K7N2 Delta L & Pioneer DVR-108 problems
Archived from groups: alt.comp.periphs.mainboard.msi-microstar (More info?)
I have a K7N2 Delta-L with an XP2500 & 256mb of RAM. I'm running W2k
with the latest updates.
I got the Pioneer burner for Christmas. I was able to back-up a
commercial DVD (yes, I own it :) ), but whe I tried doing a back-up
or data DVD using Nero, it would get about half-way & error out. I
checked the drive with Nero's 'Test Drive' function & it immediately
got a CRC communication error.
Yesterday I tried to make an iso disc so I could upgrade the firmware
on my dvd player, but at 57%, it got a lost communication error.
I tried rearranging the cable (the Pioneer was the slave while a
Hitachi DVD-ROM was the master), but it first stopped recognizing any
optical drive I attached & then stopped recognizing the 2 HDDs if a cd
drive was attached.
Am I correct in assuming this is a problem with the IDE drivers? Does
anybody know if updating the drivers with the latest from the MSI site
would correct this?
What about Microsoft drivers? Can I get them from the MS site or the
OS disk? Is there a downside to using MS's drivers?
3 answers Last reply
More about k7n2 delta pioneer problems
  1. Archived from groups: alt.comp.periphs.mainboard.msi-microstar (More info?)
    "Chris" <cbryantNOSPAM@tsh.ca> wrote in message
    news:j39jt0pjkk2qqpal6sci0hro3gu3j0hueu@4ax.com...
    > drive was attached.
    > would correct this?
    Could be your ASPI layer?
    http://www.cdmediaworld.com/hardware/cdrom/cd_utils_5.shtml Scroll to the
    bottom, try the Adaptec ASPI check, and the 4.72 drivers if you need them.
    As far as the IDE drivers, most recommend the MS drivers OVER the nvidia
    ones as they seem more problematic. I think it's a toss up as I've used
    both without trouble and benchmarks go either way depending on which one you
    try. Usually have stuck to the MS drivers though. You've got enough
    machine to upgrade to XP. Maybe it's time?
    HTH....
  2. Archived from groups: alt.comp.periphs.mainboard.msi-microstar (More info?)
    >> drive was attached.
    >> would correct this?
    >HTH....
    Yeah, I think it's time, too.
    I uninstalled the IDE drivers, rebooted & let it install new hardware,
    but it still doesn't find any drive if I hook up an optical drive.
    I just find W2K pretty stable & I've heard rumblings about conflicts
    with software & WinXP.
  3. Archived from groups: alt.comp.periphs.mainboard.msi-microstar (More info?)
    "Chris" <cbryant1NOSPAM@sympatico.ca> wrote in message
    news:09qjt0l6hi4s4cs1fbgcucg29v3sl076r8@4ax.com...
    >>> drive was attached.
    >>> would correct this?
    >>you
    >>HTH....
    Maybe the cable then? The whole software-XP conflict thing is long gone.
    It's by far the best MS O/S and matured up to SP2.
MSI-Microstar Pioneer Motherboards
