DVD Rom problem -help needed
Last response: in Windows XP
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
I hope this is the right forum but if its not perhaps you can point me in the
right direction.
The kids played a game called Casino Empire on their own PC which would
freeze every time it was played. After contacting the manufacturers I was
advised to log onto the Samsung site and download an upgrade for the DVD-Rom.
I did this and downloaded a Bin file(20030919144343187_SM-332B_COM-T406)
and a file named sfdwin.exe to my own PC as it has internet access. I copied
the downloaded stuff to disk and attempted to install it on the other PC.
During that procedure I was given the option of removing an old file which I
did (thinking this was the right thing to do).
Now the DVD-Rom will not work. Even the shortcut icon has a question mark
shown on it. When the PC is booted up there is a message saying that the
“Secondary hard disk drive 0 not found� and “Strike the F1 key to continue,
F2 to run the set up utility�
The CD/DVD-Rom is made by Samsung. On clicking the properties I got this -
ST 380023A (probably the hard drive) and “AXV CD/DVD-ROM SCSI cdRom device�
The OS is Windows XP
Can you help please as I know very little computers
right direction.
More about : dvd rom problem needed
Take a look here You might have hosed the Virtual Driver.
http://club.cdfreaks.com/showthread.php?t=99446
"muffler53" <muffler53@discussions.microsoft.com> wrote in message
news:693E03FD-2DBC-43E7-A574-2710BAD82E0D@microsoft.com...
>the
> right direction.
> DVD-Rom.
> copied
> I
> "Secondary hard disk drive 0 not found" and "Strike the F1 key to
> continue,
> F2 to run the set up utility"
> ST 380023A (probably the hard drive) and "AXV CD/DVD-ROM SCSI cdRom
> device"
>the
> right direction.
> DVD-Rom.
> copied
> I
> continue,
> device"
Thanks for the link RB. I had a look and the problem seems very similar to
mine. One of the solutions was "You will Also need to remove Plug and Play
Bios Extension from System Devices. and if needed the Virtual Drive Drivers
from the Windows/System32/Drivers Folder" which is a bit double dutch to me.
I wouldnt know where to start.
If I even knew how to contact Samsung would be a help. Done a google search
but couldn't find anything.
Hi,
Where have you linked to download the bin file?
Do you know the model of your DVD rom?
Below are some links for help:
http://www.samsungodd.com/eng/LiveUpdate/FAQ/Faq.asp
http://www.samsungodd.com/eng/Liveupdate/fwvercheck/fwv...
http://www.samsungodd.com/eng/LiveUpdate/QNA/QNA.asp
http://www.samsungodd.com/eng/LiveUpdate/Firmware/Firmw...
http://www.samsungodd.com/eng/Helper/Helper.asp?Functio...
Pls read the trouble shoot for DVD rom first and then try to use the live
update features.
Below is the message from samsung "Contact Us"
Thank you for using the Samsung ODD products.
Do you have any problems of Samsung ODD products?
Please refer to Troubleshooting or FAQs.
It will provide various solutions about your problems.
Do you need the newest firmware of Samsung ODD products?
Please download and install the Firmware Auto LiveUpdate Program
to solve your problems simply.
It will upgrade the newest firmware of your model automatically.
Do not you solve the problems of ODD products yet?
If you select your product below and send e-mail to us, we will reply
to you quickly and accurately.
CD-ROM DRIVE (SC-xxxx, SH-xxxx)
CD-RW DRIVE (SW-xxxx)
DVD-ROM DRIVE (SD-xxxx)
COMBO DRIVE (SM-xxxx) : CD-R/RW, DVD ROM
DVD-Writer DRIVE (SR-xxxx, MR-xxxx) : CD-R/RW, DVD-R/RW ROM
Slim Drive
If you want to inquire about other products or general items related to
Samsung Electronics, please click [Others].
Thank you.
< Notice >
This e-mail service is for general customers support.
In case of employees in service center of Samsung Electronics or
distributors(buyers) concerned with Samsung Electronics, please use
the business contact point of Samsung Electronics ODD Division.
© 2005 SAMSUNG Electronics Co., Ltd. All rights reserved.
Hope it helps.
Peter
Hi,
update features.
Slim Drive
Thank you.
< Notice >
Hope it helps.
Peter
Related ressources
- Help needed for DVD-ROM/DVD -RW problem - Forum
- ASUS CD/ DVD ROM Drivers needed - Forum
- Help Needed !! Flashed DVD ROM system Freezes checking NVRAM - Forum
- ASUS P5AD2 Deluxe DVD ROM Problem !! HELP !!!!! - Forum
- P4P800-E Deluxe & DVD-ROM problems -- HELP - Forum
Thanks for the help Peter. Unfortunately I amnot too technically minded and
some of the stuff on the links would be a wee bit beyond me.
I did manage to find a printed copy of the system profiler from a couple of
years ago.
The DVD/CD-RoM is a Samsung CDRW/DVD SM-332B
In the short term is it safe to use the PC or should I delete the sfdwin.exe
file and any ideas as to what to do at start up. Should I press F1 or F2
"Peter" wrote:
> Hi,
> update features.
> Slim Drive
> Thank you.
> < Notice >
> Hope it helps.
> Peter
years ago.
"Peter" wrote:
> Hi,
> update features.
> Slim Drive
> Thank you.
> < Notice >
> Hope it helps.
> Peter
Hi,
Below is the link for the download of firmware for your samsung DVD Combo
drive.
Please download the Bin file and exe file and save it to a specific folder.
Please print out the instruction for how to update the firmware. You must
strictly foloow the instructions.
http://www.samsungodd.com/eng/LiveUpdate/FWDownload/FWD...
Copy of intructions from samsung:
Global distribution
Product COMBO Model SM-332B F/W Ver. T406
Content
*caution
Samsung is not responsable for problems during the firmware upgrade. When
you encounter problems during the upgrade, please contact a Samsung Service
Center.
If your drive is still in warranty please contact your retailer first.
The newest firmware T406 of SM-332B
Applied model : EXPORT
Improvement: Progress of disk cognitive faculty
Caution:
When you upgrade your firmware, please check the "Buyer" on your label
of drive.
If you upgrade wrong firmware, you will have a problem in operating.
ex) SM-332B/*** 63BT123456 F/W=T403(***=Buyer)
How to upgrade firmware.
Download the attached "Bin file(firmware)" and "Sfdnwin.exe
file(download
program)" into a temporary folder.
When you run "Sfdnwin.exe", Pop-up window will appear. you can see
your ROM-
drive(s) in the Pop-up window.
Then choose the drive whose firmware you want to upgrade.
ex)Drive:SAMSUNG CD-R/RW SM-332B/T403
You will see three icons on the top from left.
If you click the first icon from left, you can see "Investigation
window" then open
the firmware file that you already downloaded to the temporary
folder.
You will see the message" Ready" after finding the firmware file that
you want.
Then click the middle icon on the top of left. Then your firmware
will be upgraded
automatically.
When you finish upgrading firmware , reboot your pc automatically.
Sfdnwin.exe : A program which can make your drive download our firmware(s) in
Windows.(It's for only Windows)
Caution:
of drive.
file(download
your ROM-
window" then open
folder.
you want.
will be upgraded
automatically.
Pls reply to NG if you still have problems.
Peter
> years ago.
> "Peter" wrote:
> > Hi,
> > update features.
> > Slim Drive
> > Thank you.
> > < Notice >
> > Hope it helps.
> > Peter
Hi,
drive.
Global distribution
Content
*caution
Center.
Caution:
of drive.
file(download
your ROM-
window" then open
folder.
you want.
will be upgraded
automatically.
Caution:
of drive.
file(download
your ROM-
window" then open
folder.
you want.
will be upgraded
automatically.
