G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.msi-microstar (More info?)
Hi All,
I've got a big problem and have been everywhere looking for answers. I just
put together a new PC and every time I go to start it up---- the fans and
lights come on and then quickly go out. The on/off led light blinks on and
off. Her's what I got:
MSI K8T Neo-V Socket 754 VIA K8T800 ATX AMD Motherboard
AMD Sempron 64 2600+ Palermo 800MHz
Rosewill 1GB (2 x 512MB) 184-Pin DDR SDRAM Unbuffered DDR 333 (PC 2700) Dual
Channel Kit System Memory
ASPIRE X-Navigator ATXA9N-BK/450 Black Steel ATX Full Tower Computer
Nvidia GeForce 4 MMX
Case ATX 450W dual fan power supply w/ automatic fan speed control Power
Supply
Put it all together ( now I'm just working bare bones to try to get the unit
to stay on. Checked and rechecked the processor and connections, took mobo
out and checked it on a non-conductive surface. No change. The MSI manual
( at least for this person) is terrible. So is the instructions for the
case. I set up the led switches and everything with lettering facing AWAY
from the edges. The Cmos jumper is on pins 1 +2.. The 20-pin power
connector from the PSU is in it's right place, but there was a 4-pin
cvonnector attached to that that goes to the JPW1 connection? I tried that
on and off. The memory sticks are set in right, the video board is in the
agp slot and is in good. I'm only using neccesary connections at this point
so I don't have the USB connections and any other hardware connections
plugged in at this time. There is aChassis intrusion connector on the
board, but that is left alone. There is a firewire cable from the case,
also, that I don't think I do anything with.
Any clues? I HOPE all my hardware is good. How would I ever troubleshoot
it down to the problem? I would be thankful for anybody maybe seeing what I
missed (my eyes are tired of looking at all these small connections.
Thanks,
Al alanj77@verizon.net
Hi All,
Supply
Thanks,
