USB mass storage device not getting drive letter
- Hardware
- Windows XP
Last response: in Windows XP
Anonymous
March 5, 2005 6:09:33 PM
Archived from groups: microsoft.public.windowsxp.hardware,comp.sys.ibm.pc.hardware.chips (More info?)
I got an external USB hard disk enclosure. It works fine on my laptop,
it gets detected, drivers get loaded, and everything shows up fine in
Device Manager, and a drive letter is assigned to it. When I put the
same device onto my desktop, almost everything happens the same,
except it doesn't get a drive letter assigned to it. I don't see it in
Disk Manager.
All computers are running XP SP2. I've tried it in a second desktop PC
with XP SP2 as well, and exact same thing happens -- no drive letter,
no recognition from Disk Manager, but Device Manager sees it fine
doesn't find any problems with it.
Yousuf Khan
Disk Manager.
Yousuf Khan
More about : usb mass storage device drive letter
Anonymous
March 5, 2005 10:55:05 PM
none wrote:
> Do you already have a drive Z:?
> Can you set a drive letter from Device Manager, under properties?
No, as I said, it doesn't show up as a disk under Disk Manager, but it
does show up as a device under Device Manager.
Yousuf Khan
Yousuf Khan
Anonymous
March 6, 2005 1:41:13 AM
Try using diskpart from the commandline to assign a drive. Hope this
works it has worked for me when I needed to make a drive showup. Could
be something else.
Later,
Alan
>>>>> "ykhan" == ykhan <yjkhan@gmail.com> writes:
ykhan> I got an external USB hard disk enclosure. It works fine on my
ykhan> laptop, it gets detected, drivers get loaded, and everything
ykhan> shows up fine in Device Manager, and a drive letter is
ykhan> assigned to it. When I put the same device onto my desktop,
ykhan> almost everything happens the same, except it doesn't get a
ykhan> drive letter assigned to it. I don't see it in Disk Manager.
ykhan> All computers are running XP SP2. I've tried it in a second
ykhan> desktop PC with XP SP2 as well, and exact same thing happens
ykhan> -- no drive letter, no recognition from Disk Manager, but
ykhan> Device Manager sees it fine doesn't find any problems with it.
ykhan> Yousuf Khan
be something else.
Later,
Alan
ykhan> Yousuf Khan
- USB mass storage device not getting drive letter - Forum
- Map drive mass storage device not getting drive letter - Forum
nicole
March 6, 2005 2:57:02 AM
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
Sorry Alan,
Can you please give me a step-by-step on that, as I am having the same
problem - device is installed and shows as working properly in Device
Manager, but does not show as a removable disk drive in the "My Computer"
window.
Thanks,
Nicole
> be something else.
> Later,
> Alan
> ykhan> Yousuf Khan
Sorry Alan,
window.
Thanks,
Nicole
> be something else.
> Later,
> Alan
> ykhan> Yousuf Khan
nicole
March 6, 2005 3:37:02 AM
Okay - I have sorted it out! The PC had assigned the same drive letter to
the USB drive as to a network drive. I went into Disk Management, (through
Control Panel, Administrative Tools, Computer Management) and re-assigned a
different (unused) drive letter to the USB drive - problem solved!
Thanks for the other posts, which helped me look in the right direction!
Nicole
"Nicole" wrote:
> Sorry Alan,
> window.
> Thanks,
> Nicole
> > be something else.
> > Later,
> > Alan
> > ykhan> Yousuf Khan
Nicole
"Nicole" wrote:
> Sorry Alan,
> window.
> Thanks,
> Nicole
> > be something else.
> > Later,
> > Alan
> > ykhan> Yousuf Khan
Anonymous
March 6, 2005 5:27:47 AM
> be something else.
Didn't work.
I heard somewhere that the USB mass storage driver doesn't seem to work
in a system with more than one hard drive (which is the case for all of
my desktops)?
Yousuf Khan
> be something else.
Didn't work.
my desktops)?
Yousuf Khan
Anonymous
March 6, 2005 6:10:32 AM
>Disk Manager.