Peter
> years ago.
> "Peter" wrote:
> > Hi,
> > update features.
> > Slim Drive
> > Thank you.
> > < Notice >
> > Hope it helps.
> > Peter
Cheers Peter,
I got the instructions given below when I downloaded the files and perhaps
did not follow them exactly. I dont really know. In the middle of the
insallation I was asked if I wanted to "delete the old file ?" and as there
was only 1 button to click which was the OK one I did so and this has now
rendered the drive unusable.
I did send a copy of my original post to Samsung but have yet to receive a
reply. my main concern is at start up where I press F1 to proceed as opposed
to F2 to run the set up utility. Perhaps if this was run and the correct data
entered I may have no problems but I dont know what to fill in for the
various requested data.
In any event is it actually safe to use the PC in its present form? it does
boot up several minutes after hitting F1 and the jids are playing some games
on it but I am concerned that this may be doing more harm than good
"Peter" wrote:
> Hi,
> drive.
> Global distribution
> Content
> *caution
> Center.
> Caution:
> of drive.
> file(download
> your ROM-
> window" then open
> folder.
> you want.
> will be upgraded
> automatically.
> Caution:
> of drive.
> file(download
> your ROM-
> window" then open
> folder.
> you want.
> will be upgraded
> automatically.
> Peter
> > years ago.
> > "Peter" wrote:
> > > Hi,
> > > update features.
> > > Slim Drive
> > > Thank you.
> > > < Notice >
> > > Hope it helps.
> > > Peter
Cheers Peter,
"Peter" wrote:
> Hi,
> drive.
> Global distribution
> Content
> *caution
> Center.
> Caution:
> of drive.
> file(download
> your ROM-
> window" then open
> folder.
> you want.
> will be upgraded
> automatically.
> Caution:
> of drive.
> file(download
> your ROM-
> window" then open
> folder.
> you want.
> will be upgraded
> automatically.
> Peter
> > years ago.
> > "Peter" wrote:
> > > Hi,
> > > update features.
> > > Slim Drive
> > > Thank you.
> > > < Notice >
> > > Hope it helps.
> > > Peter
Hi,
No, it won't do more harm to the OS but if you don't fix the firmware then
the DVD Combo drive become useless. It is a hardware problem and cannot be
fixed unless you can update the firmware successfully.
Pls follow my previous post to download the bin and exe files again and then
save them to a specific folder. Print out the update firware instructions
then run the Sfdnwin.exe
Care: You must strictly follow the update instructions.
Caution:
When you upgrade your firmware, please check the "Buyer" on your label of
drive.
example) SM-332B/*** 63BT123456 F/W=T403(***=Buyer)
It is of no harm to run the Sfdnwin.exe again.
Peter
Peter
"muffler53" wrote:
> Cheers Peter,
> "Peter" wrote:
> > Hi,
> > drive.
> > Global distribution
> > Content
> > *caution
> > Center.
> > Caution:
> > of drive.
> > file(download
> > your ROM-
> > window" then open
> > folder.
> > you want.
> > will be upgraded
> > automatically.
> > Caution:
> > of drive.
> > file(download
> > your ROM-
> > window" then open
> > folder.
> > you want.
> > will be upgraded
> > automatically.
> > Peter
> > > years ago.
> > > "Peter" wrote:
> > > > Hi,
> > > > update features.
> > > > Slim Drive
> > > > Thank you.
> > > > < Notice >
> > > > Hope it helps.
> > > > Peter
Hi,
Caution:
drive.
Peter
Peter
"muffler53" wrote:
> Cheers Peter,
> "Peter" wrote:
> > Hi,
> > drive.
> > Global distribution
> > Content
> > *caution
> > Center.
> > Caution:
> > of drive.
> > file(download
> > your ROM-
> > window" then open
> > folder.
> > you want.
> > will be upgraded
> > automatically.
> > Caution:
> > of drive.
> > file(download
> > your ROM-
> > window" then open
> > folder.
> > you want.
> > will be upgraded
> > automatically.
> > Peter
> > > years ago.
> > > "Peter" wrote:
> > > > Hi,
> > > > update features.
> > > > Slim Drive
> > > > Thank you.
> > > > < Notice >
> > > > Hope it helps.
> > > > Peter
Thanks Peter,
I have downloaded the files and instructions as recommended. That is as far
as my knowledge basically goes at the moment. When I tried the upgrading
myself a couple of days ago I got myself into this mess.
Things are a bit clearer now. I have put everything I downloaded on to a
disc and my son has taken this togeteher with the PC to a friend of his
today. His friend apparently is a bit of a whizz kid with these things so
hopefully come Tuesday (bank holiday weekend here) all will be sorted out.
I will post again to let you know the outcome.
Thanks again for all the help and advice
Declan
"Peter" wrote:
> Hi,
> drive.
> Global distribution
> Content
> *caution
> Center.
> Caution:
> of drive.
> file(download
> your ROM-
> window" then open
> folder.
> you want.
> will be upgraded
> automatically.
> Caution:
> of drive.
> file(download
> your ROM-
> window" then open
> folder.
> you want.
> will be upgraded
> automatically.
> Peter
> > years ago.
> > "Peter" wrote:
> > > Hi,
> > > update features.
> > > Slim Drive
> > > Thank you.
> > > < Notice >
> > > Hope it helps.
> > > Peter
Thanks Peter,
Declan
"Peter" wrote:
> Hi,
> drive.
> Global distribution
> Content
> *caution
> Center.
> Caution:
> of drive.
> file(download
> your ROM-
> window" then open
> folder.
> you want.
> will be upgraded
> automatically.
> Caution:
> of drive.
> file(download
> your ROM-
> window" then open
> folder.
> you want.
> will be upgraded
> automatically.
> Peter
> > years ago.
> > "Peter" wrote:
> > > Hi,
> > > update features.
> > > Slim Drive
> > > Thank you.
> > > < Notice >
> > > Hope it helps.
> > > Peter
Declan,
I sincerely hope that you can fix it.
Await for your favourable reply.
Peter
"muffler53" wrote:
> Thanks Peter,
> Declan
> "Peter" wrote:
> > Hi,
> > drive.
> > Global distribution
> > Content
> > *caution
> > Center.
> > Caution:
> > of drive.
> > file(download
> > your ROM-
> > window" then open
> > folder.
> > you want.
> > will be upgraded
> > automatically.
> > Caution:
> > of drive.
> > file(download
> > your ROM-
> > window" then open
> > folder.
> > you want.
> > will be upgraded
> > automatically.
> > Peter
> > > years ago.
> > > "Peter" wrote:
> > > > Hi,
> > > > update features.
> > > > Slim Drive
> > > > Thank you.
> > > > < Notice >
> > > > Hope it helps.
> > > > Peter
Declan,
Peter
"muffler53" wrote:
> Thanks Peter,
> Declan
> "Peter" wrote:
> > Hi,
> > drive.
> > Global distribution
> > Content
> > *caution
> > Center.
> > Caution:
> > of drive.
> > file(download
> > your ROM-
> > window" then open
> > folder.
> > you want.
> > will be upgraded
> > automatically.
> > Caution:
> > of drive.
> > file(download
> > your ROM-
> > window" then open
> > folder.
> > you want.
> > will be upgraded
> > automatically.
> > Peter
> > > years ago.
> > > "Peter" wrote:
> > > > Hi,
> > > > update features.
> > > > Slim Drive
> > > > Thank you.
> > > > < Notice >
> > > > Hope it helps.
> > > > Peter
Peter,
Just to keep you updated. It will be another day or so before I get the PC
back but I got a reply from Samsung. I dont think that I mentioned this
before but I sent a query off to them (same as original post here) but only
got a response today.
