18 (12 Jun 2003)
Bios available here:
http://h20000.www2.hp.com/bizsupport/TechSupport/Softwa...
SL7EY 2.80 GHz BUS 400 MHz 0.13 micron D1 512 KB 478 pin
SL6PP 2.60 GHz BUS 400 MHz 0.13 micron D1 512 KB 478 pin
SL6QR 2.60 GHz BUS 400 MHz 0.13 micron D1 512 KB 478 pin
SL6PN 2.50 GHz BUS 400 MHz 0.13 micron D1 512 KB 478 pin
SL6QQ 2.50 GHz BUS 400 MHz 0.13 micron D1 512 KB 478 pin
SL6PM 2.40 GHz BUS 400 MHz 0.13 micron D1 512 KB 478 pin
SL6QP 2.40 GHz BUS 400 MHz 0.13 micron D1 512 KB 478 pin
SL6QN 2.20 GHz BUS 400 MHz 0.13 micron D1 512 KB 478 pin
SL6PL 2.20 GHz BUS 400 MHz 0.13 micron D1 512 KB 478 pin
SL6QM 2.00 GHz BUS 400 MHz 0.13 micron D1 512 KB 478 pin
SL6PK 2.00 GHz BUS 400 MHz 0.13 micron D1 512 KB 478 pin
SL6PQ 1.80 GHz BUS 400 MHz 0.13 micron D1 512 KB 478 pin
SL6PG 3.06 GHz BUS 533 MHz 0.13 micron D1 512 KB 478 pin
SL6QC 3.06 GHz BUS 533 MHz 0.13 micron D1 512 KB 478 pin
SL6QB 2.80 GHz BUS 533 MHz 0.13 micron D1 512 KB 478 pin
SL6PF 2.80 GHz BUS 533 MHz 0.13 micron D1 512 KB 478 pin
SL6QA 2.66 GHz BUS 533 MHz 0.13 micron D1 512 KB 478 pin
SL6PE 2.66 GHz BUS 533 MHz 0.13 micron D1 512 KB 478 pin
SL6PD 2.53 GHz BUS 533 MHz 0.13 micron D1 512 KB 478 pin
SL6Q9 2.53 GHz BUS 533 MHz 0.13 micron D1 512 KB 478 pin
SL6PC 2.40 GHz BUS 533 MHz 0.13 micron D1 512 KB 478 pin
SL6Q8 2.40 GHz BUS 533 MHz 0.13 micron D1 512 KB 478 pin
SL6PB 2.26 GHz BUS 533 MHz 0.13 micron D1 512 KB 478 pin
SL6Q7 2.26 GHz BUS 533 MHz 0.13 micron D1 512 KB 478 pin
Bene ora sono pronto per l'upgrade... :sol:
Anonymous
CPUs Authority
Hi, I was trying to upgrade CPU (C4, 1G8/400) on a MS-6541 ver 1.0 mobo form a HP310V desktop (of course with a 3.18 (12 Jun 2003) updated BIOS), but without success :(  No one from the following CPUs is working: P4 2G8/533, P4 2G66/533, P4 2G4/400, P4 2G0/400, C4 2G6/533 (all of them tested !) The computer simply does not start at all. Is there any trick I am not familiar with ? Because two another C4 1G7/400 are working well. Surprinsingly the mobo adopted memory upgrade and an ATI HD3650 / AGP 4x without any problems (Half Life 2 is running well and Full HD Video with Audio via HDMI also). Thanks for any hint ...
Ask the community
