Archived from groups: microsoft.public.windowsxp.hardware (
More info?)
Hi Peter,
>7,200 RPM Hdd is more than
> enough for normal use.
Hard drive speeds are the biggest obstacle in fast computing.
It is the only device that is mechanical, where friction and RPM has
big effect.
10,000 RPM is taking it to the extremes, and might be un-reliable drive,
where heat, friction and precession are big factors.
I believe if you shop around, you can get that hard drive for about $240.
> BTW, I think you have heard about the 64bit CPU and 64 bit XP
I did hear about and been reading about it.
The biggest problem is even MS doesn't have a 64 bit programming
language. They haven't been even talking about it.
I think 64 bit is going to take much longer transition than when
Win 95 first came out.
Hardware and software took almost a year to catch up after Win 95 release.
Had to wait four months to get a compatible Motherboard and video card.
> I think it is better to follow the mainstream.
> What do you think?
You are very right, but I am a developer, and have to be ready
for what is ahead.
Dual core and 64 bit is going to be an attraction for many users.
Ted
"Peter" <Peter@discussions.microsoft.com> wrote in message
news:41F6043C-19CA-4B31-A107-829412283CF4@microsoft.com...
> Ted,
> The new dual core CPU and the 10,000r.p.m. WD SATA drive may cost you a
> lot
> of money. Unless you are an extreme gamer or you need to process extensive
> graphic works, a 3GHz P4 CPU and an ordinary 7,200 RPM Hdd is more than
> 4 months ago, I built a PC for my daughter. I bought an Intel Mobo 915GAV
> 800FSB with onboard GMA900 vedio chips and onboard HD audio, a P4 3GHz CPU
> (with HT), 1Gig DDR400 2.5ns ram, 2 Maxtor 120Gig SATA Hdds, 1 16XDVD
> player,
> 1 16X CD/RW, an Asus chassis with a good quality 350W power supply. The
> total
> cost of these components is $740.- which I think is a good deal. All the
> softwares costs are not included as they are far more expensive than the
> hardwares. The PC works great but the vedio is weak. It works OK if you
> are
> not a gamer. So I decided to buy a PCI Express vedio card, a Nvidia
> GF6600GT
> 128MB around $200.-. this card works great for all gamers.
> So, I would rather spend money on the best quality ordinary hardwares
> available in the market instead of spend money on the most advanced CPU
> and
> fastest hard drives.
> BTW, I think you have heard about the 64bit CPU and 64 bit XP. The 64bit
> system is very fast and stable but in today's world, there are seldom
> softwares/drivers that are written in 64 bit process. So the 64bit system
> users are facing headache looking for proper drivers and softwares. It may
> take a few years time for the 64bit support.
> What do you think?
> Peter
> "Ted" wrote:
>> Hi Peter,
>> I decided to wait for the dual core processor by Intel,
>> should be an exciting processor.
>> Don't know what mother board it needs, by then
>> Intel should list all compatible motherboards.
>> > I built my own PCs and they are all working fine.
>> I have a local computer shop that I know for years,
>> they build my computers as I please. I go over it
>> when I get it.
>> My wife was going through final exams, her computer took a dive,
>> so I rushed in and bought a cheap one of the shelve to get her
>> going right away, it happened to be the culprit.
>> I have two other SCSI computers, all networked together.
>> I am going to try SATA drives this time and switch from SCSI.
>> Wonder if Western Digital 10,000 RPM is a reliable drive.
>> "Enterprise Serial ATA hard drives World's fastest Serial ATA
>> drive: 10,000 RPM, 4.5 ms seek"
>> >poorly written USB device
>> I agree, I think that is the problem with the Sony camera.
>> LG CD-DVD/RW GSA-5120D is their first external USB drive.
>> ADS drive kit was their second, I have their first
>> and it works great.
>> To confuse you more, I have an older LG internal DVD-CD/RW drive
>> in an older ADS USB drive kit, both work great.
>> But because I returned the second ADS and the second LG, I bought
>> Belkin drive kit with Benq DVD-CD/RW dual layer, and they work great.
>> Ted
>> news:675BED70-7B3B-49D3-941F-65F5C3B24C7F@microsoft.com...