Have a look and I think you will see why computer dummies like me depend so
much on other people for help
Regards
Declan
"Dear,customer
Thank you for your e-mail.
If during the firmware upgrade an error occurred,or
Ypu have problem After installing the firmware update,
this may cause the firmware chip to become blocked,
making the drive unusable.
Errors during firmware upgrade can have several causes,
the major ones being a conflict with
a program running in the background (eg Virus Scanner, Screensaver...)
or installing the incorrect firmware.
this problem can only be solved by having the drive repaired
at one of our service centers.
Please return your device to the store where you bought it,
there they can send the device to the service center.
I feel sorry that i can't help you directly.
Have a nice day!
Thank you."
"Peter" wrote:
> Declan,
> Peter
> "muffler53" wrote:
> > Thanks Peter,
> > Declan
> > "Peter" wrote:
> > > Hi,
> > > drive.
> > > Global distribution
> > > Content
> > > *caution
> > > Center.
> > > Caution:
> > > of drive.
> > > file(download
> > > your ROM-
> > > window" then open
> > > folder.
> > > you want.
> > > will be upgraded
> > > automatically.
> > > Caution:
> > > of drive.
> > > file(download
> > > your ROM-
> > > window" then open
> > > folder.
> > > you want.
> > > will be upgraded
> > > automatically.
> > > Peter
> > > > years ago.
> > > > "Peter" wrote:
> > > > > Hi,
> > > > > update features.
> > > > > Slim Drive
> > > > > Thank you.
> > > > > < Notice >
> > > > > Hope it helps.
> > > > > Peter
Peter,
Regards
Declan
"Dear,customer
Have a nice day!
Thank you."
"Peter" wrote:
> Declan,
> Peter
> "muffler53" wrote:
> > Thanks Peter,
> > Declan
> > "Peter" wrote:
> > > Hi,
> > > drive.
> > > Global distribution
> > > Content
> > > *caution
> > > Center.
> > > Caution:
> > > of drive.
> > > file(download
> > > your ROM-
> > > window" then open
> > > folder.
> > > you want.
> > > will be upgraded
> > > automatically.
> > > Caution:
> > > of drive.
> > > file(download
> > > your ROM-
> > > window" then open
> > > folder.
> > > you want.
> > > will be upgraded
> > > automatically.
> > > Peter
> > > > years ago.
> > > > "Peter" wrote:
> > > > > Hi,
> > > > > update features.
> > > > > Slim Drive
> > > > > Thank you.
> > > > > < Notice >
> > > > > Hope it helps.
> > > > > Peter
Declan,
Sorry to hear that. To the best of my knowledge, if the flash rom (a kind of
chips that use to store the firmware) is not being damaged in the firmware
updating process, you can run the update process again to update the
firmware. However, if there is a bad block to the firmware chips, there is
nothing we can do about it but send it for a repair. The technician either
use the burn-in technic to burn the firmware to the firmware chips (cannot be
updated in future) or change to a new chips (can be updated in future)
Similar to a mobo BIOS update, if you encounter some problems during the
BIOS update process, DO NOT POWER OFF the machine but just run the BIOS
update process again to update the BIOS again or revert to the original BIOS.
Any way, pls take it easy and await for your friend's favourable reply.
Peter
"muffler53" wrote:
> Peter,
> Regards
> Declan
> "Dear,customer
> Have a nice day!
> Thank you."
> "Peter" wrote:
> > Declan,
> > Peter
> > "muffler53" wrote:
> > > Thanks Peter,
> > > Declan
> > > "Peter" wrote:
> > > > Hi,
> > > > drive.
> > > > Global distribution
> > > > Content
> > > > *caution
> > > > Center.
> > > > Caution:
> > > > of drive.
> > > > file(download
> > > > your ROM-
> > > > window" then open
> > > > folder.
> > > > you want.
> > > > will be upgraded
> > > > automatically.
> > > > Caution:
> > > > of drive.
> > > > file(download
> > > > your ROM-
> > > > window" then open
> > > > folder.
> > > > you want.
> > > > will be upgraded
> > > > automatically.
> > > > Peter
> > > > > years ago.
> > > > > "Peter" wrote:
> > > > > > Hi,
> > > > > > update features.
> > > > > > Slim Drive
> > > > > > Thank you.
> > > > > > < Notice >
> > > > > > Hope it helps.
> > > > > > Peter
Declan,
Peter
"muffler53" wrote:
> Peter,
> Regards
> Declan
> "Dear,customer
> Have a nice day!
> Thank you."
> "Peter" wrote:
> > Declan,
> > Peter
> > "muffler53" wrote:
> > > Thanks Peter,
> > > Declan
> > > "Peter" wrote:
> > > > Hi,
> > > > drive.
> > > > Global distribution
> > > > Content
> > > > *caution
> > > > Center.
> > > > Caution:
> > > > of drive.
> > > > file(download
> > > > your ROM-
> > > > window" then open
> > > > folder.
> > > > you want.
> > > > will be upgraded
> > > > automatically.
> > > > Caution:
> > > > of drive.
> > > > file(download
> > > > your ROM-
> > > > window" then open
> > > > folder.
> > > > you want.
> > > > will be upgraded
> > > > automatically.
> > > > Peter
> > > > > years ago.
> > > > > "Peter" wrote:
> > > > > > Hi,
> > > > > > update features.
> > > > > > Slim Drive
> > > > > > Thank you.
> > > > > > < Notice >
> > > > > > Hope it helps.
> > > > > > Peter
Peter,
I picked the PC up 2 days ago but the chap who fixed it wasn't there so I
didn;t find out exactly what the problem was. My son will be talking to him
soon so I will find out then.
Anyway it needed a new DVD Rom drive (or maybe he just decided to make a bit
of handy money). It cost me 50 euro but I,m still not convinced that the
downloaded files would not have worked.
Hope to find out more in the next couple of days.
I hate to bother but you wouldn't happen to know anything about a "16 Bit
Windows Subsystem" error.
It's left the kids PC that it will only play certain games. It was fine up
to a few months ago
Thanks for your help
Declan
"Peter" wrote:
> Declan,
> Peter
> "muffler53" wrote:
> > Peter,
> > Regards
> > Declan
> > "Dear,customer
> > Have a nice day!
> > Thank you."
> > "Peter" wrote:
> > > Declan,
> > > Peter
> > > "muffler53" wrote:
> > > > Thanks Peter,
> > > > Declan
> > > > "Peter" wrote:
> > > > > Hi,
> > > > > drive.
> > > > > Global distribution
> > > > > Content
> > > > > *caution
> > > > > Center.
> > > > > Caution:
> > > > > of drive.
> > > > > file(download
> > > > > your ROM-
> > > > > window" then open
> > > > > folder.
> > > > > you want.
> > > > > will be upgraded
> > > > > automatically.
> > > > > Caution:
> > > > > of drive.
> > > > > file(download
> > > > > your ROM-
> > > > > window" then open
> > > > > folder.
> > > > > you want.
> > > > > will be upgraded
> > > > > automatically.
> > > > > Peter
> > > > > > years ago.
> > > > > > "Peter" wrote:
> > > > > > > Hi,
> > > > > > > update features.
> > > > > > > Slim Drive
> > > > > > > Thank you.
> > > > > > > < Notice >
> > > > > > > Hope it helps.
> > > > > > > Peter
Peter,
to a few months ago
Declan
"Peter" wrote:
> Declan,
> Peter
> "muffler53" wrote:
> > Peter,
> > Regards
> > Declan
> > "Dear,customer
> > Have a nice day!
> > Thank you."
> > "Peter" wrote:
> > > Declan,
> > > Peter
> > > "muffler53" wrote:
> > > > Thanks Peter,
> > > > Declan
> > > > "Peter" wrote:
> > > > > Hi,
> > > > > drive.
