Tom's Hardware > Forum > Wireless Networking > Wireless General Discussions > wireless card does not pick up signal
Forum Wireless Networking : Wireless General Discussions - wireless card does not pick up signal
Archived from groups: microsoft.public.windows.networking.wireless (More info?)
HI,
For some reason, my laptop, which came with a broadcom wireless card
installed, cannot pick up a fairly strong signal at my work (a local coffee
shop). This is the only wireless network I have tried (wired at home), and I
have never used wireless before. The coffee shop's network is fine; my friend
and a few others have used it with excellent connectivity. What could be my
problem? The card is enabled in device manager, but it doesn't pick any
signal up. Thanks.
Sponsored Links
Jon wrote:
> HI,
> coffee shop). This is the only wireless network I have tried (wired at
> home), and I have never used wireless before. The coffee shop's
> network is fine; my friend and a few others have used it with
> excellent connectivity. What could be my problem? The card is enabled
> in device manager, but it doesn't pick any signal up. Thanks.
Do you get absolutely no response or is there an error message? If the
former, then forgive me for asking but is your wireless turned on? Many
newer laptops have a button or switch that must be turned on to enable
the wireless.
Malke
MS MVP - Windows Shell/User
www.elephantboycomputers.com
In Memoriam - MVP Alex Nichol
The world is diminished without him.
Reply to Malke
On Wed, 30 Mar 2005 11:23:04 -0800, Jon wrote:
> HI,
> signal up. Thanks.
My laptop (Toshiba) has a built in wireless card AND a manual switch to
turn on the wireless.
Reply to Anonymous
OK, well I am not sure if I have a switch or not, I have a an emachines
m5310. No, I don't get an error message.
> > HI,
> > signal up. Thanks.
Reply to Jon
I don't know if I have a switch or not. I have an emachines m5310. No, I did
not recieve an error message.
> > HI,
> > signal up. Thanks.
Reply to Jon
> I did not recieve an error message.
>> > HI,
>> > card installed, cannot pick up a fairly strong signal at my work (a
>> > local coffee shop). This is the only wireless network I have tried
>> > (wired at home), and I have never used wireless before. The coffee
>> > shop's network is fine; my friend and a few others have used it
>> > with excellent connectivity. What could be my problem? The card is
>> > enabled in device manager, but it doesn't pick any signal up.
>> > Thanks.
>> to turn on the wireless.
Look in your laptop's manual and/or examine your laptop carefully to see
if you have a switch or a button. You might even have to use one of the
FN keys. The laptop came with a manual or check with eMachines tech
support regarding your laptop's configuration.
Malke
Reply to Malke
There are 511 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
