hard drive format problems
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
Just installed a usb 2 external hard drive on my daughters computer running
XP sp2 . It recognizes the hard drive I was able to partition it but have
been unsuccessful in formatting it will get to almost being done and then it
errors out and you get the format failed. Any suggestions? The hard drive is
a western digital 60 gig that I just got as a replacement for a failed
drive. I set the partition to a primary one and tried the format to NTSF
default sectors.
Jim
13 answers Last reply
More about hard drive format problems
  1. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    At this stage you will need 3rd party drive management utilities such as
    available from the Hard Drive Manufacturer. I say this because, once Windows
    has completed the partitioning of a disk, it cannot undo that work.
    My suggestion would be to revert to a single partition and then attempt a
    format.
    Once this is successful use a 3rd part utility to partition if needed.
    Once partitioned and formatted it needs to be set as active.
    > default sectors.
    > Jim
  2. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    >> running XP sp2 . It recognizes the hard drive I was able to partition it
    >> but have been unsuccessful in formatting it will get to almost being done
    >> and then it errors out and you get the format failed. Any suggestions?
    >> The hard drive is a western digital 60 gig that I just got as a
    >> replacement for a failed drive. I set the partition to a primary one and
    >> tried the format to NTSF default sectors.
    >> Jim
    "BAR" <BAR@discussions.microsoft.com> wrote in message
    news:69237F02-04A6-4EF4-AA87-30696313400D@microsoft.com...
    > Windows has completed the partitioning of a disk, it cannot undo that
    > work.
    > format.
    Jim:
    It's hard to tell exactly why this problem arose based on the info you
    provided, so let me pose a few questions and recommend some possible actions
    you might take...
    1. I assume you installed that 60 GB WD drive in a USB external hard drive
    enclosure, i.e., it's not a sealed unit that you purchased. So that the
    drive can be easily removed from the enclosure.
    2. Did you use XP's Disk Management utility to partition and then attempt to
    format the USB EHD? And when the formatting failed, did you try at least
    once or twice more?
    3. When you say it "errors out" during the formatting, what precise message
    do you get?
    4. Are you reasonably certain that both the HD and the USB enclosure are not
    defective? Did you use the WD diagnostic utility to check out the HD? (BTW,
    BAR's statement that "once Windows has completed the partitioning of a disk,
    it cannot undo that work." is not correct. You can easily delete a partition
    using XP's Disk Management utility).
    5. Assuming you can remove the HD from its USB enclosure... Can you install
    it in the computer as an internal drive and try formatting it that way?
    6. Assuming your HD and your USB enclosure are not defective, there should
    be no reason why you cannot partition/format that drive using XP's Disk
    Management utility.
    7. If all else fails, i.e., your HD and USB enclosure are not defective, but
    you're still unable to format the drive either externally or internally
    using the DM utility, you could try formatting the drive in FAT32 while you
    have it internally connected. You will, of course, need a DOS bootup disk,
    e.g., a Windows 9x/Me Startup Disk, in order to invoke the FDISK/FORMAT
    commands on that bootup disk. Should that prove successful you could then
    convert the FAT32 file system to NTFS if you desire, although that's not
    particularly necessary for a USB EHD. And then, of course, reinstall the
    drive in its USB enclosure.
    I mention the above course of action, because we've run into a couple of
    situations where (for some unexplained reason(s)) we were unable to format a
    USB EHD where we knew both the drive & enclosure were not defective, and we
    had to resort to a FAT32 format (using a DOS bootable floppy disk) while the
    drive was connected internally. It's a rare occurrence in my experience, but
    we did run into it on at least two occasions as I recall.
    Anna
  3. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    > Windows
    Rubbish
    > format.
    Rubbish
    Rubbish
    Rubbish
    >> running
    >> it
    >> is
    >> default sectors.
    >> Jim
  4. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Yes it is installed in a external case
    Yesd to using the disk management software
    > to format the USB EHD? And when the formatting failed, did you try at
    > least once or twice more?
    I will have to try it again and will write it down
    > message do you get?
    Well the enclosure seems to be fine the HD I just recieved as a replacement
    from Western Digital
    > not defective? Did you use the WD diagnostic utility to check out the HD?
    > (BTW, BAR's statement that "once Windows has completed the partitioning of
    > a disk, it cannot undo that work." is not correct. You can easily delete a
    > partition using XP's Disk Management utility).
    I can try this yes.
    > install it in the computer as an internal drive and try formatting it that
    > way?
    > Management utility.