Do you have partitions and/or network drives on your desktop? I've had
trouble with "collisions" between drive letters and I'm still not sure of
the rules - sometimes it seems that a drive letter "sticks" with removable
drives across systems. In Device Manager for the drive, from the Volumes
Tab click on Populate and see what drive letters it wants to use and a
possible collision, then go to Disk Management and fiddle with the drive
letters.
Rgds, George Macdonald
>Disk Manager.
letters.
Anonymous
March 6, 2005 12:20:07 PM
How do the device driver details compare on the two machines?
RM
RM
Anonymous
March 6, 2005 3:19:11 PM
Bitstring <vfdl21dblivmild0kmqitqedfrpcjpnv9n@4ax.com>, from the
wonderful person George Macdonald <fammacd=!SPAM^nothanks@tellurian.com>
>>Disk Manager.
>letters.
They shouldn't stick across systems, but they will definitely stick
across time - i.e. if a WinXP system has ever seen a formatted drive it
will have the (last) drive letter stored in the registry, which can
cause all sorts of confusion later. Usually it seems to work out OK, but
sometimes ..
GSV Three Minds in a Can
SC recommends the use of Firefox; Get smart, or get assimilated.
>>Disk Manager.
>letters.
sometimes ..
Anonymous
March 6, 2005 3:45:14 PM
They're almost identical, except for the no drive letter thingy.
Actually I don't have access to that machine where it's working right
now, that's in Montreal. I use (or was planning to use) this USB hard
disk to transfer files back and forth between my two setups in Ottawa
and Montreal (whereas previously I used to bring the whole laptop with
me when coming back to Ottawa).
Yousuf Khan
Yousuf Khan
Anonymous
March 6, 2005 4:44:14 PM
>> be something else.
>Didn't work.
>my desktops)?
> Yousuf Khan
I have 6 sca drives across two hbas, four optical drives, and 3 emulated CDs,
a SM/CF combo usb mass storage device plus a "thumb drive", all running under
XP Pro. No issues.
I think you're still missing a driver. Maybe the chipset drivers didn't
install correctly?
/daytripper
>> be something else.
>Didn't work.
>my desktops)?
> Yousuf Khan
XP Pro. No issues.
install correctly?
/daytripper
None
March 6, 2005 5:41:46 PM
"ykhan" <yjkhan@gmail.com> wrote in message
news:bd84ed0c.0503051509.7b5df8fb@posting.google.com...
> Disk Manager.
> Yousuf Khan
> Disk Manager.
> Yousuf Khan
Anonymous
March 6, 2005 6:53:31 PM
Does XP support environment variable LASTDRIVE ?
If so, is there any chance it's set to something
other than Z ?
My guess is that this isn't a productive line of
inquiry, as my various Win2K docs are entirely
silent on the topic, so chances are it's not an
XP feature.
Regards, Bob Niland mailto:name@ispname.tld
http://www.access-one.com/rjn email4rjn AT yahoo DOT com
NOT speaking for any employer, client or Internet Service Provider.
other than Z ?
XP feature.
Leo
March 6, 2005 7:23:57 PM
My USB drive works fine on a system with two other hard drives.
Get TweakUI and be sure to set last drive to Z.
LEO
The supply of government exceeds the demand.
"Yousuf Khan" <bbbl67@ezrs.com> wrote in message
news:0L6dnYG5ELTYrLbfRVn-qQ@rogers.com...
>> Hope this
>> showup. Could
>> be something else.
> Didn't work.
> to work in a system with more than one hard drive (which is the
> case for all of my desktops)?
> Yousuf Khan
LEO
>> Hope this
>> showup. Could
>> be something else.
> Didn't work.
> Yousuf Khan
Anonymous
March 6, 2005 9:51:05 PM
> other than Z ?
No, I haven't seen the lastdrive used since the DOS days, and even then
in the last days of DOS, they were already defaulting to Lastdrive of Z.
I have plenty of drive letters available, just none of them are used
by this drive.
Yousuf Khan
> other than Z ?
by this drive.
