G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.shuttle (More info?)
I have the SB81P and I have a couple of issues with the audio
functions. I have a 2.1 speaker system with the L/R speakers connected
to the green connector on the rear panel and the sub-woofer connected
to the orange connector. Speakers work fine..... Now, when I plug my
headphones into the green front panel connector, I would like the
external speakers to be muted and the audio directed to the headphones.
That doesn't happen. I have sound on at the headphones, but the
speakers are active as well......
The other issue. I'm using InterVideo WinDVD 6. From that application
I don't have any control over the audio volume. When I use MediaPlayer
or iTunes, I can control the volume just fine......
I just installed the most recent RealTek drivers. No change. Any
ideas?
ideas?
