Archived from groups: alt.comp.periphs.mainboard.shuttle (More info?)
I have seen a few similar problems to the one I’m having ponsted on
various boards, but I still really haven’t seen a solution.
I have a Shuttle XPC SN41G2V3, an Athlon XP 3200+, and 1GB of Corsair
ValueSelect PC3200 Dual Channel memory (and, yes, I have an AGP card
so that the memory runs at full speed)
When I first hooked everything up, the system was fine.
However, after a few reboots, the BIOS suddenly decided to report the
processor as an Athlon XP 1100MHz. I went in to the BIOS and the FSB
was set to ’200MHz,’ but the machine was acting as if the FSB was
running at 100MHz. I tried changing the FSB to 100MHz, rebooting, and
then changing it back to 200MHz, but no luck.
So, I unplugged the power cord, hit the clear CMOS button for 5
seconds, and then powered it back up. The BIOS reported Athlon XP
1100MHz again, but this time the FSB was set to 100MHz. I reset it to
200MHz and, voila, I have an Athlon XP 3200+ again.
Problem is, about three reboots later, it does this again. I don’t
want to have to clear my CMOS every other day with this computer. Any
ideas?
I saw one post saying that Corsair memory doesn’t like Shuttle
motherboards. Can anybody confirm this? I might be able to track
down some other memory to try.
I sent an email to Shuttle tech support over a week ago, and they have
yet to reply...I’m starting to think about calling them, though I’m
not looking forward to a lengthy long distance phone call....
"dan2" wrote:
> I have seen a few similar problems to the one I'm having
> ponsted on various boards, but I still really haven't seen a
> solution.
> Corsair ValueSelect PC3200 Dual Channel memory (and, yes, I
> have an AGP card so that the memory runs at full speed)
> report the processor as an Athlon XP 1100MHz. I went in to
> the BIOS and the FSB was set to '200MHz,' but the machine was
> acting as if the FSB was running at 100MHz. I tried changing
> the FSB to 100MHz, rebooting, and then changing it back to
> 5 seconds, and then powered it back up. The BIOS reported
> Athlon XP 1100MHz again, but this time the FSB was set to
> 100MHz. I reset it to 200MHz and, voila, I have an Athlon XP
> 3200+ again.
> don't want to have to clear my CMOS every other day with this
> computer. Any ideas?
> > I saw one post saying that Corsair memory doesn't like Shuttle
> track down some other memory to try.
> they have yet to reply...I'm starting to think about calling
> them, though I'm not looking forward to a lengthy long
Hi Dan2,
Have you found a solution to your problem and has Shuttle replied yet
I have exactly the same problem as you, except that even when reseting
the CMOS I never got this damn SN41G2V3 to recognize my AMD Barton
3200+ as anything else than 1100 MHz CPU.
I really tried everything : flashing with the latest BIOS, increase
the FSB speed gradually up to 300 MHz, changing the multiplier, but no
luck, it always reports 1100 MHz. cpu-z1 report : FSB 100, multiplier
11, bus speed 200 => CPU clock 1100 MHz.
My config is :
- SN41G2V3
- AMD Barton 3200+
- 2 x 1Go PC3200 memory from Corsair
- AGP card ATI Radeon 9600 Pro 256 Mo
- 2 SATA HDD
- 1 DVD burner
- 1 PCI card
I emailed shuttle a few days ago, no reply ... I am desperate ...
"Erik" wrote:
> Hi Dan2,
> replied yet ?
> reseting the CMOS I never got this damn SN41G2V3 to recognize
> my AMD Barton 3200+ as anything else than 1100 MHz CPU.
> increase the FSB speed gradually up to 300 MHz, changing the
> multiplier, but no luck, it always reports 1100 MHz. cpu-z1
> report : FSB 100, multiplier 11, bus speed 200 => CPU clock
> 1100 MHz.
> > My config is :
> - SN41G2V3
> - AMD Barton 3200+
> - 2 SATA HDD
> - 1 DVD burner
> - 1 PCI card
Still waiting on Shuttle to reply. Really terrible response time...
Don’t know what to tell you... If I clear the CMOS on mine, and then
manually set the FSB to 200MHz, it works correctly for a short time.
I have a mobile 2500+ coming next week. Hope I don't have this problem as well. Plan on running it at 3200+
"dan2" <DoNotEmail@HardwareForumz.com> wrote in message news:7_296141_31f963937579b95115872083041765d8@hardwareforumz.com...
> "Erik" wrote:
> > Hi Dan2,
> > replied yet ?
> > 1100 MHz.
> > My config is :
> > - SN41G2V3
> > - AMD Barton 3200+
> > - 2 SATA HDD
> > - 1 DVD burner
> > - 1 PCI card
> Don't know what to tell you... If I clear the CMOS on mine, and then
mine doesn't run at 200mhz - it will only do 195mhz x 11 - havenn't rebooted yet - but I think I don't have your problem. Turned out to be just a 2500+ XP not a mobile. Damn ebay.
"gringo" <holycrapuscuk@bigpond.net.au> wrote in message news:uPyGe.66332$oJ.61033@news-server.bigpond.net.au...
>I have a mobile 2500+ coming next week. Hope I don't have this problem as >well. Plan on running it at 3200+
> "dan2" <DoNotEmail@HardwareForumz.com> wrote in message > news:7_296141_31f963937579b95115872083041765d8@hardwareforumz.com...
>> "Erik" wrote:
>> > Hi Dan2,
>> > replied yet ?
>> > 1100 MHz.
>> > My config is :
>> > - SN41G2V3
>> > - AMD Barton 3200+
>> > - 2 SATA HDD
>> > - 1 DVD burner
>> > - 1 PCI card
Did anyone ever find a solution to this problem? I know this thread was over a year ago, but I'm having the same problem. If there are any solutions to this problem please let me know. Thanks
