Tom's Hardware Forums » Motherboards & Memory » Shuttle » AN35N Ultra & XP 3200+ Problem
Word :   Username :
Bottom
Author
 Thread : AN35N Ultra & XP 3200+ Problem
More Information
Archived from groups: alt.comp.periphs.mainboard.shuttle (More info?)
I just bought an Athlon XP 3200+ for my AN35N Ultra MB. It is an
upgrade from an XP 2700+.
Shuttle AN35N Ultra
2x 512MB Corsair Value RAM PC3200.
450W Cooler Master PSU
Thermalright SLK800U HS (w/ Arctic Silver) & Panaflow fan.
I have set the FSB to 200 & everything else to "optimal"...No
overclocking
Temps are OK
When booting I get an error screen Machine_Check_Exception, STOP
0x0000009C just before the desktop appears.
I can't get any further. I get better luck booting when I set the FSB
to 190 or 192. If I try 199 or 200 the BSOD comes back.
I put the XP 2700+ back in & it works fine!
What could be causing this? Should I update the BIOS? Current BIOS
is from 12/2003.
Related Product
More Information
The latest bios update is 9/10/2004. I would put the XP 2700+ back in and
update the bios. REinstall the 3200 and everything should work.
http://global.shuttle.com/Download [...] AN35/N-400
"Big Fan" <help@mail.com> wrote in message
news:t7d8s019pii448orpaim8ns7ek5r6h885r@4ax.com...
> Shuttle AN35N Ultra
> overclocking
> Temps are OK
> is from 12/2003.
More Information
I updated the BIOS to the 9/10/04 version...Still get the error at the
200mhz FSB. I am currently running it at 190mhz OK.
I ran MemTest for a couple of hrs w/ 0 errors.
I can't figure this one out? Could the CPU be defective? It's an OEM
one.
On Sat, 18 Dec 2004 14:14:04 GMT, "Paul J. Veres"
>http://global.shuttle.com/Download/Download_File.asp?Item=AN35/N%20Ultra%20&%20AN35/N-400
More Information
I am now running the FSB at 195mhz/388mhz. If I put it up to 200/400
I still get the BSOD error message.
What gives?!
>one.
More Information
> STOP 0x0000009C just before the desktop appears.
http://support.microsoft.com/?kbid=162363
First, I would try increasing the vdimm (voltage to the memory).
I think it goes up to 1.7v. Try setting it at that.
It is possible that you could have a board like mi- my sister's.
It would only do 200 MHz with CPU Interface set to aggressive
with the memory in single channel mode. That would be in dimm
slots 1 and 2, I believe. Well, that's if you have two sticks of
memory.
I found the memory bandwidth to be far greater in single channel
mode with CPU Interface set to aggressive than in dual channel
mode, at a lower FSB, or in dual channel with CPU Interface
set to optimal.
Profile: stranger
More Information
Ahhh....
Someone with 'exactly' the same problem I am having.
I have a Shuttle AN35N Ultra board and just bought a Athlon XP 3200.
I get exactly the same errors.
What I have found is that you can not run the system using the 11x
multiplier with a 400 FSB.
10.5x and 400 works fine.
I contacted Shuttle and they basically blew me off. They wanted me to
return the board. The board has been operating fine for a year now. I
simple think this board was never designed to operate with a 400MHz FSB
3200.
If anyone has got a XP 3200 400FSB to work on this board, I would love to
know how you did it.
It's not the CPU, this is a board problem
Mike
news:2739s0914mg1n6jmdrkimrntqaru2ci8qb@4ax.com...
> What gives?!
>>one.
>>>and
More Information
Thanks for your help. Tried what u suggested & it's running OK at
x10.5/200/400 fsb. It's now an XP 3000+ running at 2.10 GHZ,
according to my PC.
Which is better...2.2GHZ at 190/378 fsb or 2.1GHZ at 200/400 fsb?
This is so frustrating!
On Sat, 18 Dec 2004 23:07:18 -0600, "Mike" <msbenn67@hotmail.com>
wrote:
>Ahhh....
>3200.
>Mike
>>>one.
