Archived from groups: comp.periphs.printers (More info?)
Hi.
My HP printer recently stopped working. On power-up it emmits a loud
hum and then goes into an error state. So I pulled the thing apart
and isolated the problem to the spittoon mechanism. What seems to be
happening is the carriage that's driven by the attached motor and
gears gets to the end of its travel but the motor still wants to drive
it. Ergo, the noise. If I manually reset the gear-driven carriage
and then cycle the power I get the familiar start up sound as the
carriage is driven through its normal travel but then the motor again
tried to drive it forward past its stop.
So I figure either the electronics that control the motor are
defective or the motor itself is defective (i.e., not reversing).
Does any kind soul know if:
1) This is a common problem with a known solution?
2) If these sort of parts are even available?
On 2), I gather from other past posts that HP parts can be hard to
get. I went to their parts web site which was quite helpful in
identifying part names (such as spittoon) but when I clicked on them,
most were unavailable.
"Jim Schlemmer" <schlamalio@yahoo.com> wrote in message
news:e3b7c264.0407120758.6419f14b@posting.google.com...
> Hi.
I had a HP882 which was replaced with a much better printer, a Canon
i850. When the 882 was replaced I took the 882 apart so I know something
of its construction. The motor in the HP882 is a 2 wire DC motor run
in servo mode. Since the motor moves your carriage, the motor is good.
Your problem is either the carriage is blocked at end of travel and
does not reach its home position, or the sensor that detects the home
position is most likely dirty or defective. The noise is the motor trying
to drive the carriage home. The error message is the carriage was not
detected as being home in a prescribed time.
Thanks, Ray. I'll have a look to see if I can locate the sensor. I
didn't notice any wires going anywhere except to the motor. However,
the entire area is pretty gunked up and so a thorough cleaning would
be in order at any rate.
I believe I have experienced similar problems with a deskjet 550c.
On alternate power ups, the carriage mechanism goes through a warm up cycle
then emits a kind of doyng/clang noise. Turn off and on and it sets up
normally.
The printer runs like this for maybe 6 months, then it won't start, just
doyng/clangs with every power up.
I then remove the motor which holds and lowers the cartridge housing, make
sure everything is free, re-fit the motor and (hopefully) it operates, every
other switch on, for another 6 months!