> > > > > Global distribution
> > > > > Content
> > > > > *caution
> > > > > Center.
> > > > > Caution:
> > > > > of drive.
> > > > > file(download
> > > > > your ROM-
> > > > > window" then open
> > > > > folder.
> > > > > you want.
> > > > > will be upgraded
> > > > > automatically.
> > > > > Caution:
> > > > > of drive.
> > > > > file(download
> > > > > your ROM-
> > > > > window" then open
> > > > > folder.
> > > > > you want.
> > > > > will be upgraded
> > > > > automatically.
> > > > > Peter
> > > > > > years ago.
> > > > > > "Peter" wrote:
> > > > > > > Hi,
> > > > > > > update features.
> > > > > > > Slim Drive
> > > > > > > Thank you.
> > > > > > > < Notice >
> > > > > > > Hope it helps.
> > > > > > > Peter
Declan,
To fix the "16 Bit Windows Subsystem" error, restore the autoexec.nt file
from C:\windows\repair folder. If it disappears or gets broken again, suspect
a malware issue and remove same.
Procedures:
Double click My Computer, click the C drive, click WINDOWS and find the
repair folder
C:\WINDOWS\repair\autoexec.nt
right click on the file "autoexec.nt " and select copy then paste it to
C:\WINDOWS\system32\AUTOEXEC.NT
Let the file "autoexec.nt " copied from the repair folder to replace the
existing file" AUTOEXEC.NT" in the system32 folder.
If the symptom persists, pls run any anti-spyware softwares e.g. Adaware
Personal SE from lavasoftusa.com or Spybot Search & Destroy. Ensure the PC is
free from virus and spywares then proceed the copy & paste of the file again.
Hope it helps you to fix it.
Peter
"muffler53" wrote:
> Peter,
> to a few months ago
> Declan
> "Peter" wrote:
> > Declan,
> > Peter
> > "muffler53" wrote:
> > > Peter,
> > > Regards
> > > Declan
> > > "Dear,customer
> > > Have a nice day!
> > > Thank you."
> > > "Peter" wrote:
> > > > Declan,
> > > > Peter
> > > > "muffler53" wrote:
> > > > > Thanks Peter,
> > > > > Declan
> > > > > "Peter" wrote:
> > > > > > Hi,
> > > > > > drive.
> > > > > > Global distribution
> > > > > > Content
> > > > > > *caution
> > > > > > Center.
> > > > > > Caution:
> > > > > > of drive.
> > > > > > file(download
> > > > > > your ROM-
> > > > > > window" then open
> > > > > > folder.
> > > > > > you want.
> > > > > > will be upgraded
> > > > > > automatically.
> > > > > > Caution:
> > > > > > of drive.
> > > > > > file(download
> > > > > > your ROM-
> > > > > > window" then open
> > > > > > folder.
> > > > > > you want.
> > > > > > will be upgraded
> > > > > > automatically.
> > > > > > Peter
> > > > > > > years ago.
> > > > > > > "Peter" wrote:
> > > > > > > > Hi,
> > > > > > > > update features.
Declan,
Procedures:
repair folder
Peter
"muffler53" wrote:
> Peter,
> to a few months ago
> Declan
> "Peter" wrote:
> > Declan,
> > Peter
> > "muffler53" wrote:
> > > Peter,
> > > Regards
> > > Declan
> > > "Dear,customer
> > > Have a nice day!
> > > Thank you."
> > > "Peter" wrote:
> > > > Declan,
> > > > Peter
> > > > "muffler53" wrote:
> > > > > Thanks Peter,
> > > > > Declan
> > > > > "Peter" wrote:
> > > > > > Hi,
> > > > > > drive.
> > > > > > Global distribution
> > > > > > Content
> > > > > > *caution
> > > > > > Center.
> > > > > > Caution:
> > > > > > of drive.
> > > > > > file(download
> > > > > > your ROM-
> > > > > > window" then open
> > > > > > folder.
> > > > > > you want.
> > > > > > will be upgraded
> > > > > > automatically.
> > > > > > Caution:
> > > > > > of drive.
> > > > > > file(download
> > > > > > your ROM-
> > > > > > window" then open
> > > > > > folder.
> > > > > > you want.
> > > > > > will be upgraded
> > > > > > automatically.
> > > > > > Peter
> > > > > > > years ago.
> > > > > > > "Peter" wrote:
> > > > > > > > Hi,
> > > > > > > > update features.
Thanks Peter,
just after I posted I did a search on this forum and found details of the
error. The problem is on the kid's PC (same one with the dvd rom problem.)
There is a "VX2" malware in it which I cant get rid of.
That PC is not connected to the internet but when it was a few months ago i
did download and install some sort of removal tool from Adaware which was
supposed to fix it but it didn't.
I assume there is no point in trying the procedure as you described until I
get rid of the VX2.
ANy ideas other than a system restore or a complete reinstall of how to
banish the VX2.
Thanks again for the help
regards
Declan
"Peter" wrote:
> Declan,
> Procedures:
> repair folder
> Peter
> "muffler53" wrote:
> > Peter,
> > to a few months ago
> > Declan
> > "Peter" wrote:
> > > Declan,
> > > Peter
> > > "muffler53" wrote:
> > > > Peter,
> > > > Regards
> > > > Declan
> > > > "Dear,customer
> > > > Have a nice day!
> > > > Thank you."
> > > > "Peter" wrote:
> > > > > Declan,
> > > > > Peter
> > > > > "muffler53" wrote:
> > > > > > Thanks Peter,
> > > > > > Declan
> > > > > > "Peter" wrote:
> > > > > > > Hi,
> > > > > > > drive.
> > > > > > > Global distribution
> > > > > > > Content
> > > > > > > *caution
> > > > > > > Center.
> > > > > > > Caution:
> > > > > > > of drive.
> > > > > > > file(download
> > > > > > > your ROM-
> > > > > > > window" then open
> > > > > > > folder.
> > > > > > > you want.
> > > > > > > will be upgraded
> > > > > > > automatically.
> > > > > > > Caution:
> > > > > > > of drive.
> > > > > > > file(download
> > > > > > > your ROM-
> > > > > > > window" then open
> > > > > > > folder.
> > > > > > > you want.
> > > > > > > will be upgraded
> > > > > > > automatically.
> > > > > > > Peter
> > > > > > > > years ago.
> > > > > > > > "Peter" wrote:
> > > > > > > > > Hi,
Thanks Peter,
get rid of the VX2.
banish the VX2.
regards
Declan
"Peter" wrote:
> Declan,
> Procedures:
> repair folder
> Peter
> "muffler53" wrote:
> > Peter,
> > to a few months ago
> > Declan
> > "Peter" wrote:
> > > Declan,
> > > Peter
> > > "muffler53" wrote:
> > > > Peter,
> > > > Regards
> > > > Declan
> > > > "Dear,customer
> > > > Have a nice day!
> > > > Thank you."
> > > > "Peter" wrote:
> > > > > Declan,
> > > > > Peter
> > > > > "muffler53" wrote:
> > > > > > Thanks Peter,
> > > > > > Declan
> > > > > > "Peter" wrote:
> > > > > > > Hi,
> > > > > > > drive.
> > > > > > > Global distribution
> > > > > > > Content
> > > > > > > *caution
> > > > > > > Center.
> > > > > > > Caution:
> > > > > > > of drive.
> > > > > > > file(download
> > > > > > > your ROM-
> > > > > > > window" then open
> > > > > > > folder.
> > > > > > > you want.
> > > > > > > will be upgraded
> > > > > > > automatically.
> > > > > > > Caution:
> > > > > > > of drive.
> > > > > > > file(download
> > > > > > > your ROM-
> > > > > > > window" then open
> > > > > > > folder.