>> > Ted,
>> > There are many reasons that those plug and play USB devices cannot be
>> > working properly in windows enviroment; hardwares/softwares conflicts,
>> > mobo
>> > BIOS, mobo chipset drivers, system I/O BUS, poorly written USB device
>> > drivers, insufficient electric power, etc, etc.
>> > Hope you can get a trouble free new PC.
>> > Peter
>> > "Ted" wrote:
>> >> Hi Peter,
>> >> There other many reasons we are junking this computer.
>> >> Some computers these days, better to buy new ones
>> >> than try fixing them.
>> >> What I didn't understand, is all other USB devices
>> >> work OK in this computer, but not the Sony camera.
>> >> I wish I still have the ADS drive kit and LG CD-DVD/RW drive,
>> >> and would experiment with it. With those the problem was
>> >> on different computers than the above.
>> >> > Sorry if I have misleaded you. MS do support other USB devices other
>> >> > than
>> >> > NEC chipsets.
>> >> NEC is a Microsoft plug and play device, others need a driver.
>> >> Thanks
>> >> Ted
>> >> news:37B3C4EC-168F-44B5-9836-3784783C431D@microsoft.com...
>> >> > ed,
>> >> > I think the chipset drivers and/or the mobo BIOS is the culprit.
>> >> > You can download Belarc Advisor to have a detail info of your
>> >> > system.
>> >> > You can download it from :
http://www.belarc.com/free_download.html
>> >> > Have you changed the mobo battery and then load the BIOS default
>> >> > setup?
>> >> > Pls let me know the brand/model/self built and configurations of
>> >> > your
>> >> > PC
>> >> > so
>> >> > that I can have more info to analyse the problem. You can easily get
>> >> > those
>> >> > info after you have downloaded and installed the Belerc Advisor.
>> >> >> Also hope MS comes up with a fix, and support other USB
>> >> >> devices other than NEC chipsets.
>> >> > than
>> >> > NEC chipsets. What I meant to say was that if the mobo using Intel
>> >> > chipsets,
>> >> > using NEC USB chipsets would be better than using a VIA USB
>> >> > chipsets.
>> >> > There
>> >> > is nothing to do with MS.
>> >> > BTW, it is a challenge to fix the problem. With the help of Belarc
>> >> > Advisor,
>> >> > you would know the mobo BIOS, chipsets details, system BUS,
>> >> > softwares
>> >> > installed and license, windows updated details, etc.
>> >> > Hope you can try it and inform me the outcome.
>> >> > Peter
>> >> > "Ted" wrote:
>> >> >> Hello Peter,
>> >> >> I did install a USB 2, with a NEC chipset, but
>> >> >> the problem is the same.
>> >> >> For few other reasons, we decided to replace the computer.
>> >> >> USB suppose to make things easier, but unfortunately
>> >> >> it is not as easy, and it have big bugs.
>> >> >> Thank you very much for the help, I know how to go about
>> >> >> removing VIDs and fix the problem if it happens in another
>> >> >> computer.
>> >> >> > Remember update the mobo chipset drivers first and change the
>> >> >> > battery
>> >> >> > as
>> >> >> > it
>> >> >> > has been using for 3 years.
>> >> >> I found that the MB is generic, and that is one of the reasons
>> >> >> we are going to replace it.
>> >> >> Ted
>> >> >> news:E5317CD0-91EA-49BF-96A9-E4A00EEC22C3@microsoft.com...
>> >> >> > Ted,
>> >> >> > battery
>> >> >> > as
>> >> >> > it
>> >> >> > Peter
>> >> >> > "Ted" wrote:
>> >> >> >> Hi Peter,
>> >> >> >> > I would suggest you to buy a PCI USB 2.0 card
>> >> >> >> I think I will try that first before updating the BIOS.
>> >> >> >> The computer is about three years old, with onboard 2 USB1
>> >> >> >> slots.
>> >> >> >> I do have an extra 4 slot USB2 PCI card, that I will install.
>> >> >> >> I think it should take care of it, will let you know.
>> >> >> >> Thanks again.
>> >> >> >> Ted
>> >> >> >> news:ECD60EC3-0AB8-47FC-ADEA-CE1144A5AD9C@microsoft.com...
