Archived from groups: microsoft.public.windowsxp.hardware (
More info?)
Hi,
Personally, I have not because even at my home environment, I set up a small
domain to do with work and with DSL and wireless routers.
But I heard from our technical support, that it is somehow required for
using direct cable and/or just via switching/hub. But I have not hands-on
test on this one.
Wish you luck.
"tfw48079" <tfw48079@discussions.microsoft.com> ¼¶¼g©ó¶l¥ó·s»D:924F0A73-8DF0-4EF7-AD72-046D15E24464@microsoft.com...
> Have you set up identical users on both PC's?? Or enabled guest account??
> "xfile" wrote:
>> Hi,
>> Just trying to help,
>> The variables can be many and depending on how do you connect the two
>> computers, such as what type of cable did you use (e.g.cross-over,
>> regular
>> LAN, or others?) or did you use any switching/hub?
>> Since home networking can range from very simple to complicated ones, so
>> here is a link from MS for your reference: Home and Small Office
>> Networking
>> with Windows XP --
http://www.microsoft.com/windowsxp/using/networking/default.mspx
>> Hope this helps.
>> "Ignacio Fernandez" <wolverine@movinet.com.uy>
>> ???????:u30pNs3KFHA.128@tk2msftngp13.phx.gbl...
>> > Yes i tried firewall off of the SP2
>> > share folders everything, but when i go to "see computers in this work
>> > group" i can see each other but no access is allowed one way or the
>> > other...
>> > "David Vair" <dvair@nycap.rr.com> escribio en el mensaje
>> > news:Kst_d.140590$nC5.108748@twister.nyroc.rr.com...
>> >> Firewall on?? Also do you have a shared folder set up?
>> >> Dave Vair
>> >> CNE, CNA, MCP, A+, N+
>> >> Computer Education Services Corp. (CESC)
>> >> "Ignacio Fernandez" <wolverine@movinet.com.uy> wrote in message
>> >> news:u34iUg3KFHA.3992@TK2MSFTNGP15.phx.gbl...
>> >>> hi, i have a windows xp SP2 based pc and a windows xp home based
>> >>> notebook,
>> >>> and i can not get them to conect, i need to transfer files between
>> >>> this
>> >>> two
>> >>> computers but when i configure the home or small office network it
>> >>> send
>> >>> a
>> >>> message "//Mobile is not accessible. You might not have permision to
>> >>> use
>> >>> htis network resurce. Contact the administrator of this server to
>> >>> find
>> >>> out
>> >>> if you have access permissions.
>> >>> Access denied"
>> >>> it happens both ways.... i tried everything would you please help
>> >>> me?!?!?!?
>> >>> thanks!
