XP 64 bit Hard Drive Size Problem.
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
Have just installed Windows XP 64 bit (Service Pack 1, v.1433) onto a brand
new Maxtor 250GB Hard Drive. However windows only recognises the drive as
31.4GB.
I have tried altering the size in "Computer Management" but no luck.
I have also tried the Registry fix to allow large Hard Drives from the
Maxtor site but it will not work in XP 64bit.
I have tried downloading 64 bit Service Pack 2 - can't find it anywhere,
does it exist?
Automatic updates doesn't find anything at all to download.
Tried downloading various security fixes for 64bit from Microsoft but none
of them will run.
Does XP 64 bit have a hard drive size limit like the original XP did?
Is there any way I can get XP 64bit to recognise the 250GB Hard drive.
Thanks in advance for ANY suggestions or advise.
7 answers Last reply
More about hard drive size problem
  1. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    The limit you are hitting is probably NOT the original XP limit, since that
    was around 127 Gig.
    A limit around 32 Gig (+-) sounds more like a BIOS limit for a motherboard
    that is several years old, and whose BIOS has not (or can not) be updated.
    "Nanoc III" <Nanoc III@discussions.microsoft.com> wrote in message
    news:E2383633-27A6-406D-8690-13E7B2766A87@microsoft.com...
    > brand
    > 31.4GB.
    > does it exist?
    > of them will run.
    > Thanks :-(
  2. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Hi,
    How did you format the drive, NTFS or FAT32?
    For FAT32, you are limited to 32 GB under XP.
    Pls also check the Hdd size in the mobo bios to ensure it shows 250GB.
    Hope it helps.
    Peter
    > was around 127 Gig.
    > > brand
    > > 31.4GB.
    > > does it exist?
    > > of them will run.
    > > Thanks :-(
  3. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Service Pack 1?
    No such thing for the operating system you installed.
    Sounds like you have a BIOS problem.
    Make sure you have the latest BIOS from the motherboard manufacturer.
    Also your questions a will be better answered in the 64 bit newsgroups:
    http://www.microsoft.com/windowsserver2003/64bit/x64/trial/support.mspx
    The Server newsgroup is correct.
    Jupiter Jones [MVP]
    http://www3.telus.net/dandemar/
    > brand
    > 31.4GB.
    > does it exist?
    > of them will run.
    > Thanks :-(
  4. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    > brand new Maxtor 250GB Hard Drive. However windows only recognises
    > the drive as
    > 31.4GB.
    > anywhere, does it exist?
    > none of them will run.
    > Thanks :-(
    Wrong group. This group is for Windows XP 32-bit only. Please see the email
    you would have been sent when you downloaded the beta, it tells you how to
    access the 64-bit groups.
    Facon - the artificial bacon bits you get in Pizza Hut for sprinkling
    on salads.
  5. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Sorry that this is in the wrong forum, I came across this by accident.
    The motherboard is also brand new, an Asus AN8-SLi Deluxe.
    However the Disk does show up as the smaller size in the Bios.
    It is set to Auto detect, very strange?
    I will contact ASUS and see if they can help me.
    Thanks.
    "Jupiter Jones [MVP]" wrote:
    > Service Pack 1?
    > Jupiter Jones [MVP]
    > > brand
    > > 31.4GB.
    > > does it exist?
    > > of them will run.
    > > Thanks :-(
  6. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Check the jumper settings on the hard drive - Make sure there is no jumper
    on the J46.
    > brand
    > 31.4GB.
    > does it exist?
    > of them will run.
    > Thanks :-(
  7. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Have a look here :
    http://makeashorterlink.com/?S1222509A
    "RonK" <I'mhere@home.com> wrote in message
    news:paZTd.33749$uO.925517@news20.bellglobal.com...
    > on the J46.
    >> brand
    >> 31.4GB.
    >> does it exist?
    >> none
    >> of them will run.
    >> Thanks :-(
Hard Drives Windows XP
