Archived from groups: alt.comp.periphs.mainboard.shuttle (
More info?)
Hi MHz,
This is my son's system. The problems are intermittent in nature. That is
that the light on the mouse will go out for a second or two, and the mouse
will not respond. It does not require a reboot to get the mouse back, it
comes back by itself. Other than the video card, we have a D-Link NIC card
and an Adaptec DuoConnect IEEE/USB2.0 card installed. The D-Link has been
since we built the system in 2002, the Adaptec card has been installed since
12/2003. I will look at the bios first, not sure what version is in there.
I will get back with a follow-up.
Thanks
Tony
Tony Marsillo
Nutmeg Repair
"MHz Tweaker" <Clint@Smith&Wesson.com> wrote in message
news:8d1jf0p927984drcg8kskpm9bs3e5avsn8@4ax.com...
> On Fri, 16 Jul 2004 17:16:19 -0400, "Tony Marsillo"
> <tonymar@optonline.net> wrote:
> >I've had this MB since 4/15/2002, and it has been working fine. Recently
the
> >PS2 mouse has started acting up intermittently. It will sometimes not
work
> >for a short time, it is an Intellimouse optical 1.1. I have tried a
> >different mouse with the same problem. I have also tried the mouse in the
> >USB port with the same problem. I have removed the MB and inspected the
> >connections and solder joints around the PS2 connector and did not find
any
> >problems. I have tried to call Shuttle tech support but was on hole too
> >long. My question is what is Shuttles warranty? If not under warranty is
> >worth sending back to Shuttle or just get a new MB. Any thoughts on the
> >cause of the problem.
> >Thanks
> >Tony
> Hi Tony
> I just bought a used AK35-GTRaid a few weeks ago for $20 and love it
> so far.
> Was wondering, does the mouse just stop responding while you are using
> it? or does it not work when you reboot or cold boot?
> Also will a cold boot ever fix the problem?
> What I am thinking is that it could be one of a few things. You could
> have motherboard hardware going bad or it could be related to the way
> resources are being assigned to either the USB or PS/2 ports.
> Do you have lot's of add-in cards that share interupts? Check to BIOS
> settings to see by chance it resources are assigned automatically or
> manually. Also, if you use windows check the device manager to see if
> there are any conflicts with with IRQ12 or the USB ports.
> I don't know if this is your main system but I would try to narrow it
> down but doing a clean install of your choice O/S with the board using
> just a Vid card and single drive.
> I don't know what PCB version you have of the board, but I think I
> have like ver 1.2 and I use BIOS version AK35s00m with good results.
> This is the latest I could find on the www.spacewalker.com web site
> for my PCB revision. You will have to go into their Archives to find
> what you are looking for I think.
> If you are manually allocating resources, you may try letting the BIOS
> assign them. If all else fails, flash the BIOS to the latest version
> and then load system defaults after rebooting from the BIOS menu.
> I believe once you have narrowed it down that no other hardware could
> be conflicting you should look at possibly having a bad board. I have
> not dealt with shuttle directly, so I don't know how their tech
> support is or what terms they can RMA your board under.
> I hope this helps
> MHz