>> >> >> >> > Ted,
>> >> >> >> > Below are the links for drivers update and FAQ:
http://esupport.sony.com/perl/swu-list.pl?template=EN&mdl=DSCP41
http://esupport.sony.com/perl/faq-model.pl?template=EN&mdl=DSCP41
>> >> >> >> > Your digicam should be USB 2.0, are you using USB2.0 for
>> >> >> >> > connection?
>> >> >> >> > If yes, is it an onboard USB2.0 chips or PCI USB 2.0 card?
>> >> >> >> > I think it is an onboard USB chips as you said you have
>> >> >> >> > unpluged
>> >> >> >> > the
>> >> >> >> > HP
>> >> >> >> > printer.
>> >> >> >> > For older mobo over 4 years, it only has limited USB ports
>> >> >> >> > (may
>> >> >> >> > be
>> >> >> >> > only
>> >> >> >> > 2
>> >> >> >> > USB 1.0 ports)
>> >> >> >> > Well, I don't think the unplug of USB printer would cause
>> >> >> >> > problems.
>> >> >> >> > It may be caused by the mobo BIOS or I/O chipset drivers.
>> >> >> >> > I would suggest you to update the mobo chipset drivers first
>> >> >> >> > and
>> >> >> >> > if
>> >> >> >> > the
>> >> >> >> > symptom persists, update the mobo BIOS as well. Special care
>> >> >> >> > should
>> >> >> >> > be
>> >> >> >> > taken
>> >> >> >> > for BIOS update as an improper update of BIOS may turn your PC
>> >> >> >> > to
>> >> >> >> > a
>> >> >> >> > dead
>> >> >> >> > stone and the repair charges is expensive. Load setup default
>> >> >> >> > after
>> >> >> >> > updated
>> >> >> >> > BIOS and then adjust the BIOS to suit your requirements.
>> >> >> >> > Note: you may also need to change the battery on the mobo if
>> >> >> >> > it
>> >> >> >> > is
>> >> >> >> > over
>> >> >> >> > 3
>> >> >> >> > years.
>> >> >> >> > In some cases, the CMOS cause troubles if the battery is too
>> >> >> >> > weak.
>> >> >> >> > BTW, if you does not have sufficient USB 2.0 ports to connect
>> >> >> >> > all
>> >> >> >> > your
>> >> >> >> > USB
>> >> >> >> > devices,
>> >> >> >> > I would suggest you to buy a PCI USB 2.0 card (prefer to use
>> >> >> >> > NEC
>> >> >> >> > chipset
>> >> >> >> > for
>> >> >> >> > mobo using intel chipsets, for mobo using VIA chipsets, you
>> >> >> >> > may
>> >> >> >> > buy
>> >> >> >> > the
>> >> >> >> > USB
>> >> >> >> > card using VIA chipsets as it is a little bit cheaper). A 4+1
>> >> >> >> > port
>> >> >> >> > USB
>> >> >> >> > 2.0
>> >> >> >> > card with NEC chipsets cost only about $10.- to $15.-
>> >> >> >> > Let me know the outcome.
>> >> >> >> > Peter
>> >> >> >> > "Ted" wrote:
>> >> >> >> >> Hi peter,
>> >> >> >> >> It is Cyber Shot DSC P41.
>> >> >> >> >> Works OK in one XP machine.
>> >> >> >> >> But no luck with the XP I want it to work on.
>> >> >> >> >> Removing the VID and re-installing software worked fine.
>> >> >> >> >> But the second time I plugged in the USB, XP crashed
>> >> >> >> >> with error:
>> >> >> >> >> 0x00000050 (0xFFFFFFE8 0x80511098 0x00000000)
>> >> >> >> >> Restarted computer and the camera worked OK, until
>> >> >> >> >> I remove it and insert it a second time.
>> >> >> >> >> I looked in MS Knowledge Base, found no related articles.
>> >> >> >> >> except may be because the HP USB printer is unplugged ??
>> >> >> >> >> Thanks
>> >> >> >> >> Ted
>> >> >> >> >> news
D3CD3F0-86AD-407A-AA5F-AF2E034DC66F@microsoft.com...