    Thanks for the info
    Jim Clark
  5. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    "Jim Clark" <clark5080@att.net> wrote in message
    news:Fbj0e.442758$w62.363994@bgtnsc05-news.ops.worldnet.att.net...
    >> drive enclosure, i.e., it's not a sealed unit that you purchased. So that
    >> the drive can be easily removed from the enclosure.
    >> message do you get?
    > replacement from Western Digital
    >> of a disk, it cannot undo that work." is not correct. You can easily
    >> delete a partition using XP's Disk Management utility).
    > I can try this yes.
    >> that way?
    >> should be no reason why you cannot partition/format that drive using XP's
    >> Disk Management utility.
    > Thanks for the info
    > Jim Clark
    Jim:
    I notice in your most recent posting you say that "the HD I just recieved as
    a replacement from Western Digital". Is that the same 60 GB drive you were
    having problems with, or is this a new drive to replace the one you were
    having problems with? If it's a new one, does the same problem still exist?
    Here are the detailed steps to partition & format a USB external hard drive
    using XP's Disk Management utility. In this scenario, the drive had been
    previously partitioned...
    1. In Disk Management, right-click on the external hard drive's drive
    letter in the upper pane and click on "Delete Partition".
    2. A message will appear "...All data on the partition will be lost. Are
    you sure you want to delete this partition?" Click Yes.
    3. The partition will be immediately deleted. The external drive capacity
    will reflect the disk's capacity as "Unallocated".
    4. Right-click on the unallocated region and click "New Partition".
    5. The "New Partition Wizard" will open. Click Next.
    6. Select the Primary partition option and click Next.
    7. In the "Specify Partition Size" window that opens, specify the size of
    the first partition you wish to create. For example, if you want your first
    partition to have a size of 40 GB, enter 40000 MB in the "Partition size in
    MB" box. If you desire only a single partition encompassing the full
    capacity of the disk, enter the appropriate number of MBs. Click Next.
    8. In the "Assign Drive Letter..." window that opens, assign a drive letter
    to the partition you are about to create. Click Next.
    9. The "Format Partition" window will open. Select desired options and
    click Next.
    10. Review your settings in the next window and if OK, click Finish.
    11. The Disk Management window will open, indicating the partition you have
    created is being formatted. After the formatting has been completed, the
    bottom pane will reflect the partition size and the "Unallocated" space (if
    any)
    remaining on the drive.
    12. Repeat the process from step 4. for each additional partition you wish
    to create, (again, assuming you're multi-partitioning the drive).
    13. Reboot the computer and verify that your external drive has been
    partitioned and formatted correctly and is recognized in the system.
    Try it again and let's see what happens. Make sure your USB cable is
    securely connected to the USB enclosure and to the computer's USB port
    (*not* a USB hub).
    Anna
  6. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Ok I tried the WD (Western Digital) utilities and deleted the partition that
    the XP management installed then let the WD utilities add new partition and
    let WD format the USB drive. The format goes very quickly and then Windows
    wants to format the drive when you try to access it. I let XP format the
    drive and it gets to 100% done then the Logical Disk Manager window comes up
    and says this "Format did not complete successfully"
    Jim
    news:Ik20e.438654$w62.29358@bgtnsc05-news.ops.worldnet.att.net...
    > and then it errors out and you get the format failed. Any suggestions? The
    > hard drive is a western digital 60 gig that I just got as a replacement
    > for a failed drive. I set the partition to a primary one and tried the
    > Jim
  7. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Jim, check the jumper on the drive. It should be set to Master/Single
    drive. If you have it set to Master with slave, you will get this error
    most times.
    news:hsk0e.1142$cg1.244@bgtnsc04-news.ops.worldnet.att.net...
    > that the XP management installed then let the WD utilities add new
    > partition and let WD format the USB drive. The format goes very quickly
    > and then Windows wants to format the drive when you try to access it. I
    > let XP format the drive and it gets to 100% done then the Logical Disk
    > Manager window comes up and says this "Format did not complete
    > successfully"
    > Jim
    >> Jim
  8. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    >> successfully"
    >> Jim
    >>> done and then it errors out and you get the format failed. Any
    >>> suggestions? The hard drive is a western digital 60 gig that I just got
    >>> as a replacement for a failed drive. I set the partition to a primary
    >>> one and tried the format to NTSF default sectors.
    >>> Jim
    "LVTravel" <trash@dd.com> wrote in message
    news:1143nr3t2tbdpc7@corp.supernews.com...
    > most times.
    No you won't. At least based upon my experience working with a fairly large
    number of USB external hard drives. Jumper position is irrelevant in the
    case of USB EHDs. You can jumper the EHD any which way or even jumperless.
