Archived from groups: microsoft.public.windowsxp.hardware (More info?)
I have a problem with USB. Device manager reports:
"The drivers for this device are not installed. (Code 28)
To reinstall the drivers for this device, click Reinstall Driver."
No amount of re-installing makes any difference, auto re-install, manual
re-install all result in the same problem. If I delete the devices and
do a rescan, XP recognises the USB devices but the driver install always
ends in the same error.
The USB used to work fine but now it doesn't. I installed XP on a spare
hard disk and the install went fine. USB recognised, installed and works
properly. I don't want to do a complete re-install on my main hard disk
because I have a heavily customised setup.
I feel that I need to delete some registry entries and files to get USB
to re-install correctly.
This is racking my brain. Any help will be much appreciated.
Joe
Joe
