Archived from groups: comp.periphs.printers (More info?)
Hi
My needs are a printer that will turn out good quality A4 sized documents
most with colour photos on the front, some with colour photos both sides but
manual duplexing is OK as I am looking at the budget end of the options.
Around £500.
My major problem is that at 5.00 pm each weekday I am made aware of how many
copies each of varying files are required to be posted off with the post
time no later than 6.00 pm. So one hour and I find the number each day
varies considerably. Could be as low as 6 differing docs varying from 1 copy
to 6 copies. Could be higher at 20 different docs varying from 1 but up to
10 copies.
My concern is how long and labour intensive will be the printing.
I have been using an outside printer but with a minimum run of 10 copies and
24 hours notice required it is becoming a problem.
Heeelp!
Phil
Hi
Around £500.
10 copies.
Heeelp!
Phil
