G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.msi-microstar (More info?)
I Need Help!!
I tried to flash my DVD-ROM and it has gone horribly wrong, if i have
my DVD-ROM plugged in then the system freezes at checking NVRAM and i
can’t do anything at all, pressing any key does nothing on the
keyboard. If i unplug the drive comp boots up fine.
How can i get access to the DVD-ROM so that i can flash it again with
an ’official’ DOS based flash program i have downloaded from the
manufacturers site.
Motherboard is MSI, i will check model tonight.
Processor is AMD Athlon 2600+
DVD is BTC BDV 316C
Posted using the http://www.hardwareforumz.com interface, at author's request
Articles individually checked for conformance to usenet standards
Topic URL: http://www.hardwareforumz.com/MSI-Microstar-Help-Needed-Flashed-DVD-ROM-system-Freezes-checking-NVRAM-ftopict57485.html
Visit Topic URL to contact author (reg. req'd). Report abuse: http://www.hardwareforumz.com/eform.php?p=289545
I Need Help!!
manufacturers site.
DVD is BTC BDV 316C