> > > > > > > you want.
> > > > > > > will be upgraded
> > > > > > > automatically.
> > > > > > > Peter
> > > > > > > > years ago.
> > > > > > > > "Peter" wrote:
> > > > > > > > > Hi,
Declan,
Firstly, you must stop the restore feature and clear all the restored files.
Right click My Computer/Properties/System Restore
Check the box "Turn off System Restore on all drives", click Apply and OK
Run Adaware to download & install the latest spywares definitions.
Then go to the link below to download the VX2 cleaner:
http://www.lavasoftusa.com/software/addons/vx2cleaner.s...
Follow the instructions for how to run the add-on tools to remove VX2
Run Adaware again to ensure the VX2 is completely removed from the system.
After the cleanup of VX2, run any antivirus software with the latest virus
definitions to ensure your system is free from any
virus/trojans/spywares/malwares, etc. Reboot the PC then re-enable the System
Restore feature by uncheck the box "Turn off System Restore on all drives",
click Apply and OK
Hope it helps.
Peter
"muffler53" wrote:
> Thanks Peter,
> get rid of the VX2.
> banish the VX2.
> regards
> Declan
> "Peter" wrote:
> > Declan,
> > Procedures:
> > repair folder
> > Peter
> > "muffler53" wrote:
> > > Peter,
> > > to a few months ago
> > > Declan
> > > "Peter" wrote:
> > > > Declan,
> > > > Peter
> > > > "muffler53" wrote:
> > > > > Peter,
> > > > > Regards
> > > > > Declan
> > > > > "Dear,customer
> > > > > Have a nice day!
> > > > > Thank you."
> > > > > "Peter" wrote:
> > > > > > Declan,
> > > > > > Peter
> > > > > > "muffler53" wrote:
> > > > > > > Thanks Peter,
> > > > > > > Declan
> > > > > > > "Peter" wrote:
> > > > > > > > Hi,
> > > > > > > > drive.
> > > > > > > > Global distribution
> > > > > > > > Content
> > > > > > > > *caution
> > > > > > > > Center.
> > > > > > > > Caution:
> > > > > > > > of drive.
> > > > > > > > file(download
> > > > > > > > your ROM-
> > > > > > > > window" then open
> > > > > > > > folder.
> > > > > > > > you want.
> > > > > > > > will be upgraded
> > > > > > > > automatically.
> > > > > > > > Caution:
> > > > > > > > of drive.
> > > > > > > > file(download
> > > > > > > > your ROM-
> > > > > > > > window" then open
> > > > > > > > folder.
> > > > > > > > you want.
> > > > > > > > will be upgraded
> > > > > > > > automatically.
> > > > > > > > Peter
> > > > > > > > "muffler53" wrote:
Declan,
click Apply and OK
Hope it helps.
Peter
"muffler53" wrote:
> Thanks Peter,
> get rid of the VX2.
> banish the VX2.
> regards
> Declan
> "Peter" wrote:
> > Declan,
> > Procedures:
> > repair folder
> > Peter
> > "muffler53" wrote:
> > > Peter,
> > > to a few months ago
> > > Declan
> > > "Peter" wrote:
> > > > Declan,
> > > > Peter
> > > > "muffler53" wrote:
> > > > > Peter,
> > > > > Regards
> > > > > Declan
> > > > > "Dear,customer
> > > > > Have a nice day!
> > > > > Thank you."
> > > > > "Peter" wrote:
> > > > > > Declan,
> > > > > > Peter
> > > > > > "muffler53" wrote:
> > > > > > > Thanks Peter,
> > > > > > > Declan
> > > > > > > "Peter" wrote:
> > > > > > > > Hi,
> > > > > > > > drive.
> > > > > > > > Global distribution
> > > > > > > > Content
> > > > > > > > *caution
> > > > > > > > Center.
> > > > > > > > Caution:
> > > > > > > > of drive.
> > > > > > > > file(download
> > > > > > > > your ROM-
> > > > > > > > window" then open
> > > > > > > > folder.
> > > > > > > > you want.
> > > > > > > > will be upgraded
> > > > > > > > automatically.
> > > > > > > > Caution:
> > > > > > > > of drive.
> > > > > > > > file(download
> > > > > > > > your ROM-
> > > > > > > > window" then open
> > > > > > > > folder.
> > > > > > > > you want.
> > > > > > > > will be upgraded
> > > > > > > > automatically.
> > > > > > > > Peter
Peter,
Thank you so much for the replies. As you will have guessed I'm a bit of a
novice with Pc's. The kids PC is in a different room and not connected to the
internet but can I download the items you mentioned including the up to date
adaware (and possibly AVG) on to my own PC and copy this to disc and then
load all into the kids PC from the disc.
I haven't got much help here where I live and I really do appreciate your
help and advice which has been fairly easy to understand even for a novice
like me.
thanks again
Declan
"Peter" wrote:
> Declan,
> click Apply and OK
> Hope it helps.
> Peter
> "muffler53" wrote:
> > Thanks Peter,
> > get rid of the VX2.
> > banish the VX2.
> > regards
> > Declan
> > "Peter" wrote:
> > > Declan,
> > > Procedures:
> > > repair folder
> > > Peter
> > > "muffler53" wrote:
> > > > Peter,
> > > > to a few months ago
> > > > Declan
> > > > "Peter" wrote:
> > > > > Declan,
> > > > > Peter
> > > > > "muffler53" wrote:
> > > > > > Peter,
> > > > > > Regards
> > > > > > Declan
> > > > > > "Dear,customer
> > > > > > Have a nice day!
> > > > > > Thank you."
> > > > > > "Peter" wrote:
> > > > > > > Declan,
> > > > > > > Peter
> > > > > > > "muffler53" wrote:
> > > > > > > > Thanks Peter,
> > > > > > > > Declan
> > > > > > > > "Peter" wrote:
> > > > > > > > > Hi,
> > > > > > > > > drive.
> > > > > > > > > Global distribution
> > > > > > > > > Content
> > > > > > > > > *caution
> > > > > > > > > Center.
> > > > > > > > > Caution:
> > > > > > > > > of drive.
> > > > > > > > > file(download
> > > > > > > > > your ROM-
> > > > > > > > > window" then open
> > > > > > > > > folder.
> > > > > > > > > you want.
> > > > > > > > > will be upgraded
> > > > > > > > > automatically.
> > > > > > > > > Caution:
> > > > > > > > > of drive.
> > > > > > > > > file(download
> > > > > > > > > your ROM-
Peter,
like me.
thanks again
Declan
"Peter" wrote:
> Declan,
> click Apply and OK
> Hope it helps.
> Peter
> "muffler53" wrote:
> > Thanks Peter,
> > get rid of the VX2.
> > banish the VX2.
> > regards
> > Declan
> > "Peter" wrote:
> > > Declan,
> > > Procedures:
> > > repair folder
> > > Peter
> > > "muffler53" wrote:
> > > > Peter,
> > > > to a few months ago
> > > > Declan
> > > > "Peter" wrote:
> > > > > Declan,
> > > > > Peter
> > > > > "muffler53" wrote:
> > > > > > Peter,
> > > > > > Regards
> > > > > > Declan
> > > > > > "Dear,customer
> > > > > > Have a nice day!
> > > > > > Thank you."
> > > > > > "Peter" wrote:
> > > > > > > Declan,
> > > > > > > Peter
> > > > > > > "muffler53" wrote:
> > > > > > > > Thanks Peter,
> > > > > > > > Declan
> > > > > > > > "Peter" wrote:
> > > > > > > > > Hi,
> > > > > > > > > drive.
> > > > > > > > > Global distribution
> > > > > > > > > Content
> > > > > > > > > *caution
> > > > > > > > > Center.
