Tom's Hardware > Forum > Motherboards & Memory > Shuttle > speed of sata through pci card?
Forum Motherboards & Memory : Shuttle - speed of sata through pci card?
Archived from groups: alt.comp.periphs.mainboard.shuttle (More info?)
I have an AN35N ultra. I need to add a HD. My choices seem to be:
ATA100 (another Seagate)
ATA133 (something) (there seem to be fewer of these - mostly Maxtor)
SATA drive connected to a pci adapter card.
My question is: since the sata is connected to a pci card, and I believe
the pci only runs at 66, it seems as though the sata would at best do 66.
Yes? So it would be slower than an ATA100 EIDE, yes?
(It will probably be a year or so before I upgrade the mobo to one with
sata ports)
thoughts?
tia!!
Kristi
Shuttle AN35N Ultra, XP2600Bart, 512mb, GeF4Ti4200, WinXP Pro SP2
Sponsored Links
>sata ports)
PCI is 133 MB/sek, but this is shared between the PCI-devices. But in
general, with a standard setup (no RAID, and not any other extremly
demanding PCI-deviced) there will not really be a performancehit if
you use a PCI Serial ATA-card compared to have a integrated Serial
ATA-controler in the chipset.
For normal use, the throughput for the harddrive ain't too many
MBytes/sec. Even on the fastes part of the drive (the start) and a
sequencial read, the max. for new drives are often not more than 60
MB/sek -- but this is not really with real usage.
Take a look at this image:
http://www.pconline.com.cn/pchardw [...] ach_lg.png
As you can see the max for this drive, which is one of the fastest on
the market, is about 60 MB/sek in the start -- the average is down to
about 50 MB/sek.
Clas Mehus
Dataguiden : http://www.pcworld.no/dataguiden/
"Den som har flest prylar när han dör vinner..."
Reply to Anonymous
66? Mine runs at 33! 32 bits, though, which is four bytes. Theoretical
maximum is 130 some MB/s, but closer to 110 or 112 in real life, I heard.
In my book, ATA100 is plenty close for that occasional buffer burst.
SATA cards are pretty expensive-- $40, I think. I don't see any
advantage to SATA on that board, unless you were getting a Raptor.
If you don't have anywhere to plug your new drive, you can get an oem
Promise TX2 (ATA100) for about $27 shipped (cnetpc.com, Newegg).
I've seen them go for less than $20 shipped on eBay. My retail
WD1600JB came with a TX2, but I don't think the new FDB ones do.
Reply to Anonymous
>>sata ports)
> about 50 MB/sek.
Thanks!
I have a Seagate 40GB and a Maxtor 20GB - both 7200rpm and ATA100. HDtach3
says:
Seagate 40mbs down to about 25mbs with 59 burst
Maxtor 30mbs down to 20mbs with burst 35.2
So it looks like going with a SATA pci card and SATA drive would
dramatically increase the burst speed and possibly somewhat increase the
Sequential read speed. Whereas getting an ATA100 or ATA133 would result
in about the same performance I now have. Yes?
tia
Kristi
Reply to Anonymous
Yes, I think that is right - 33mhz x 4bytes = 132mBs
SATA card cost - I just looked at newegg and found a LinkDepot for $22+$4
(good manual, but devoted mostly to RAID which I have no use for) it has a
silicon image chipset which I think might be good. There is a Kingwin for
19+5 that also looks very interesting and comes with good instructions.
I have had such bad experience with Promise and its drivers that I will
avoid them and look for something that will allow me to boot from an
attached sata drive.
It appears that while a sata pci plus a sata drive won't increase average
mBs, it will greatly increase burst rate...
Raptor... now that's an idea - but too expensive and I had bad luck with
WD and such good luck with Seagate. Maxtor is good, too, but Seagate is
faster...
Kristi
Reply to Anonymous
They've come down since last I looked!
Had no problem with my TX2, but downloaded the latest drivers and firmware
before using...
I hadn't heard that about the burst rate. I see some new Maxtors have 16MB
buffers...
> faster...
I RMA'd my noisy WD 160GB and it was painlessly replaced in a week. They
did get some points for that!
Reply to Anonymous
:o)))
> before using...
good to hear, but I'll pass...
> buffers...
the cheapest one newegg has is $243. If the low end Maxtors had 8mb that
would be a possibility. Right now the best for me seems to be a seagate
with 8mb, 80gb, for $73+1 (why is newegg doing this silly stuff with their
shipping rates???) But I will wait a bit before I go for it.
>> faster...
Great to hear - I know they sell a lot of HDs and they really should give
great cust support. I soured on them back several years ago when they
wouldn't support a HD on XP. Maxtor, on the other hand was quickly
swapping bad drives.
Kristi
Reply to Anonymous
There are 631 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
