AN35N Ultra IDE2 Problems
Archived from groups: alt.comp.periphs.mainboard.shuttle (More info?)
I am having some serious problems when it comes to the second IDE
channel on my new Shuttle AN35N Ultra motherboard. I'm an experienced
computer builder, though this is the first shuttle motherboard I've
ever worked with. The problem is that anything I put on the second
IDE channel POSTs properly, but I cannot access it from within the OS
(currently, I have linux installed...but I tried Windows XP for
troubleshooting). For that matter...regardless of which OS I'm in, I
can't even partition a hard drive on the second IDE channel. I might
also add that every device I've tried on IDE2 works fine on the first
IDE channel. If I have a CD-Drive on the second IDE channel, I cannot
boot from the CD.
Here's my current setup:
Motherboard: AN35N Motherboard
CPU: AMD Duron 900mhz
Video: Diamond Viper (Riva TNT 770)
RAM: Kingston 256MB PC 2300 (one chip)
Hard Drives: WD 40Gig (Cable Select, Master, IDE1)
CD-ROM (Cable Select, Slave, IDE1)
Seagate 20Gig (not currently installed...used for testing)
Power Supply: Antec Truepower 450w ATX (has the second square power
connector)
Now as I said, either of those three drives POSTS properly at boot
time -- even on IDE2. I have enabled both IDE channels in BIOS. IDE1
seems to work perfectly (which is why I have the CD-ROM on IDE1 at the
moment, but I want it as master on IDE2). This is the second
motherboard I've tried...the first, also an AN35N Ultra, was returned
because I thought it was a faulty motherboard. But the new
motherboard seems to be acting exactly the same.
I've already posted on other places...but no one seems to have any
thoughts. Does anyone here have any ideas?
--Coplan
8 answers Last reply
More about an35n ultra ide2 problems
  1. Archived from groups: alt.comp.periphs.mainboard.shuttle (More info?)
    No one has any theories?
    > boot from the CD.
    > connector)
    > --Coplan
  2. Archived from groups: alt.comp.periphs.mainboard.shuttle (More info?)
    When I added my 2nd hard drive to my computer, I also installed it to the
    second IDE.
    I had to add this hard drive in the computer management program on
    WinXPHome.
    Control Panel, Performance and Maintainence, Administrative Tools, Computer
    Management, Storage, Disk Management Local
    and then ask for help there or here. ;-)
    You might have to activate your 2nd hard drive.
    Just a newbie here so I am still learning! ;-)
    later,
    dave
    (One out of many daves)
    "Coplan" <coplan@verison[antispam].net> wrote in message
    news:7LhHd.4499$av2.1268@trndny02...
    >> boot from the CD.
    >> connector)
    >> --Coplan
  3. Archived from groups: alt.comp.periphs.mainboard.shuttle (More info?)
    You mean partition it and all?
    The second hard drive actually has Windows XP on it. So I know it works
    fine. I can boot off of it if I set it as MAster on IDE1. But when I
    put it on IDE2, Bios detects it...but I can't access it from the OS.
    The same behavior happens when I put the CD-ROM as master on IDE2. I
    can't boot off of it or anything...and I get read errors when I try to
    access it.
    > second IDE.
    > WinXPHome.
    > later,
    > dave
    > >> boot from the CD.
    > >> connector)
    > >> --Coplan
  4. Archived from groups: alt.comp.periphs.mainboard.shuttle (More info?)
    If you haven't ran "fdisk" & then formatted the drive, Windows will not
    assign a drive letter. This is done with a WIN98 or ME startup disk. Don't
    have a startup disk? You can get one here:
    http://www.bootdisk.com/bootdisk.htm
    news:xXEHd.9267$av2.3790@trndny02...
    > access it.
    >> second IDE.
    >> WinXPHome.
    >> Computer
    >> later,
    >> dave
    >> >> boot from the CD.
    >> >> connector)
    >> >> --Coplan
  5. Archived from groups: alt.comp.periphs.mainboard.shuttle (More info?)
    That's what I'm saying. I've used fdisk (both in linux and in windows)
    but it can't create the table on the drive. I've had three hard drives
    I've tried in that slot, and so long as any of these drives is on IDE2,
    I cannot partition it, format it, write data to it, read data from
    it....nothing. So I know it's the controller itself.
    And yes...I have IDE2 enabled in Bios.
    > > access it.
    > >> second IDE.
    > >> WinXPHome.
    > >> Computer
    > >> later,
    > >> dave
    > >> >> boot from the CD.
    > >> >> connector)
    > >> >> --Coplan
  6. Archived from groups: alt.comp.periphs.mainboard.shuttle (More info?)
    YES you need to have WinXP activate it. Then you could have it as Drive F
    or whatever and your Optical Drives as D and E.
    I could not even see my second hard drive until I went to the disk
    management program of WinXP.
    But again I am a newbie so I might have been very lucky in solving my
    problem. <g>
    later,
    dave
    > access it.
    >> second IDE.
    >> WinXPHome.
    >> Computer
    >> later,
    >> dave
    >> >> boot from the CD.
    >> >> connector)
    >> >> --Coplan
  7. Archived from groups: alt.comp.periphs.mainboard.shuttle (More info?)
    Okay...here's the thing. Regardless of what OS I have...I can get the
    OS to "see" the drive, but I cannot get it to actually be able to
    access the drive. I'm using Linux at the moment, and I get a whole
    bunch of read/write errors and timeout errors.
    Here's some more data. I had a spare PCI IDE controller lying around.
    So I installed that into the machine, and the hard drives all work
    perfectly. That, of course, only stumps me more.
    --Coplan
    Drive F
    > problem. <g>
    > later,
    > dave
    works
    when I
    OS.
    I
    to
    > > access it.
    to the
    > >> second IDE.
    > >> WinXPHome.
    > >> Computer
    > >> later,
    > >> dave
    IDE
    experienced
    I've
    second
    the OS
    in, I
    might
    first
    cannot
    > >> >> boot from the CD.
    power
    > >> >> connector)
    boot
    BIOS. IDE1
    at the
    returned
    any
    > >> >> --Coplan
  8. Archived from groups: alt.comp.periphs.mainboard.shuttle (More info?)
    Under device manager, you will find IDE ATA/ATAPI CONTROLLERS. Highlight
    secondary IDE channel, and under ACTION at the top, click on install if
    available. If it says uninstall instead, try updating the driver.
    "Coplan" <coplan.ic@rcn.com> wrote in message
    news:1106586531.422684.312000@c13g2000cwb.googlegroups.com...
    > --Coplan
    > Drive F
    >> problem. <g>
    >> later,
    >> dave
    > works
    > when I
    > OS.
    > I
    > to
    >> > access it.
    > to the
    >> >> second IDE.
    >> >> WinXPHome.
    >> >> Computer
    >> >> later,
    >> >> dave
    > IDE
    > experienced
    > I've
    > second
    > the OS
    > in, I
    > might
    > first
    > cannot
    >> >> >> boot from the CD.
    > power
    >> >> >> connector)
    > boot
    > BIOS. IDE1
    > at the
    > returned
    > any
    >> >> >> --Coplan
Motherboards