>>>>and
More Information
You should make a bootable floppy or CD with Memtest86
or the newer variant Memtest86+ and make sure you are not
getting memory errors. And do try increasing vdimm. I see
now that you have 2 x 512MB Corsair Value Ram. I see that
the single sticks are spec'd to run at cl=2.5 and the dual kit it
spec'd to run at cl=3. If the board is setting them both to 2.5,
you might try them at 3. If you are using dimm slots 1 and 3,
try 2 and three, or vice versa. You might also try bumping-up
the voltage to the CPU a notch, to see if that helps. I had t
bump the voltage up to 1.675v. to get the XP2500+ Prime 95
stable at 200MHz, whereas it ran fine in an Abit NF7-S at
1.65v, and that board under-volted a little. It's nice when
everything works together out of the box, but apparently it
didn't this time.
Profile: stranger
More Information
In my opinion, a 400MHz FSB is more valuable than an extra 100MHz CPU.
The bus speed touches all aspects of your systems. You'll never notice a
CPU bump from 2100 to 2200 Mhz which is only ~5%.
If you ever find a way to make the Shuttle board work for the 3200, please
let me know. I'll do the same.
Good luck,
Mike
news:691bs01915p4gqud9qh7tvucoo31h8p67h@4ax.com...
> according to my PC.
> wrote:
>>Ahhh....
>>3200.
>>Mike
>>>>one.
>>>>>and
More Information
Big Fan wrote:
> My CPU/MB hates the multiplier to be set at x11. x10.5 works
> great. I'm going to call Shuttle tomorrow & see what they say.
So- did *anyone* try single channel yet? I got 3 GB/s of memory
bandwidth out of that thing, which is way more than you are going
to get setting CPU Interface to Optimal in dual channel...
More Information
I'm going to RMA this CPU back to GameVE.com. I took a closer look at
the CPU core & there appears to be a small chip/pit on one edge. I
don't recall seeing it before.
I'll let you know
On Mon, 20 Dec 2004 06:19:21 -0800, "Fishface" <invalid@ddress.ok?>
Profile: stranger
More Information
Yes, I did. Unfortunately, it didn't work either.
I also moved the DIMMS to every possible slot compbination but that didn't
help.
However, I agree that running without the dual channel enabled dose provide
better performance when you use the aggressive timing.
The best I can make of this is that the board really doesn't support this
chip. I've checked a number of boards and haven't found anyone who has had
any success.
Any other ideas?
THanks
MIke
"Fishface" <invalid@ddress.ok?> wrote in message
news:10sdnp2h0h3gn30@corp.supernews.com...
More Information
Mike wrote:
> Any other ideas?
You might check to see if the northbridge chip heatsink is getting very
hot while running Prime95. If not, there may not be good contact. The
chips are generally very concave. Mine was attached with a just little
snot glue in one spot. You pretty much need to pull the board to remove
the heatsink, should you feel that is necessary. And lapping the chip was
sure no picnic. My Abit NF7-S had a huge wad of thermal compound
under the stamped heatsink and noisy fan that failed within months. I
replaced it with a passive Zalman that doesn't make contact with the
entire chip surface and was so concave that I had to sand and lap it.
Next time I will try some other brand of heatsink.
Profile: stranger
More Information
If you had it to do all over, what board would you recommend for an Athlon
3200/400? I'm thinking about replacing the motherboard. I'll use the
Shuttle board to build a Linux sandbox.
I like the nVidia chip set. I need on-board audio and LAN but don't care
too much about RAID.
Thanks,
Mike
news:10sj12ftk25j03e@corp.supernews.com...
> Mike wrote:
>> Any other ideas?
More Information
I only have experience with one of each board, so that hardly makes me
an expert. The only reason I bought the NF7-S is because I felt my $320
investment in memory was wasted on the Shuttle that didn't overclock well
and didn't run dual channel. The NF7-S had a reputation as a good
overclocker, but mine would only do 212 or 213 FSB with CPU Interface
set to "enabled." By disabling it, even at 230 FSB, memory bandwidth was
lower. I do like the idea of a passive northbridge heatsink for quiet and low
maintenance. I'd probably try another NF7-S, but replace the northbridge
heatsink and fan right after bench testing it. It comes with a PATA to
SATA adapter (serillel 2) and SATA cable, plus I use the firewire with a
video camera.
Profile: stranger
More Information
