G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.shuttle (More info?)
I'm having problems building an SB51G system. Right now when I plug
in just the CPU and memory, I get nothing on the VGA port, though the
blue light on the front comes on and the cpu fans spin. If I plug in
a DVD and HD, I get the same symptoms, though the DVD light will come
on and the disk will spin, and it appears that the HD is spinning. HD
and DVD work on an old PC.
I already RMA'd the CPU once thinking that was the problem.
I've tried different memory sticks, but I don't have another CPU to
try. One web site suggested powering up with the cpu in, but without
the heat sink and fan, to see if the CPU gets hot. The site said if
it doesn't get hot, something is wrong. Well, mine didn't get hot, so
I guess something is wrong, but I'd be surprised if I really received
2 bad cpu's.
Thanks,
Sean
sysinfo
sb51g barebones system
intel celeron d, 478, 2.66 Ghz, 533 Mhz FSB, 256KB L2 cache
memory: have tied both kingston 512 MB and hynix 512 MB
2 bad cpu's.
Thanks,
Sean
sysinfo