    As long as it's connected as a USB device the system will recognize it
    regardless of jumper position. This is true for Western Digital drives that
    have the Single jumper setting as well.
    Anna
    Anna
  9. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    I downloaded western digital diagnostic software and in the test the drive
    failed. It had a bunch of bad sectors so WD is sending me another drive.
    Thanks to all for the help Especially Anna
    Jim Clark
    "Anna" <myname@myisp.net> wrote in message
    news:u2tFdv$LFHA.2736@TK2MSFTNGP09.phx.gbl...
    >>> successfully"
    >>> Jim
    >>>> it but have been unsuccessful in formatting it will get to almost being
    >>>> Jim
    >> most times.
    > large number of USB external hard drives. Jumper position is irrelevant in
    > the case of USB EHDs. You can jumper the EHD any which way or even
    > jumperless. As long as it's connected as a USB device the system will
    > recognize it regardless of jumper position. This is true for Western
    > Digital drives that have the Single jumper setting as well.
    > Anna
    > Anna
  10. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Just tried your suggestion on aWD 80 GB. Had set in an USB enclosure and
    was working fine. Changed jumper from Master/Single to removing the jumper
    and the drive stopped working. Change it back and worked again!
    >>> successfully"
    >>> Jim
    >>>> Jim
    >> most times.
    > Anna
    > Anna
  11. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    >>>> successfully"
    >>>> Jim
    >>>>> being done and then it errors out and you get the format failed. Any
    >>>>> got as a replacement for a failed drive. I set the partition to a
    >>>>> primary one and tried the format to NTSF default sectors.
    >>>>> Jim
    >>> most times.
    >> in the case of USB EHDs. You can jumper the EHD any which way or even
    >> Anna
    news:1145rnl3kdv66ce@corp.supernews.com...
    > jumper > and the drive stopped working. Change it back and worked again!
    LVTravel...
    I really can't explain your experience. All I can tell you is that I've
    worked with dozens of HDs, including the WD ones, installed as USB external
    hard drives in a variety of USB external HD enclosures, and I have *never*
    experienced a drive recognition problem due to jumpering the drive in any
    position, or for that matter, not jumpering the drive at all. I've spoken
    with my colleagues about this - they've installed & serviced hundreds of USB
    EHDs - and they tell me their experience parallels mine. But it *did* happen
    to you, so proceed based upon your own experience and ignore my comments.
    Needless to say, in any event, the jumpering of the OP's USB EHD is *not*
    his problem in this case.
    Anna
  12. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    news:%233MgyEKMFHA.1172@TK2MSFTNGP12.phx.gbl...
    >>>>> partition that the XP management installed then let the WD utilities
    >>>>> add new partition and let WD format the USB drive. The format goes
    >>>>> very quickly and then Windows wants to format the drive when you try
    >>>>> to access it. I let XP format the drive and it gets to 100% done then
    >>>>> the Logical Disk Manager window comes up and says this "Format did not
    >>>>> Jim
    >>>>>> Jim
    >>>> error most times.
    >>> Anna
    > LVTravel...
    > external hard drives in a variety of USB external HD enclosures, and I
    > have *never* experienced a drive recognition problem due to jumpering the
    > drive in any position, or for that matter, not jumpering the drive at
    > all. I've spoken with my colleagues about this - they've installed &
    > serviced hundreds of USB EHDs - and they tell me their experience
    > parallels mine. But it *did* happen to you, so proceed based upon your own
    > Anna
    Absolutely agree with both of your last statements. It seems that not all
    USB enclosures treat HDDs the same. I don't know what electronics are in
    the various enclosure devices that recognize the drive's particulars but it
    does have to access and control the onboard electronics some way.
    Apparently the different controllers work differently. My enclosure is a 2
    year old no-name 5.25" one that only has USB2.0 written on it and it will
    work with both CD/DVDs drives and also 3.5" HDDs. This may be the reason.
    It wouldn't take a CD-RW drive either until I put the M/S jumper to Master.
    Just a shame that his "that I just got as a replacement" drive was a dud.
    It does happen.
  13. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Different USB 2.0 external enclosure kits have different bridge
    chipset/device controllers - and sometimes the USB 2.0 host controllers
    can be troublesome to boot:
    '*USB 2.0 HDD/GHOST 2003: Building a bridge...*'
    (http://tinyurl.com/5seq6)
    *-El Pescador-*
    El Pescador
    El Pescador's Profile: http://forum.osnn.net/member.php?userid=8322
    View this thread: http://forum.osnn.net/showthread.php?t=63898
Hard Drives Format Windows XP
