Archived from groups: microsoft.public.windowsxp.hardware (
More info?)
Hi Carey:
You are right on target!
I finally found an article at a website that recommended turning off
(Disabling) your AV at shutdown and sure enough Norton AV was causing the
problem. Luckily it only happens after I have used the "A" floppy drive and
not all the time. Just will have to remember to disable NAV etc after I have
used the "A" drive.
Thanks for your timely and accurate reply.
Tom
"Carey Frisch [MVP]" <cnfrisch@nospamgmail.com> wrote in message
news:%23FxSb0cUFHA.628@tk2msftngp13.phx.gbl...
> It's likely your antivirus program is accessing the
> floppy drive, checking for viruses. This is normal.
> Carey Frisch
> Microsoft MVP
> Windows XP - Shell/User
> Microsoft Newsgroups
> Get Windows XP Service Pack 2 with Advanced Security Technologies:
http://www.microsoft.com/athome/security/protect/windowsxp/choose.mspx
> "ColTom2" wrote:
> | Hi:
> | I have a Sony RX860 desktop and recently when I use the floppy "A"
> drive
> | it makes a repetitive "tat."tat","tat" etc type noise on shutdown.
> | Everything works fine except for this noise for a few seconds that
> happens
> | on shutdown after I have used the floppy drive.
> | Any ideas as to cause and prevention will be appreciated.
> | Thanks
> avast! Antivirus: Outbound message clean.
> Virus Database (VPS): 0518-3, 05/04/2005
> Tested on: 5/5/2005 6:49:47 PM
> avast! - copyright (c) 1988-2005 ALWIL Software.
http://www.avast.com
