Archived from groups: microsoft.public.windowsxp.hardware (More info?)
Hi:
I am installing a MB with built in audio and I donot see any place on the
board to connect the audio cable from the CD Rom, or is it needed.
TIA
John
Sponsored Links
"John" <John@discussions.microsoft.com> wrote in message
news:97EBDE1D-2BC6-46E3-A12D-EA87DC3D15F6@microsoft.com...
> Hi:
The audio cable is not needed. This cable allows you to play an Audio CD
directly from your CD-ROM while bypassing your system. It takes the analog
signal and inputs it directly to your audio output. It's essentially the
same as if you were to connect an audio device to your input on the sound
card.
If this is a need you have, you'll need the cable. Otherwise, you'll do
fine without it. If your board does not have the input, then you cannot,
obviously, do this.
Reply to Anonymous
If you are having the sound played back "digitally", then you do not need
that cable. If you want the sound played back in "analog" (ie: stereo radio
style) then you may need it.
"DJ Borell" <dborell(remove)@techmedix.com> wrote in message
news:OH2KrhuGFHA.2156@TK2MSFTNGP09.phx.gbl...
>> Hi:
> analog signal and inputs it directly to your audio output. It's
> essentially the same as if you were to connect an audio device to your
> input on the sound card.
> obviously, do this.
Reply to Anonymous
Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > CD Rom audio cable.
There are 1053 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
