G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
Hi,
I have an Intel 4C 3.4Ghz with an Asus P4P800 Deluxe motherboard.
Windows XP is supposed to display two graphs (CPU0 and CPU1) in Task Manager
with this hardware configuration. But it is not.
The processor is recognized correctly by Sandra 2005 SR1, but it shows :
Warning W234 - You are using a Hyper-Threaded system on an Operating System
that either does not support HT or does not support the total number of
logical CPUs of the system. Thus Hyper-Threading is not properly utilised.
You may as well disable it.
Fix: Make sure you are using the right Hyper-Threading kernel or update your
Operating System for HT support (use Windows XP/2003 or later). Do note that
some Operating Systems and software have licensing limits that may prevent
you from using all CPUs or you may be in violation of your licence.
I have a licensed Windows XP Pro SP2 (from MSDN as I'm subscriber).
And how can I enable HyperThreading if it is already enable in BIOS ?
Hi,
