CD Rom drive problem Registry/bios
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
I'm trying to fix the problem with my HP Pavillion 751.
It has a drive D dvd and a drive E CD Rom.
When I put a disk in it gives a message: "please insert a disk in Drive E"
(doesn't detect it)
I'm working through a support article from HP. Previously I tried a step
where you uninstall the driver and delete some entries from the registry and
then start it up again to let it redetect.
Click the plus sign (+) next to the following items in the listed order:
§ HKEY_LOCAL_MACHINE
§ SYSTEM
§ CurrentControlSet (or the current control set with lowest number if
that is all that is listed)
§ Control
§ Class
Select 4D36E965-E325-11CE-BFC1-08002BE10318.
[There are 3 subfolders here 0000> Digital Audio, 0001 > DigitalAudio (has
same data) and Properties]
It lists DVD/CD Rom drive and below CDRom drive in the right window
e. Select UpperFilter in the right window and press the Delete key.
Confirm the deletion by clicking Yes.
(can't see any Upper filter)
f. Select LowerFilters in the right window and press the Delete key.
It lists "LowerFilters" > pxhelp 20 mxlW2k (not sure if that's what they
are talking about)
g. Close the registry editor, restart the computer, and
wait until Windows configures the necessary drivers for new hardware
I looked in BIOS
Primary Master: Samsung SV8004H
Primary Slave [None]
Secondary Master [HP]
Secondary Master Samsung CD Rom
Thanks for your help
John
2 answers Last reply
More about drive problem registry bios
  1. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Actually thats not correct,youre area in regedit needs to
    be:HKEY_LOCAL_MACHINE
    software/microsoft/windows/set-up then open source path.The letter listed for
    the cdrom probably is diffrent then whats listed it as in my
    computer,L.click on
    the hardware,go to edit,modify,change to correct letter as it shows in my
    computer
    then close out regedit.
    > (doesn't detect it)
    > § SYSTEM
    > § Control
    > § Class
    > are talking about)
    > I looked in BIOS
    > John
  2. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    I have found HKEY_LOCAL_MACHINE software/microsoft/windows/current
    version/setup
    It has a CDInstall Reg D Word 0000etc (0)
    Source path is C:\Windows\1386?
    Thanks
    John
    "Andrew E." <eckrichco@msn.com> wrote in message
    news:6F094381-0E76-43E4-AFEF-8B4B5614D945@microsoft.com...
    > for
    > computer,L.click on
    > computer
    >> E"
    >> (doesn't detect it)
    >> and
    >> § SYSTEM
    >> § Control
    >> § Class
    >> (has
    >> key.
    >> are talking about)
    >> I looked in BIOS
    >> John
Hewlett Packard CD-Rom Windows XP