> > > > > > > > > Caution:
> > > > > > > > > of drive.
> > > > > > > > > file(download
> > > > > > > > > your ROM-
> > > > > > > > > window" then open
> > > > > > > > > folder.
> > > > > > > > > you want.
> > > > > > > > > will be upgraded
> > > > > > > > > automatically.
> > > > > > > > > Caution:
> > > > > > > > > of drive.
> > > > > > > > > file(download
> > > > > > > > > your ROM-
Declan,
Theoritically you can download AVG and Adaware to your PC then copy and
install them on the kid's PC. However, it is rather complicated to download
the latest update definitions from AVG and Adaware and then install them to
the kid's PC.
It is more easy for you to move the kid's PC to your room and then connect
it to the internet (provided that it has a lan card or modem or your PC using
external modem, then you just need to install the modem drivers on the kid's
PC)
Peter
"muffler53" wrote:
> Peter,
> like me.
> thanks again
> Declan
> "Peter" wrote:
> > Declan,
> > click Apply and OK
> > Hope it helps.
> > Peter
> > "muffler53" wrote:
> > > Thanks Peter,
> > > get rid of the VX2.
> > > banish the VX2.
> > > regards
> > > Declan
> > > "Peter" wrote:
> > > > Declan,
> > > > Procedures:
> > > > repair folder
> > > > Peter
> > > > "muffler53" wrote:
> > > > > Peter,
> > > > > to a few months ago
> > > > > Declan
> > > > > "Peter" wrote:
> > > > > > Declan,
> > > > > > Peter
> > > > > > "muffler53" wrote:
> > > > > > > Peter,
> > > > > > > Regards
> > > > > > > Declan
> > > > > > > "Dear,customer
> > > > > > > Have a nice day!
> > > > > > > Thank you."
> > > > > > > "Peter" wrote:
> > > > > > > > Declan,
> > > > > > > > Peter
> > > > > > > > "muffler53" wrote:
> > > > > > > > > Thanks Peter,
> > > > > > > > > Declan
> > > > > > > > > "Peter" wrote:
> > > > > > > > > > Hi,
> > > > > > > > > > drive.
> > > > > > > > > > Global distribution
> > > > > > > > > > Content
> > > > > > > > > > *caution
> > > > > > > > > > Center.
> > > > > > > > > > Caution:
> > > > > > > > > > of drive.
> > > > > > > > > > file(download
> > > > > > > > > > your ROM-
> > > > > > > > > > window" then open
> > > > > > > > > > folder.
> > > > > > > > > > you want.
> > > > > > > > > > will be upgraded
> > > > > > > > > > automatically.
Declan,
the kid's PC.
PC)
Peter
"muffler53" wrote:
> Peter,
> like me.
> thanks again
> Declan
> "Peter" wrote:
> > Declan,
> > click Apply and OK
> > Hope it helps.
> > Peter
> > "muffler53" wrote:
> > > Thanks Peter,
> > > get rid of the VX2.
> > > banish the VX2.
> > > regards
> > > Declan
> > > "Peter" wrote:
> > > > Declan,
> > > > Procedures:
> > > > repair folder
> > > > Peter
> > > > "muffler53" wrote:
> > > > > Peter,
> > > > > to a few months ago
> > > > > Declan
> > > > > "Peter" wrote:
> > > > > > Declan,
> > > > > > Peter
> > > > > > "muffler53" wrote:
> > > > > > > Peter,
> > > > > > > Regards
> > > > > > > Declan
> > > > > > > "Dear,customer
> > > > > > > Have a nice day!
> > > > > > > Thank you."
> > > > > > > "Peter" wrote:
> > > > > > > > Declan,
> > > > > > > > Peter
> > > > > > > > "muffler53" wrote:
> > > > > > > > > Thanks Peter,
> > > > > > > > > Declan
> > > > > > > > > "Peter" wrote:
> > > > > > > > > > Hi,
> > > > > > > > > > drive.
> > > > > > > > > > Global distribution
> > > > > > > > > > Content
> > > > > > > > > > *caution
> > > > > > > > > > Center.
> > > > > > > > > > Caution:
> > > > > > > > > > of drive.
> > > > > > > > > > file(download
> > > > > > > > > > your ROM-
> > > > > > > > > > window" then open
> > > > > > > > > > folder.
> > > > > > > > > > you want.
> > > > > > > > > > will be upgraded
> > > > > > > > > > automatically.
Peter,
Sorry for the delay in getting back with an update on what happened the DVD
drive.
My son finally got round to asking what the problem was and his friend told
him that it had basically just worn out.
As you are aware I know very little about computers but seeing as the
problem occured during installation of a firmware upgrade it was fairly
obvious that this is where the problem lay. But in order not to put my son on
a spot I decided to let it go.
At least his friend has given me a guarantee wih the new drive.
I will take your advice about the kids PC. It will be easier than I thought
as there is a phone socket in their room so I think I just have to disconnect
the modem and connect it again in their room.
I will keep you posted or indeed if I hit a problem I may be back to torture
you for some good advice.
Thanks
Declan
"Peter" wrote:
> Declan,
> the kid's PC.
> PC)
> Peter
> "muffler53" wrote:
> > Peter,
> > like me.
> > thanks again
> > Declan
> > "Peter" wrote:
> > > Declan,
> > > click Apply and OK
> > > Hope it helps.
> > > Peter
> > > "muffler53" wrote:
> > > > Thanks Peter,
> > > > get rid of the VX2.
> > > > banish the VX2.
> > > > regards
> > > > Declan
> > > > "Peter" wrote:
> > > > > Declan,
> > > > > Procedures:
> > > > > repair folder
> > > > > Peter
> > > > > "muffler53" wrote:
> > > > > > Peter,
> > > > > > to a few months ago
> > > > > > Declan
> > > > > > "Peter" wrote:
> > > > > > > Declan,
> > > > > > > Peter
> > > > > > > "muffler53" wrote:
> > > > > > > > Peter,
> > > > > > > > Regards
> > > > > > > > Declan
> > > > > > > > "Dear,customer
> > > > > > > > Have a nice day!
> > > > > > > > Thank you."
> > > > > > > > "Peter" wrote:
> > > > > > > > > Declan,
> > > > > > > > > Peter
> > > > > > > > > "muffler53" wrote:
> > > > > > > > > > Thanks Peter,
> > > > > > > > > > Declan
> > > > > > > > > > "Peter" wrote:
> > > > > > > > > > > Hi,
> > > > > > > > > > > drive.
> > > > > > > > > > > Global distribution
> > > > > > > > > > > Content
> > > > > > > > > > > *caution
> > > > > > > > > > > Center.
> > > > > > > > > > > Caution:
> > > > > > > > > > > of drive.
> > > > > > > > > > > file(download
> > > > > > > > > > > your ROM-
> > > > > > > > > > > window" then open
Peter,
drive.
Thanks
Declan
"Peter" wrote:
> Declan,
> the kid's PC.
> PC)
> Peter
> "muffler53" wrote:
> > Peter,
> > like me.
> > thanks again
> > Declan
> > "Peter" wrote:
> > > Declan,
> > > click Apply and OK
> > > Hope it helps.
> > > Peter
> > > "muffler53" wrote:
> > > > Thanks Peter,
> > > > get rid of the VX2.
> > > > banish the VX2.
> > > > regards
> > > > Declan
> > > > "Peter" wrote:
> > > > > Declan,
> > > > > Procedures:
> > > > > repair folder
> > > > > Peter
> > > > > "muffler53" wrote:
> > > > > > Peter,
> > > > > > to a few months ago
> > > > > > Declan
> > > > > > "Peter" wrote:
> > > > > > > Declan,
> > > > > > > Peter
> > > > > > > "muffler53" wrote:
> > > > > > > > Peter,
> > > > > > > > Regards
> > > > > > > > Declan
> > > > > > > > "Dear,customer
> > > > > > > > Have a nice day!
