Solved
Screen resolution problems
Hello,
I have windows 7 and am using Mozilla Firefox. Each time I click on mozilla to get to my hompage the page comes up very large and wont fit the screen. There is no way I can change it ! I have treid via Control Panel but nothing there helps.
If I use IE for my homepage that comes up OK and everything fits the screen.
Can anyone advise what to do to correct this problem please ?
4 answers Last reply Best Answer
More about screen resolution problems
  1. Best answer
    Hi. Hold down the control key and scroll the mouse wheel to the screen size you want
    :na: Thanks very much for your help. I didnt realise it was so simple to correct. I am really grateful because it was driving me "nuts" trying to find solutions on the web.
    Thanks again :na:
  3. Best answer selected by brivel.
  4. You're very welcome Thanks for the vote
Configuration Windows 7 Screen Resolution