>> >> >> >> >> > Ted,
>> >> >> >> >> > Yes, uninstall device from device manager would not delete
>> >> >> >> >> > the
>> >> >> >> >> > registry
>> >> >> >> >> > keys.
>> >> >> >> >> > You should not delete the registry key unless the drivers
>> >> >> >> >> > of
>> >> >> >> >> > that
>> >> >> >> >> > USB
>> >> >> >> >> > device
>> >> >> >> >> > was improperly loaded or could not be loaded.
>> >> >> >> >> > I have two digicams, Sony and Canon, both working
>> >> >> >> >> > flawlessly
>> >> >> >> >> > with
>> >> >> >> >> > my
>> >> >> >> >> > two
>> >> >> >> >> > XP
>> >> >> >> >> > Pro SP2 machines.
>> >> >> >> >> > BTW, let me know the model and driver version of your Sony
>> >> >> >> >> > digicam.
>> >> >> >> >> > There
>> >> >> >> >> > may be updated drivers for your cam.
>> >> >> >> >> > Peter
>> >> >> >> >> > "Ted" wrote:
>> >> >> >> >> >> Hello Peter,
>> >> >> >> >> >> >> It seems when the device is uninstalled from the device
>> >> >> >> >> >> >> manager,
>> >> >> >> >> >> >> it fails to remove it from the registry.
>> >> >> >> >> >> Maybe my statement is wrong.
>> >> >> >> >> >> Most likely it leaves it for next time USB device
>> >> >> >> >> >> connection.
>> >> >> >> >> >> Ted
>> >> >> >> >> >> news:68C76D9C-FCBD-4BE2-A125-A221784B0A28@microsoft.com...
>> >> >> >> >> >> > Ted,
>> >> >> >> >> >> > OK, let me know to-morrow.
>> >> >> >> >> >> > Peter
>> >> >> >> >> >> > "Ted" wrote:
>> >> >> >> >> >> >> Hi Peter,
>> >> >> >> >> >> >> I got it, thanks.
>> >> >> >> >> >> >> manager,
>> >> >> >> >> >> >> I don't have the Sony Camera, I will get it tomorrow
>> >> >> >> >> >> >> and
>> >> >> >> >> >> >> try
>> >> >> >> >> >> >> install it again. Will let you know.
>> >> >> >> >> >> >> Ted
>> >> >> >> >> >> >> message
>> >> >> >> >> >> >> news:C8A695BD-292D-4321-825A-A48DC67B35B8@microsoft.com...
>> >> >> >> >> >> >> > Ted,
>> >> >> >> >> >> >> > Try run regedit as follows:
>> >> >> >> >> >> >> > HKEY Local machine/SYSTEM/ControlSet001/Enum/USB,
>> >> >> >> >> >> >> > double click the USB folder, found the Vid keys that
>> >> >> >> >> >> >> > relevant
>> >> >> >> >> >> >> > to
>> >> >> >> >> >> >> > the
>> >> >> >> >> >> >> > device
>> >> >> >> >> >> >> > that you want to delete and than delete the whole Vid
>> >> >> >> >> >> >> > keys.
>> >> >> >> >> >> >> > If errors occurred that you couldn't allow to delete
>> >> >> >> >> >> >> > the
>> >> >> >> >> >> >> > Vid
>> >> >> >> >> >> >> > keys,
>> >> >> >> >> >> >> > right
>> >> >> >> >> >> >> > click on the Vid key, click permissions, select Full
>> >> >> >> >> >> >> > control
>> >> >> >> >> >> >> > in
>> >> >> >> >> >> >> > the
>> >> >> >> >> >> >> > Permissions for Everyone area, click Apply and OK.
>> >> >> >> >> >> >> > Now try to delete the Vid keys again.
>> >> >> >> >> >> >> > Care: export the registries and save to a specific
>> >> >> >> >> >> >> > folder
>> >> >> >> >> >> >> > before
>> >> >> >> >> >> >> > any
>> >> >> >> >> >> >> > deletion.
>> >> >> >> >> >> >> > Hope it helps.
>> >> >> >> >> >> >> > Peter
>> >> >> >> >> >> >> > "Ted" wrote:
>> >> >> >> >> >> >> >> > I meant have you run regedit to clear the invalid
>> >> >> >> >> >> >> >> > Vid
>> >> >> >> >> >> >> >> > keys?