Yousuf Khan
Anonymous
March 7, 2005 9:00:10 AM
On Sun, 6 Mar 2005 12:19:11 +0000, GSV Three Minds in a Can
>>>Disk Manager.
>>letters.
>sometimes ..
In a perfect world, GUIDs (Globally Unique IDs) *really* are unique.:-)
I've seen some oddball behavior which I cannot explain.
>>>Disk Manager.
>>letters.
>sometimes ..
Anonymous
March 7, 2005 1:55:10 PM
cquirke (MVP Windows shell/user) wrote:
> Suspect this if Drive Manager shows the device (drive, volume) but
you
> don't see it in Windows Explorer. Use Drive Manager to set a
> different drive letter so that it escapes the shadow of the LAN
share.
No, "Drive" Manager (actually is "Disk" Manager, but I know what you
meant) is not showing it at all as a volume. If it showed up in Disk
Manager, I would've known what to do with it then.
Strangely enough, now this drive is not showing up on its original home
either, where it was working previously. I'm going to have see what
else is going on here, maybe something got shaken loose while I was
transporting it?
Yousuf Khan
you
share.
transporting it?
Yousuf Khan
Anonymous
March 7, 2005 1:56:43 PM
I did check it out with TweakUI originally.
Yousuf Khan
Yousuf Khan
Anonymous
March 7, 2005 2:03:41 PM
Scott Alfter wrote:
> I'm assuming that the drive is already partitioned and formatted.
When you
> plug it into your desktop and bring up the Disk Management plugin, is
it not
> showing up at all? The drive and its partitions should show up
there,
> whether one or more drive letters are allocated to the drive or not.
I've
> had parts of flash-card readers not get drive letters when they're
plugged
> in because they were already taken by network shares or other drives;
going
> into Disk Management and reassigning drive letters has always cleared
up the
> problem for me.
Yeah, it was already partitioned and formatted. In fact, it was
carrying some data for me that I wanted to transfer between a couple of
my machines, which I was not able to transfer because of this problem.
It's like as if the partition has gone totally missing. Actually even
if it was a completely blank unpartitioned disk, it would still show up
inside disk manager which would then give me the option to partition
and format it. But it doesn't show that.
Yousuf Khan
When you
it not
there,
I've
plugged
going
up the
> problem for me.
Yousuf Khan
Anonymous
March 7, 2005 2:05:26 PM
Franc Zabkar wrote:
> On 5 Mar 2005 15:09:33 -0800, yjkhan@gmail.com (ykhan) put finger to
> keyboard and composed:
laptop,
in
in
> >Disk Manager.
> Is a USB pen/thumb/flash drive assigned a drive letter?
Usually yes.
Were you asking a question or making an observation?
Yousuf Khan
laptop,
in
in
> >Disk Manager.
Usually yes.
Yousuf Khan
Anonymous
March 7, 2005 3:44:46 PM
On Sun, 06 Mar 2005 18:51:05 -0500, Yousuf Khan <bbbl67@ezrs.com>
One of the things that can hide a drive letter in XP, is a network
share with the same drive letter. This applies both to USB sticks and
to hard drive volumes.
Suspect this if Drive Manager shows the device (drive, volume) but you
different drive letter so that it escapes the shadow of the LAN share.
Cats have 9 lives, which makes them
ideal for experimentation!
Anonymous
March 7, 2005 8:54:32 PM
>Disk Manager.
- Franc Zabkar
Please remove one 's' from my address when replying by email.
>Disk Manager.
- Franc Zabkar
Anonymous
March 8, 2005 3:36:04 AM
>you
>share.
>transporting it?
Does it still show in Device Manager as a drive? If so what does Populate
show?
>you
>share.
>transporting it?
show?
Anonymous
March 8, 2005 11:27:32 AM
On 7 Mar 2005 11:05:26 -0800, "YKhan" <yjkhan@gmail.com> put finger to
>laptop,
>in
>in
>> >Disk Manager.
>Usually yes.
