G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.shuttle (More info?)
Hi all, I'm having a problem with my mb and was wondering if anyone
else has ran into similar with this one.
Ok, here is my setup,
an35-400 mb
512 mb ddr 400 mhz ram
wd 80 gb, and wd 160 gb hd (160 is master)
amd 2600+ cpu
dvd and cd rw drives
xp home edition
When I got the first mb everything was fine for about a month or so,
then I noticed it was getting slow booting up, would stay at the post
screen for a while, and then would finaly boot. After a few weeks,
suddenly it wouldn't boot at all, settings would default to factory
(100 mhz bus speed, etc...), but if I went into bios settings (which
took several minutes to bring up the menu) it would reload my
settings. Once I got past this point, the system would pause for
several min and would not finish loading windows (said my boot disk
wasn't a system disk). As if this all wasn't strange enough, if I put
my xp install disk in, it would pass where it asked if I wanted to
boot from cd, if I left it alone, it would boot normally. Now dsl
connection is going flaky. the same time that it started having
trouble booting, my connection speed reported by the built in network
card dropped from 100 to 28.8. even if I connect to my small network
in my house, it still says 28.8 instead of 100. My router and all
network cards are all 100 base.
I had the same problems with the first card, and returned it to the
shop I bought it, installed the new card and it worked fine for about
a month and a half, and now it has the same exact problems. I have all
the latest bios, drivers, and updates, but can't see that it makes any
difference.
Did I just get 2 bad motherboards, or is there something I'm missing?
Paul
an35-400 mb
amd 2600+ cpu
xp home edition
difference.
Paul
