Archived from groups: microsoft.public.windowsxp.hardware (More info?)
As the subject says, I'm in need of cables for these units (four). What are
the pinouts for such a cable? Are there crossed wires similar to a nul modem
cable or are both ends standard printer connections? Could a person not make
his own? I have sufficient parts on hand for such a project.
| Thanks
> Thanks
All Backpack drives use standard DB25 parallel printer cabling. Any good
quality printer cable will work. Source:
"Sunny" <sunny@nospam.net> wrote in message
news:9tTae.1323$gA5.84466@news20.bellglobal.com...
>> are
>> modem
>> make
>> Thanks
> http://www.micro-solutions.com/sup [...] etips1.asp >
> Sunny
That's the info I was searching for. I did search Micro Solutions site but
didn't find this.
>> are
>> modem
>> make
>> Thanks
> Sunny
My next question. Could these backpacks be used with a hard drive as well. I
notice there are some wires cutoff on the ribbon cable between the board and
drive. Apparantly a CDrom doesn't need as many conductors as a HD. This
cable would have to be replaced I expect.
>>>are
>>>modem
>>>make
>>>Thanks
>>http://www.micro-solutions.com/support/more_tips/moretips1.asp
>>Sunny
> Thanks
You want to install a hard drive in a Backpack CD-ROM enclosure?
I think it will probably work, but I'd try it with the existing ribbon
cable first because the cutoff wires are likely for master/slave
selection (i.e. not applicable) and/or printer pass-through. You are
unlikely to damage anything, even if it doesn't work - but you will be
experimenting in unknown territory, so don't blame me if something nasty
happens ;-)
A more cautious approach might be to obtain a Backpack hard drive
enclosure first, so you can see if it uses the same internal wiring as
the CD-ROM version.
news:REYae.667$BW6.199838@news20.bellglobal.com...
>>>>are
>>>>modem
>>>>make
>>>>Thanks
>>>Sunny
>> well. I notice there are some wires cutoff on the ribbon cable between
>> the board and drive. Apparantly a CDrom doesn't need as many conductors
>> as a HD. This cable would have to be replaced I expect.
>> Thanks
> cable first because the cutoff wires are likely for master/slave selection
Makes sense.
> happens ;-)
Not to worry. I've a number of old smaller HD's around. No great loss.
> enclosure first, so you can see if it uses the same internal wiring as the
> CD-ROM version.
