problems installing sata as second drive
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
The drive shows up in the boot process but not once I am in windows?
See you Later, here, there, or in the air
Keith
9 answers Last reply
More about problems installing sata drive
  1. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    So much for detailed information...If running xp on a IDE controller,try
    downloading and installing the drivers/software for the SATA controller from
    the mfg web site.
    > Keith
  2. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Sorry about the lack of info
    Asus k8v board, brand new WD 200 gig sata hard drive, existing 200 gig
    Seagate eide with winxp home, system runs fine just need more storage.
    Already been to asus site got the newest drivers. It is not that it is not
    operating, the problem is that once I am in windows the system does not show
    the new drive( no drive letter) to work with it, but it does show during the
    boot process. So just for the record I want this as a second drive I don't
    want to install my os on it, I just need this for storage.
    Keith
    "Andrew E." <eckrichco@msn.com> wrote in message
    news:0CD9AA9F-75F2-4B75-9907-84731603562F@microsoft.com...
    from
    > the mfg web site.
    > > Keith
  3. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    It is a modesty problem: that naked HD must have a layer of clothing added,
    or XP will pretend to not see it. ;-)
    With the new HD connected, boot XP and head for the disk management window
    to initialize the new HD.
    Cheers, Bob
  4. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Love you new age sensitivity Bob.
    To open Computer Management, click Start, and then click Control Panel.
    Double-click Administrative Tools, and then double-click Computer Management.
    You must be logged on as an administrator or a member of the Administrators
    group in order to complete this procedure.
    If your computer is connected to a network, network policy settings might
    also prevent you from completing this procedure.
    New disks appear as Not Initialized [cannot be viewed in My Computer].
    Before you can use a disk, you must first initialize it.
    If you start Disk Management after adding a disk, the Initialize Disk Wizard
    appears so you can initialize the disk.
    > Cheers, Bob
  5. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    disk management does not show my new drive.
    Keith
    "Bob Willard" <BobwBSGS@TrashThis.comcast.net> wrote in message
    news:enOjIO9TFHA.1040@TK2MSFTNGP10.phx.gbl...
    not
    show
    the
    don't
    added,
    > Cheers, Bob
  6. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Have you installed the SATA drivers (may be called RAID drivers) for
    your SATA controller (either a card, or the SATA controller on your
    MB)? Without those, XP will rarely be able to see a SATA drive.
    >Keith
    >not
    >show
    >the
    >don't
    >added,
    >> Cheers, Bob
  7. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Tried twice give me the run down to make sure I am doing it right
    "NobodyMan" <none@none.net> wrote in message
    news:dt6g711v6oefs1k0gopdh7vlfatqqhhotu@4ax.com...
    > >Keith
    gig
    storage.
    is
    > >not
    not
    > >show
    during
    > >the
    > >don't
    > >added,
    window
    > >> Cheers, Bob
  8. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    1. Your mainboard should have come with a driver CD. Put it in your
    CDROM drive, find the option for SATA (maybe labeled RAID) drivers,
    and run it. If this is an add-on SATA card, it should have come with
    drivers as well.
    2. No CDROM? Go to the mainboard manufacturers site (or, if an
    add-on card, the manufacturer for it) and download the drivers.
    Install them as above.
    If you are trying to set up XP using a SATA drive as the boot drive,
    you'll need to place the drivers on a floppy. When setup starts,
    press F6 as directed to load RAID drivers, use that floppy, and then
    let setup continue.
    >> >Keith
    >gig
    >storage.
    >is
    >> >not
    >not
    >> >show
    >during
    >> >the
    >> >don't
    >> >added,
    >window
    >> >> Cheers, Bob
  9. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Thanks for the help everyone!
    Turns out the asus drivers did not work but I went to via ( my chipset) and
    they worked perfectly.
    news:olvi719nn942r1h4ii2r2a093v2he91sa6@4ax.com...
    > drivers as well.
    > let setup continue.
    >>> >Keith
    >>gig
    >>storage.
    >>> >> > it
    >>is
    >>> >not
    >>not
    >>> >show
    >>during
    >>> >the
    >>> >> > I
    >>> >don't
    >>> >added,
    >>window
    >>> >> Cheers, Bob
Hardware SATA Microsoft Windows XP
