Archived from groups: microsoft.public.windowsxp.hardware (
More info?)
OK listen, in safe mode you will go and delete the display driver from the
device manager.
That will make XP reload it on its default settings when you restart.
Tell me if this helps
Kenny
"jgvp" <jgvp@cogeco.ca> wrote in message news:BE6E5CDB.5D6%jgvp@cogeco.ca...
> Before I received all your responses, and I want to thank you all for your
> responses, I did try three different approaches with the F8 key: Safe
> Mode,
> VGA Mode, and the Last normal boot up (sic), but the problem was that they
> didn't work for one reason or another. Safe Mode, and VGA Mode don't
> present
> you with the ATI Control Panel, and the Latest normal.... (?) just didn't
> work at all since I had tried to reboot many times in the interim.
> It seems, to me at least, that I will never be presented with the ability
> to reverse the settings in the ATI Control Panel until I can at least
> access
> the ATI CP again. Is it possible to download the ATI CP in Safe Mode ?
> Failing that, it looks like yet another Recovery process only this time
> without any opportunity to backup my files.
> in article u6dLZx9MFHA.3928@TK2MSFTNGP09.phx.gbl, Kenny S at
> hotmail@coldmail.com wrote on 3/28/05 4:19 PM:
>> you must boot into safe mode by pressing the F8 key right after the first
>> bios screen,
>> and then lower the resolution and refresh rate.
>> If you do not want this to happen again, you must find the drivers for
>> your
>> screen,
>> that will tell XP what resolutions/refresh rates it is capable of.
>> Kenny
>> news:BE6DDD7A.258%jgvp@cogeco.ca...
>>> I just inadvertently changed one of the settings (ATI Utilities) and the
>>> screen suddenly went blank and I have been unable to get the video back
>>> after many reboots. I can't figure out how you can do anything with a PC
>>> if
>>> you're unable to see anything on your monitor. Any help would certainly
>>> be
>>> appreciated. In case you're wondering, I'm using my Mac right now.