>> >> >> >> >> >> >> >> I did the Uninstall hardware from Device Manager and
>> >> >> >> >> >> >> >> rebooted.
>> >> >> >> >> >> >> >> You said Or, figured I don't need to remove it from
>> >> >> >> >> >> >> >> registry.
>> >> >> >> >> >> >> >> I get error deleting the VID keys.
>> >> >> >> >> >> >> >> It also has USBStor with all the USB drives that I
>> >> >> >> >> >> >> >> installed
>> >> >> >> >> >> >> >> in the past, but non will delete.
>> >> >> >> >> >> >> >> I have full administrator permission to edit
>> >> >> >> >> >> >> >> registry.
>> >> >> >> >> >> >> >> message
>> >> >> >> >> >> >> >> news:05996D00-CB5D-4786-B613-BD89BE5766C2@microsoft.com...
>> >> >> >> >> >> >> >> > Ted,
>> >> >> >> >> >> >> >> > Vid
>> >> >> >> >> >> >> >> > keys?
>> >> >> >> >> >> >> >> > Peter
>> >> >> >> >> >> >> >> > "Ted" wrote:
>> >> >> >> >> >> >> >> >> Hi Peter,
>> >> >> >> >> >> >> >> >> > Have you tried what I have suggested?
>> >> >> >> >> >> >> >> >> Ops apologies, I have done that many times, that
>> >> >> >> >> >> >> >> >> is
>> >> >> >> >> >> >> >> >> why
>> >> >> >> >> >> >> >> >> I posted the first message.
>> >> >> >> >> >> >> >> >> Ted
>> >> >> >> >> >> >> >> >> in
>> >> >> >> >> >> >> >> >> message
>> >> >> >> >> >> >> >> >> news:49C1FC55-33A7-4CDB-9F71-717EB04F4F9B@microsoft.com...
>> >> >> >> >> >> >> >> >> > Ted,
>> >> >> >> >> >> >> >> >> > Peter
>> >> >> >> >> >> >> >> >> > "Ted" wrote:
>> >> >> >> >> >> >> >> >> >> Hello Peter,
>> >> >> >> >> >> >> >> >> >> > Or, simply go to device manager and
>> >> >> >> >> >> >> >> >> >> > uninstall
>> >> >> >> >> >> >> >> >> >> > the
>> >> >> >> >> >> >> >> >> >> > USB
>> >> >> >> >> >> >> >> >> >> > host
>> >> >> >> >> >> >> >> >> >> > controller
>> >> >> >> >> >> >> >> >> >> > and
>> >> >> >> >> >> >> >> >> >> > then reboot.
>> >> >> >> >> >> >> >> >> >> I believe its a bug in Win XP, I think above
>> >> >> >> >> >> >> >> >> >> never
>> >> >> >> >> >> >> >> >> >> works
>> >> >> >> >> >> >> >> >> >> again,
>> >> >> >> >> >> >> >> >> >> unless you do it right from the beginning.
>> >> >> >> >> >> >> >> >> >> I had to return the ADS and LG drive thinking
>> >> >> >> >> >> >> >> >> >> there
>> >> >> >> >> >> >> >> >> >> is
>> >> >> >> >> >> >> >> >> >> something
>> >> >> >> >> >> >> >> >> >> wrong with the devices, but still have the
>> >> >> >> >> >> >> >> >> >> Sony
>> >> >> >> >> >> >> >> >> >> camera,
>> >> >> >> >> >> >> >> >> >> that
>> >> >> >> >> >> >> >> >> >> works
>> >> >> >> >> >> >> >> >> >> one computer but not on the one that I want it
>> >> >> >> >> >> >> >> >> >> to
>> >> >> >> >> >> >> >> >> >> work
>> >> >> >> >> >> >> >> >> >> on.
>> >> >> >> >> >> >> >> >> >> Ted
>> >> >> >> >> >> >> >> >> >> wrote
>> >> >> >> >> >> >> >> >> >> in
>> >> >> >> >> >> >> >> >> >> message
>> >> >> >> >> >> >> >> >> >> news:EADC1BBF-7F4A-457F-A51A-C7A74CF164DA@microsoft.com...
