3 blown Power supply's in 6 months.
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
Hi all,
I have a P.C. that keeps blowing power supply's.
It is P4 2.4, Gigabyte GA-8IG100MK Main Board in a "whitebox" of
unknown make.
Low spec AGP video card
2 x Optical drives
1 x 80gig Seagate Barracuda
The last power supply it blew was a Unicase 400W Silent power supply.
I has been plugged into a middle of the road surge protector the whole
time (which seems to fine.)
This has all happened in the same house; however there hasn't been any
other power problems.
I'm thinking maybe it's the case because the problems happend when the
unit is being switched o every time.
Anyone else seen something like this?
TIA
Rob
57 answers Last reply
More about blown power supply months
  1. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Is the line power, from the electric company stable and
    clean (no spikes, surges) ? Do you have any other
    electrical problems? Is the computer on a circuit that is
    isolated from heavy draw items such as motors (air
    conditioners, washing machines) or do you see any
    fluctuation in the lights?
    Have you tried a "name brand" PSU from a company such as PC
    Power & Cooling or Antec?
    The people think the Constitution protects their rights;
    But government sees it as an obstacle to be overcome.
    "RobW" <none@none.com> wrote in message
    news:ka6u71tqclh24kaekdbd9d33n1i3eb09tt@4ax.com...
    | Hi all,
    "whitebox" of
    | unknown make.
    | 2 x Optical drives
    power supply.
    protector the whole
    hasn't been any
    happend when the
    | TIA
    | Rob
  2. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Try another powercable it might have a faulty fuse.
    "RobW" wrote:
    > Hi all,
    > unknown make.
    > 2 x Optical drives
    > TIA
    > Rob
  3. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    The "common" middle of the road surge protector can only handle ONE/TWO
    surges. After this, the surge protection does not exist!
    Your power in your room/office is definiately BAD! You are going to have
    problems like this forever. The only true ways to fix this are:
    1) Call an electrician and have them put in an "isolated" power circuit for
    your PC. (Expensive!!!)
    2) Buy an line conditioning power regulator, or a UPS. These type of units
    will "filter" the power so that the out-bound power is with-in the "safe"
    range of the power supplies.
    And, always use a 'name-brand' power supply. Antec and Enermax always use
    "good" components in their PSUs and the PSUs are mostly correctly rated for
    their WATTAGE. Generic PSUs are not worth the monet when the power is
    "dirty".
    > Hi all,
    > unknown make.
    > 2 x Optical drives
    > TIA
    > Rob
  4. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    One more option to check. Make sure the PSU is set for the correct incoming
    voltage. There is a red switch to set for 110/120 or 220/240.
    "RobW" wrote:
    > Hi all,
    > unknown make.
    > 2 x Optical drives
    > TIA
    > Rob
  5. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    In article <10BC4506-70D3-4ED8-96C2-4D116A62B9D4@microsoft.com>,
    JDee@discussions.microsoft.com says...
    Power cables don't have fuses, at least not the ones I've seen connected
    to computers in the US.
    If you are killing PSU's and you are SURE THE INCOMMING POWER IS
    GOOD/Clean, then you've got a device inside the computer that's
    overloading the PSU.
    You need to determine what part of the PSU is dead - is it a fuse on one
    of the DC lines or one the AC of the PSU or something else.
    Your spec's don't seem to need more than 350W would provide, but you
    could have a shorted/intermittent connection where the screws mounting
    the motherboard connect to the chassis - many times the installer will
    not use the proper screw size (screw heads) and will short a trace
    without knowing it's been done.
    Disconnect everything, reseat the computers motherboard on the chassis,
    make sure that every mounting post is accounted for and that none are
    shorting out traces on the board, same for the screws.
    I've also seen power leads (for drives) without a cap over them short
    out on the metal parts of a case and blow a PSU.
    spam999free@rrohio.com
    remove 999 in order to email me
  6. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    im from UK and every power cable has to have a fuse in UK so suppose it
    depends where your from. if you use fuses it could well be a problem.
  7. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    In article <AFADA9D7-AC21-4ACF-B079-8D9F8853EA97@microsoft.com>,
    I agree then, not knowing where the OP was from, it's a good assumption
    to guess at the fused power cord if his country requires such.
  8. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Fuses don't protect electronics. After something electronic
    has failed, a fuse may blow. This so the hardware failure
    does not result in harm to humans. Do you think a fuse blows
    to protect electronics? Electricity. First it flows through
    everything in a circuit. Only then does something blow after
    everything has been exposed to the same current flow. A 13
    amp fuse is going to blow because more than 3 amps flowed
    through a component rated only for 2 amps? Only when the 2
    amp component shorts and starts drawing more like 13 amps.
  9. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    "J-Dee" <JDee@discussions.microsoft.com> wrote in message
    news:AFADA9D7-AC21-4ACF-B079-8D9F8853EA97@microsoft.com...
    > it
    If that is true then the fuse needs to be the slow-blow type. The
    sudden burst of amps surging through a normal fuse could easily blow it
    when the computer is powered on. The slow-blow fuse will prevent it
    from opening for a short one-time surge. However, if the fuse in the
    power cord blew then the OP would be asking why he has to keep replacing
    power cords or the fuses in them. He is saying that he is replacing
    PSUs. Even if he replaced the PSU, it wouldn't work until he replaced
    the power cord fuse, so he would've still mentioned having to replace
    fuses. Doesn't sound like it is a fuse problem.
