Solved
Offline printer problem
My Internet access stopped and when it got fixed, my printer went offline. How do i fix this problem?
7 answers Last reply Best Answer
More about offline printer problem
  1. Is the printer a network printer (wireless) or connected via USB?
  2. Wireless
    Thanks for your response. It is wireless.
  4. Best answer
    Make and model?
    The easiest way for you may be to uninstall the printer, then re-install it. I'm assuming it walked you through the wireless setup and that would be far easier than me giving you a step-by-step on how to do it manually.
  5. Cmon man, go to Add Printer....
  6. Best answer selected by tgreaves3064.
  7. Thanks. Before I could do anything it came on by itself as it had done a month before. I wonder if it connected to the fact that all of the telephones in my house that has VOIP, stopped working with the exception of one that has since stopped working.
Internet Access Printers Windows 7