>> >> >> >> >> >> >> >> >> >> > HI,
>> >> >> >> >> >> >> >> >> >> > You can clear the registry by running
>> >> >> >> >> >> >> >> >> >> > regedit
>> >> >> >> >> >> >> >> >> >> > on
>> >> >> >> >> >> >> >> >> >> > the
>> >> >> >> >> >> >> >> >> >> > Enum
>> >> >> >> >> >> >> >> >> >> > USB,
>> >> >> >> >> >> >> >> >> >> > HKEY Local
>> >> >> >> >> >> >> >> >> >> > Machine/SYSTEM/ControlSet001/Enum/USB/Vid_xxxxxxxxxxx
>> >> >> >> >> >> >> >> >> >> > Find the Vid for your device and delete the
>> >> >> >> >> >> >> >> >> >> > keys.
>> >> >> >> >> >> >> >> >> >> > Backup the regtistry before deletion.
>> >> >> >> >> >> >> >> >> >> > uninstall
>> >> >> >> >> >> >> >> >> >> > the
>> >> >> >> >> >> >> >> >> >> > USB
>> >> >> >> >> >> >> >> >> >> > host
>> >> >> >> >> >> >> >> >> >> > controller
>> >> >> >> >> >> >> >> >> >> > and
>> >> >> >> >> >> >> >> >> >> > then reboot. Windows shhould found new
>> >> >> >> >> >> >> >> >> >> > hardware
>> >> >> >> >> >> >> >> >> >> > and
>> >> >> >> >> >> >> >> >> >> > reinstall
>> >> >> >> >> >> >> >> >> >> > the
>> >> >> >> >> >> >> >> >> >> > USB
>> >> >> >> >> >> >> >> >> >> > drivers.
>> >> >> >> >> >> >> >> >> >> > Care: disconnect the USB devices before
>> >> >> >> >> >> >> >> >> >> > uninstall.
>> >> >> >> >> >> >> >> >> >> > Hope it helps.
>> >> >> >> >> >> >> >> >> >> > Peter
>> >> >> >> >> >> >> >> >> >> > "Ted" wrote:
>> >> >> >> >> >> >> >> >> >> >> I made the mistake by plugging a USB device
>> >> >> >> >> >> >> >> >> >> >> before
>> >> >> >> >> >> >> >> >> >> >> installing the driver, Win XP with SP2 (and
>> >> >> >> >> >> >> >> >> >> >> Win
>> >> >> >> >> >> >> >> >> >> >> 98)
>> >> >> >> >> >> >> >> >> >> >> couldn't
>> >> >> >> >> >> >> >> >> >> >> detect
>> >> >> >> >> >> >> >> >> >> >> the device and installed the wrong driver
>> >> >> >> >> >> >> >> >> >> >> for
>> >> >> >> >> >> >> >> >> >> >> it.
>> >> >> >> >> >> >> >> >> >> >> I uninstalled the driver, installed the
>> >> >> >> >> >> >> >> >> >> >> device
>> >> >> >> >> >> >> >> >> >> >> driver,
>> >> >> >> >> >> >> >> >> >> >> but
>> >> >> >> >> >> >> >> >> >> >> no
>> >> >> >> >> >> >> >> >> >> >> way
>> >> >> >> >> >> >> >> >> >> >> you can get the device to work ever again.
>> >> >> >> >> >> >> >> >> >> >> This happened to me on Sony camera, ADS
>> >> >> >> >> >> >> >> >> >> >> drive
>> >> >> >> >> >> >> >> >> >> >> kit,
>> >> >> >> >> >> >> >> >> >> >> and
>> >> >> >> >> >> >> >> >> >> >> external LG DVD/RW.
>> >> >> >> >> >> >> >> >> >> >> Anybody knows how to reset windows without
>> >> >> >> >> >> >> >> >> >> >> restoring
>> >> >> >> >> >> >> >> >> >> >> the registry and start fresh ? Maybe a
>> >> >> >> >> >> >> >> >> >> >> registry
>> >> >> >> >> >> >> >> >> >> >> cleaning
>> >> >> >> >> >> >> >> >> >> >> or changing that have to be done.