> > > > > > > > Thank you."
> > > > > > > > "Peter" wrote:
> > > > > > > > > Declan,
> > > > > > > > > Peter
> > > > > > > > > "muffler53" wrote:
> > > > > > > > > > Thanks Peter,
> > > > > > > > > > Declan
> > > > > > > > > > "Peter" wrote:
> > > > > > > > > > > Hi,
> > > > > > > > > > > drive.
> > > > > > > > > > > Global distribution
> > > > > > > > > > > Content
> > > > > > > > > > > *caution
> > > > > > > > > > > Center.
> > > > > > > > > > > Caution:
> > > > > > > > > > > of drive.
> > > > > > > > > > > file(download
> > > > > > > > > > > your ROM-
> > > > > > > > > > > window" then open
Declan,
You are welcome.
Peter
"muffler53" wrote:
> Peter,
> drive.
> Thanks
> Declan
> "Peter" wrote:
> > Declan,
> > the kid's PC.
> > PC)
> > Peter
> > "muffler53" wrote:
> > > Peter,
> > > like me.
> > > thanks again
> > > Declan
> > > "Peter" wrote:
> > > > Declan,
> > > > click Apply and OK
> > > > Hope it helps.
> > > > Peter
> > > > "muffler53" wrote:
> > > > > Thanks Peter,
> > > > > get rid of the VX2.
> > > > > banish the VX2.
> > > > > regards
> > > > > Declan
> > > > > "Peter" wrote:
> > > > > > Declan,
> > > > > > Procedures:
> > > > > > repair folder
> > > > > > Peter
> > > > > > "muffler53" wrote:
> > > > > > > Peter,
> > > > > > > to a few months ago
> > > > > > > Declan
> > > > > > > "Peter" wrote:
> > > > > > > > Declan,
> > > > > > > > Peter
> > > > > > > > "muffler53" wrote:
> > > > > > > > > Peter,
> > > > > > > > > Regards
> > > > > > > > > Declan
> > > > > > > > > "Dear,customer
> > > > > > > > > Have a nice day!
> > > > > > > > > Thank you."
> > > > > > > > > "Peter" wrote:
> > > > > > > > > > Declan,
> > > > > > > > > > Peter
> > > > > > > > > > "muffler53" wrote:
> > > > > > > > > > > Thanks Peter,
> > > > > > > > > > > Declan
> > > > > > > > > > > "Peter" wrote:
> > > > > > > > > > > > Hi,
> > > > > > > > > > > > drive.
> > > > > > > > > > > > Global distribution
> > > > > > > > > > > > Content
> > > > > > > > > > > > *caution
> > > > > > > > > > > > Center.
Declan,
You are welcome.
Peter
"muffler53" wrote:
> Peter,
> drive.
> Thanks
> Declan
> "Peter" wrote:
> > Declan,
> > the kid's PC.
> > PC)
> > Peter
> > "muffler53" wrote:
> > > Peter,
> > > like me.
> > > thanks again
> > > Declan
> > > "Peter" wrote:
> > > > Declan,
> > > > click Apply and OK
> > > > Hope it helps.
> > > > Peter
> > > > "muffler53" wrote:
> > > > > Thanks Peter,
> > > > > get rid of the VX2.
> > > > > banish the VX2.
> > > > > regards
> > > > > Declan
> > > > > "Peter" wrote:
> > > > > > Declan,
> > > > > > Procedures:
> > > > > > repair folder
> > > > > > Peter
> > > > > > "muffler53" wrote:
> > > > > > > Peter,
> > > > > > > to a few months ago
> > > > > > > Declan
> > > > > > > "Peter" wrote:
> > > > > > > > Declan,
> > > > > > > > Peter
> > > > > > > > "muffler53" wrote:
> > > > > > > > > Peter,
> > > > > > > > > Regards
> > > > > > > > > Declan
> > > > > > > > > "Dear,customer
> > > > > > > > > Have a nice day!
> > > > > > > > > Thank you."
> > > > > > > > > "Peter" wrote:
> > > > > > > > > > Declan,
> > > > > > > > > > Peter
> > > > > > > > > > "muffler53" wrote:
> > > > > > > > > > > Thanks Peter,
> > > > > > > > > > > Declan
> > > > > > > > > > > "Peter" wrote:
> > > > > > > > > > > > Hi,
> > > > > > > > > > > > drive.
> > > > > > > > > > > > Global distribution
> > > > > > > > > > > > Content
> > > > > > > > > > > > *caution
> > > > > > > > > > > > Center.
Peter,
Apologies again. I was to post a reply ages ago but I have only got round to
getting the kids PC hooked up to the internet this evening. The phone point
didnt work in their room so I brought it down to my room and connected all.
Anyway I carried out the instructions but to no avail. The problem is that I
cant get rid of the VX2 thingy. I downloaded the tool from lavasoft and ran
it a few times but to no avail.
I reinstalled Adaware and downloaded the VX2 tool again but still no good.
Apart from that issue I ran updates on Spybot and installed and ran the MS
Antispyware and the AVG anti virus programme.
I did detect and delete some other stuff but the old VX2 remains.
If you get this maybe you may have some other ideas
Thanks again
Declan
"Peter" wrote:
> Declan,
> You are welcome.
> Peter
> "muffler53" wrote:
> > Peter,
> > drive.
> > Thanks
> > Declan
> > "Peter" wrote:
> > > Declan,
> > > the kid's PC.
> > > PC)
> > > Peter
> > > "muffler53" wrote:
> > > > Peter,
> > > > like me.
> > > > thanks again
> > > > Declan
> > > > "Peter" wrote:
> > > > > Declan,
> > > > > click Apply and OK
> > > > > Hope it helps.
> > > > > Peter
> > > > > "muffler53" wrote:
> > > > > > Thanks Peter,
> > > > > > get rid of the VX2.
> > > > > > banish the VX2.
> > > > > > regards
> > > > > > Declan
> > > > > > "Peter" wrote:
> > > > > > > Declan,
> > > > > > > Procedures:
> > > > > > > repair folder
> > > > > > > Peter
> > > > > > > "muffler53" wrote:
> > > > > > > > Peter,
> > > > > > > > to a few months ago
> > > > > > > > Declan
> > > > > > > > "Peter" wrote:
> > > > > > > > > Declan,
> > > > > > > > > Peter
> > > > > > > > > "muffler53" wrote:
> > > > > > > > > > Peter,
> > > > > > > > > > Regards
> > > > > > > > > > Declan
> > > > > > > > > > "Dear,customer
> > > > > > > > > > Have a nice day!
> > > > > > > > > > Thank you."
> > > > > > > > > > "Peter" wrote:
> > > > > > > > > > > Declan,
> > > > > > > > > > > Peter
> > > > > > > > > > > "muffler53" wrote:
> > > > > > > > > > > > Thanks Peter,
> > > > > > > > > > > > Declan
> > > > > > > > > > > > "Peter" wrote:
> > > > > > > > > > > > > Hi,
> > > > > > > > > > > > > drive.
> > > > > > > > > > > > > Global distribution
Peter,
Thanks again
Declan
"Peter" wrote:
> Declan,
> You are welcome.
> Peter
> "muffler53" wrote:
> > Peter,
> > drive.
> > Thanks
> > Declan
> > "Peter" wrote:
> > > Declan,
> > > the kid's PC.
> > > PC)
> > > Peter
> > > "muffler53" wrote:
> > > > Peter,
> > > > like me.
