Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > "Installing COM component" window on bootup -- help?
Forum Windows XP : Windows XP General Discussion - "Installing COM component" window on bootup -- help?
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
Every few times I boot or restart, I get a small pop-up window near
the end of the bootup with the heading "Installing COM Component". In the
box is "activex.microsoft.com", and a progress bar, which never starts. The
window just sits there; if I close it, I get the warning "Canceling will
likely result in failure of the current operation."
I have no idea what this is, why it's sporadically appearing, or what to do
with it. It's been going on quite a while, and I can't pinpoint its starting
to any changes on my system, or any added hardware.
Can anyone help?
Thanks very much.
Sponsored Links
I know this is old, but there are not very many results when trying to fix this and I frequently ran across this post when searching. I want the fix to be listed here.
Follow this link:
http://support.microsoft.com/kb/323207
Basically disable the registry key it refers to. I put a ; at the very beginning of the line to do it.
Good luck all
Reply to Noodlewad
- 0 +
I know it's 2 years later, but I'm having the same problem as the OP at the moment. Like was said in the last post, I frequently ran across this post when searching. This is the only place where a fix was given.
My question is, how do I disable the registry key?
I read the link you posted, but I couldn't really understand it. It was all a bit over my head.
Hopefully someone will seee this post, it's really frustrating.
Thanks in advance...
Reply to bren_02
There are 1128 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
