Tom's Hardware > Forum > Wireless Networking > Wireless General Discussions > Linksys WRT54G WPA-PSK connection problem
Forum Wireless Networking : Wireless General Discussions - Linksys WRT54G WPA-PSK connection problem
Archived from groups: microsoft.public.windows.networking.wireless (More info?)
I am trying to change my wireless security over to WPA-PSK with TKIP without
success. Here are my specs:
Router: Linksys WRT54G (w/ latest firmware)
Wireless Card: Dell Wireless 1350 WLAN Mini-PCI Card (w/ latest drivers)
OS: Windows XP Professional SP2
I have changed the security model on the router to be WPA-PSK with TKIP, but
when I configure my laptop and enter the key, it seems to hang with the
"Acquiring network address" message.
I am able to connect using WEP 128-bit, so Linksys help believes that it is
a problem in compatibility with SP2. I have tried changing channels without
success and the firmware and driver updates did nothing either.
Any help would be greatly appreciated
Sponsored Links
I have the same problem.The problem with me that i have the wep and wpa.
I disamble the wep key and 'restart' the router (power off and on) and
connect the laptop with the wpa key and its works.
Reply to Anonymous
Hi Gerard,
Can you explain a bit more about how you are disabling the WEP key? I tried
repeatedly to delete the "preferred connection" (with either WEP or WPA as
the security model), restart the router (and the laptop), and then reconnect
using the WPA key.
No luck so far.
Reply to Anonymous
I mean on the router i disamble the wep key and only use the wpa-psk /tkip
config.
I have the same ssid name
"grovduck" wrote:
> Hi Gerard,
> using the WPA key.
> No luck so far.
Reply to Anonymous
Hmmm, I've tried this as well but it hasn't worked for me. Thanks for your
help, though.
> config.
> "grovduck" wrote:
> > Hi Gerard,
> > using the WPA key.
> > No luck so far.
Reply to Anonymous
Try this:
- Go to your router's web interface site
- Select the setting to WPA-PSK (under wireless tab).
Set it with a password. Click save.
- Go to Control Panel, click Wireless Network Setup
- Select "Setup a new wireless..."
- Follow the setup step-by-step.
- Just make sure though, you're putting the same SSID
as what you have in your router's web interface site.
- Also, select Manual for the password. THis way, you
would have to put the same password as what you have in
the router's web.
- I recommend having a portable drive when you set this
up, that way, all you have to do is connect your pen
drive to whatever computer you want it wirelessly.
Goodluck!
>-----Original Message-----
me. Thanks for your
>help, though.
>> config.
>> "grovduck" wrote:
>> > Hi Gerard,
>> > using the WPA key.
>> > No luck so far.
Reply to Anonymous
Gal,
Thanks for the feedback. I'll give it a shot tonight. I hadn't tried using
this wizard before ... maybe it's the magic ticket!
"gal" wrote:
> Try this:
> the router's web.
> Goodluck!
> me. Thanks for your
> >help, though.
> >> config.
> >> "grovduck" wrote:
> >> > Hi Gerard,
> >> > using the WPA key.
> >> > No luck so far.
Reply to Anonymous
When I went from WEP to WPA-PSK I had the same problem. The cure for me was
to go the router's Wireless Advanced Settings page and change
"Authentication Type" back to the default value of "Auto." For some reason,
"Shared Key" does not work with WPA-PSK ..... go figure.
"grovduck" <grovduck@discussions.microsoft.com> wrote in message
news:1F027B58-BF2E-4B7A-B7BF-1C4552BD5634@microsoft.com...
> Gal,
> using
> "gal" wrote:
>> Try this:
>> the router's web.
>> Goodluck!
>> me. Thanks for your
>> >help, though.
>> >> config.
>> >> "grovduck" wrote:
>> >> > Hi Gerard,
>> >> > using the WPA key.
>> >> > No luck so far.
Reply to Anonymous
Shared key authentication is a WEP specific feature and is not utilized for
WPA secured connections.
Jerry Peterson
Windows Network Services - Wireless
This posting is provided "AS IS" with no warranties, and confers no rights.
"Gary De Feyter" <someguy@earthlink.net> wrote in message
news:O0%23GRBPNFHA.3328@TK2MSFTNGP14.phx.gbl...
> was to go the router's Wireless Advanced Settings page and change
> reason, "Shared Key" does not work with WPA-PSK ..... go figure.
>> Gal,
>> using
>> "gal" wrote:
>>> Try this:
>>> the router's web.
>>> Goodluck!
>>> me. Thanks for your
>>> >help, though.
>>> >> config.
>>> >> "grovduck" wrote:
>>> >> > Hi Gerard,
>>> >> > using the WPA key.
>>> >> > No luck so far.
Reply to Anonymous
Dear grovduck take a look at this meaby its help you
http://msdn.microsoft.com/library/ [...] fe.xml.asp
Reply to Anonymous
There are 1307 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