> > > > thanks again
> > > > Declan
> > > > "Peter" wrote:
> > > > > Declan,
> > > > > click Apply and OK
> > > > > Hope it helps.
> > > > > Peter
> > > > > "muffler53" wrote:
> > > > > > Thanks Peter,
> > > > > > get rid of the VX2.
> > > > > > banish the VX2.
> > > > > > regards
> > > > > > Declan
> > > > > > "Peter" wrote:
> > > > > > > Declan,
> > > > > > > Procedures:
> > > > > > > repair folder
> > > > > > > Peter
> > > > > > > "muffler53" wrote:
> > > > > > > > Peter,
> > > > > > > > to a few months ago
> > > > > > > > Declan
> > > > > > > > "Peter" wrote:
> > > > > > > > > Declan,
> > > > > > > > > Peter
> > > > > > > > > "muffler53" wrote:
> > > > > > > > > > Peter,
> > > > > > > > > > Regards
> > > > > > > > > > Declan
> > > > > > > > > > "Dear,customer
> > > > > > > > > > Have a nice day!
> > > > > > > > > > Thank you."
> > > > > > > > > > "Peter" wrote:
> > > > > > > > > > > Declan,
> > > > > > > > > > > Peter
> > > > > > > > > > > "muffler53" wrote:
> > > > > > > > > > > > Thanks Peter,
> > > > > > > > > > > > Declan
> > > > > > > > > > > > "Peter" wrote:
> > > > > > > > > > > > > Hi,
> > > > > > > > > > > > > drive.
> > > > > > > > > > > > > Global distribution
Declan,
Pls try download the VX2 cleaner Add-on from lavasoft and run it:
Below is the message from lavasoft in text format, pls post back if you
can't view the information from the above link in html format:
VX2 CLEANER
Lavasoftî–¸ new add-on VX2 Cleaner detects the malware VX2 and offers you the
ability to remove it from your computer. Some users have experienced a very
difficult variant of VX2 which cannot be removed by Ad-Aware. For those users
which have this variant, we have developed an add-on to help you remove this
VX2 variant.
This VX2 variant registers itself in a way, which gives it system
privileges. It also prevents the user from viewing this information by
removing the user’s rights to do so. Furthermore it constantly monitors the
registry and prevents any attempts to remove its associated values. This
makes it very difficult for the user to manually remove it.
The VX2 Cleaner works with all editions of Ad-Aware.
How to use Lavasoftî–¸ VX2 Cleaner add-on
lose Ad-Aware and Ad-Watch (if running)
Download the free VX2 Cleaner here
Install the VX2 Cleaner
tart Ad-Aware
o to dd-ons?br> elect the VX2 Cleaner add-on and click un Tool?br> If
your computer isn’t infected, click “Close�.
If your computer is infected
Select “Clean System�
Reboot your computer
Scan your computer with Ad-Aware
Remove any VX2 objects detected
Reboot your computer again
Run a second scan to make sure the files have been removed from your computer
More information on VX2 can be found in the TAC database
Pls post back to NG for the outcome.
Peter
"muffler53" wrote:
> Peter,
> Thanks again
> Declan
> "Peter" wrote:
> > Declan,
> > You are welcome.
> > Peter
> > "muffler53" wrote:
> > > Peter,
> > > drive.
> > > Thanks
> > > Declan
> > > "Peter" wrote:
> > > > Declan,
> > > > the kid's PC.
> > > > PC)
> > > > Peter
> > > > "muffler53" wrote:
> > > > > Peter,
> > > > > like me.
> > > > > thanks again
> > > > > Declan
> > > > > "Peter" wrote:
> > > > > > Declan,
> > > > > > click Apply and OK
> > > > > > Hope it helps.
> > > > > > Peter
> > > > > > "muffler53" wrote:
> > > > > > > Thanks Peter,
> > > > > > > get rid of the VX2.
> > > > > > > banish the VX2.
> > > > > > > regards
> > > > > > > Declan
> > > > > > > "Peter" wrote:
> > > > > > > > Declan,
> > > > > > > > Procedures:
> > > > > > > > repair folder
> > > > > > > > Peter
> > > > > > > > "muffler53" wrote:
> > > > > > > > > Peter,
> > > > > > > > > to a few months ago
> > > > > > > > > Declan
> > > > > > > > > "Peter" wrote:
> > > > > > > > > > Declan,
> > > > > > > > > > Peter
> > > > > > > > > > "muffler53" wrote:
> > > > > > > > > > > Peter,
> > > > > > > > > > > Regards
> > > > > > > > > > > Declan
> > > > > > > > > > > "Dear,customer
> > > > > > > > > > > Have a nice day!
> > > > > > > > > > > Thank you."
> > > > > > > > > > > "Peter" wrote:
> > > > > > > > > > > > Declan,
> > > > > > > > > > > > Peter
> > > > > > > > > > > > "muffler53" wrote:
> > > > > > > > > > > > > Thanks Peter,
Declan,
VX2 CLEANER
VX2 variant.
tart Ad-Aware
Peter
"muffler53" wrote:
> Peter,
> Thanks again
> Declan
> "Peter" wrote:
> > Declan,
> > You are welcome.
> > Peter
> > "muffler53" wrote:
> > > Peter,
> > > drive.
> > > Thanks
> > > Declan
> > > "Peter" wrote:
> > > > Declan,
> > > > the kid's PC.
> > > > PC)
> > > > Peter
> > > > "muffler53" wrote:
> > > > > Peter,
> > > > > like me.
> > > > > thanks again
> > > > > Declan
> > > > > "Peter" wrote:
> > > > > > Declan,
> > > > > > click Apply and OK
> > > > > > Hope it helps.
> > > > > > Peter
> > > > > > "muffler53" wrote:
> > > > > > > Thanks Peter,
> > > > > > > get rid of the VX2.
> > > > > > > banish the VX2.
> > > > > > > regards
> > > > > > > Declan
> > > > > > > "Peter" wrote:
> > > > > > > > Declan,
> > > > > > > > Procedures:
> > > > > > > > repair folder
> > > > > > > > Peter
> > > > > > > > "muffler53" wrote:
> > > > > > > > > Peter,
> > > > > > > > > to a few months ago
> > > > > > > > > Declan
> > > > > > > > > "Peter" wrote:
> > > > > > > > > > Declan,
> > > > > > > > > > Peter
> > > > > > > > > > "muffler53" wrote:
> > > > > > > > > > > Peter,
> > > > > > > > > > > Regards
> > > > > > > > > > > Declan
> > > > > > > > > > > "Dear,customer
> > > > > > > > > > > Have a nice day!
> > > > > > > > > > > Thank you."
> > > > > > > > > > > "Peter" wrote:
> > > > > > > > > > > > Declan,
> > > > > > > > > > > > Peter
> > > > > > > > > > > > "muffler53" wrote:
> > > > > > > > > > > > > Thanks Peter,
Related ressources:
- ForumPioneer 106S DVD-ROM problem
- ForumDVD rom Problem with windows 8, Help !
- ForumNewbie - DVD Rom problem
- ForumProblem Installing DVD rom /drive in media bay Dell inspiro..
- ForumWin2000 Problem - DVD-Rom
- ForumDVD-ROM Problem
- ForumHelp - Anyone got a DVD ROM (LG,8080DRN) working on a Dell..
- ForumDVD-Rom no longer reading DVDs
- ForumTrouble with DVD Rom and Win 7
- ForumASUS P8Z77-V Problem . Finds hard drive, but not DVD-ROM
- ForumDVD rom notworking
- ForumDVD /CD Rom won\'t read any discs
- ForumWhat is the problem of DVD rom hide after installation in window 7
- ForumPCMCIA slots need more power??? HELP!
- ForumI met a big problem!!!!
- More resources
Read discussions in other Windows XP categories