> Yousuf Khan
Sorry, I realised just after posting that my question may have been
ambiguous. What I was asking was whether a flash drive is assigned a
drive letter on *your* system in its present state. If so, then this
could shed some light on any LASTDRIVE issue, ie it could confirm
whether additional drive letters were available. Does the USB HD's
drive letter show up in Device Manager but not in Explorer, or is it
missing from both? Is it possible that the drive letter is hidden
(Tweakui should be able to tell you this)? If you switch to a command
prompt, can you see the HD using a DIR command?
- Franc Zabkar
>laptop,
>in
>in
>> >Disk Manager.
>Usually yes.
> Yousuf Khan
- Franc Zabkar
Anonymous
March 8, 2005 11:06:29 PM
> show?
Yes, it shows under Device Manager, Disk Drives, as "USB 2.0 Storage
Device USB Device".
I don't see a Populate option for it.
Yousuf Khan
> show?
Device USB Device".
Yousuf Khan
Anonymous
March 9, 2005 6:47:28 AM
>> show?
>Device USB Device".
Under the Volumes tab of a disk/cd/dvd etc. drive there should be a
Populate button. If it ain't there, I'd think something might be wrong
with the MBR - not sure if bootitng www.bootitng.com works with USB yet but
it'd be worth a try to see what it makes of it. Other than that if you
care about the data, some other disk fix software?
>> show?
>Device USB Device".
Anonymous
March 10, 2005 12:32:36 AM
I had some problems getting my usb enclosure to show up and work on my
two computer also. My problem was with the drivers. I went to this
website:
http://www.usbnews.net/news/drivers%20for%20usb%20drive...
and used their generic usb enclosure drivers to get my enclosure
working and it works great. I hope this will help in your case as well.
website:
Anonymous
March 11, 2005 11:21:13 AM
> website:
Thanks for the pointer, I'll check that site out.
Yousuf Khan
> website:
Yousuf Khan
Anonymous
March 11, 2005 3:21:39 PM
The mystery has been solved. The drive inside the enclosure seems to
have died. I took a drive out of another laptop and plugged it into
here and found that it worked. There's a little airhole in these laptop
drives how much clearance is needed above them?
Yousuf Khan
Yousuf Khan
Anonymous
March 11, 2005 11:42:32 PM
Hi, removing the side of your case and blowing cool air inside, maybe a
hairdryer, might prove whether it's a heat issue. Other than that I've seen
the same issue when the memory chips of the card are failing....
ChrisC
"YKhan" <yjkhan@gmail.com> wrote in message
news:1110572499.438286.326380@f14g2000cwb.googlegroups.com...
> Yousuf Khan
ChrisC
> Yousuf Khan
Anonymous
March 12, 2005 6:54:12 AM
The air hole is for pressure equalization and not for ventilation. No
clearance is required.
One issue I've observed is that some USB enclosures for 2.5" notebook
drives do not use an external power source and instead rely on a
"double" USB plug. This causes problems with certain systems, and can
cause the symptoms you described. Sometimes the drive won't spin up,
and sometimes it won't get a drive letter. And these problems may come
and go, or not appear at all on certain systems, depending on the
amount of power supplied by the USB ports.
Gary L.
Reply to the newsgroup only
Gary L.
- I can see my WD 750gb USB mass storage device letter in windows wista Forum
- USB Mass Storage Drive Letter Forum
- How to assogn a drive to a usb mass storage device Forum
- Cant see USB mass storage device flash drive in My Computer Forum
- My usb mass storage device are not showing all 4 drive its show only 1 drive but Forum
- What is USB mass storage device drives E: F: G: H: Forum
- SolvedUSB Mass Storage Device - Driver won't install to save my life... Forum
- Solvedusb mass storage device in device manager NOT disk management Forum
- SolvedUSB mass storage device shows in Device Manager, not in Disk Management Forum
- SolvedUsb device not recognized (Mass Storage) but optical mouse works Forum
- Solvedusb mass storage device Forum
- SolvedUsb mass storage device Forum
- USB Mass Storage DEVICE not recognized and not showing up as connected Forum
- SolvedProblem Ejecting USB Mass Storage Device Forum
- Problem loading Windows 7. Hard drive not recognized. Asks for Mass storage device driver Forum
- More resources
Read discussions in other Windows XP categories