    ____________________________________________________________
    ** Post your replies to the newsgroup - Share with others **
    For e-mail Reply: remove "DELETE", add "~VN56~" to Subject.
  10. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Tom
    Take a look at this..
    http://www.littelfuse.com/cgi-bin/r.cgi/application/Computer/3.html?LFSESSION=oNm8TFzMb5
    Fuses are not just found in domestic, industrial and automotive power supply
    lines..
    Mike Hall
    MVP - Windows Shell/User
    http://dts-l.org/goodpost.htm
    "w_tom" <w_tom1@hotmail.com> wrote in message
    news:427F6A46.BE6CE8F7@hotmail.com...
    >> > connected
    >> > one
  11. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Why did you provide a URL for circuit protection devices?
    Those are not fuses? Did you assume that because it is a
    Littelfuse product, then it must be a fuse? Or did you first
    review the datasheets before posting? Cited are applications
    for circuit protection devices .... which are not fuses.
    Circuit protector devices and fuses are not the same
    device. You have claims a device called TMOV is a fuse. That
    is wrong. Go back and learn about TMOVs ... "available in 14
    and 20 mm disc size with and without a monitor lead (to alert
    you that the thermal element has opened). The 14 mm parts are
    rated to 6kA and the 20 mm parts are rated to 10kA." Do you
    claim these "6,000 and 10,000 amp fuses" would stop electronic
    damage?
    Again, fuses blow after the electronic damage has happened
    so that the human is not put at risk. This being basic
    electrical knowledge that even a computer assembler should
    know.
    > power supply lines..
  12. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    In article <427F9404.C731F0AE@hotmail.com>, w_tom1@hotmail.com says...
    > know.
    Sorry, the fuse it sized to prevent damage to the lines/devices, not to
    blow after the device has been damaged (although that may also happen).
    The fuse is sized to protect some part of the device, be it power lines,
    transformers, etc....
  13. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Tom
    A fuse does NOT exist purely to save human life.. the fuses inside a hi-fi
    power amplifier or CB or computer power supply are there to protect
    circuits.. some will be fast blow, some will be slow blow, and some are
    thermal types..
    Note also that automotive fuses do NOT exist to save human life.. and if you
    had followed any links on the URL given to you, that would have become
    patently clear to you too..
    Mike Hall
    news:427F9404.C731F0AE@hotmail.com...
    > damage?
    > know.
  14. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    And again, fuse designed to blow so that "damage to the
    lines/devices" created by component failure does not threaten
    human life. Any device whose destruction can harm humans will
    be disconnected by fuses and other equivalent 'one shot'
    devices. The fuse is not installed to protect hardware. In
    the process of protecting humans, a fuse may protect some
    hardware - ie a power cord. But fuses are installed to
    protect humans. Any protected hardware is incidental.
    When a fuse blows in a power supply, a failed component
    often causes that open fuse. Even shorting all power supply
    outputs would not blow a fuse. The concept is called
    fold-back current limiting. The fuse is for human
    protection. It blows typically because a component inside the
    supply has failed. Furthermore many power supplies don't use
    fuses. Such human protection is found elsewhere in the power
    supply design making the fuse unnecessary.
    >> know.
  15. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Fuses are rated by amps and time and are intended to open
    the circuit before the wires emits smoke. In other words,
    the fuse must blow before a fire starts. There are fast
    fuses that protect some electronic circuits in devices such
    as the resistance (ohms) circuit in a voltmeter.
    There are also slow-blow fuses for use with motors.
    There are ground fault detectors and there are Hall Effect
    sensors which can detect problems in circuits.
    One thing that the OP needs to tell, under what condition
    and how fast does the PSU blow, does it work at all and
    sometimes fail, or does it always fail immediately?
    "Leythos" <void@nowhere.lan> wrote in message
    news:MPG.1ce9666e70ec256d9896af@news-server.columbus.rr.com...
    happened
    should
    | > know.
    also happen).
    it power lines,
  16. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Hell. There were times in my past career when I would not even fuse a 10HP
    440/460V motor. I would rather have it burn up than have a fuse blow at an
    inopportune time. Example: an emergency ventilator in an explosive
    atmosphere. When the LFL (lower flammability limit) reached 7.5% that motor
    came on and ran until the environment was again safe or the motor destroyed
    itself because of "whatever"!
    Regards,
    Richard Urban
    aka Crusty (-: Old B@stard :-)
    If you knew as much as you think you know,
    You would realize that you don't know what you thought you knew!
    "Mike Hall (MS-MVP)" <mike.hall.mail@sympatico.ca> wrote in message
    news:u3fxqPMVFHA.3244@TK2MSFTNGP15.phx.gbl...
    > Tom
    > thermal types..
    > you had followed any links on the URL given to you, that would have become
    > Mike Hall
    >> damage?
    >> know.
  17. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    In article <427F9B3D.BA1F6643@hotmail.com>, w_tom1@hotmail.com says...
    That depends on the power supply design, but in most switched power
    supply designs you are correct, they can sustain a shorted output for a
    sustained period.
  18. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    As an industrial electrical designer (large industrial ovens and furnaces) I
    always design and fuse for the protection of the device.
    > >> know.
  19. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    In article <AA9BE454-262A-4023-9FDF-251B39F5CEEF@microsoft.com>,
    Falcon@discussions.microsoft.com says...
    As a designer that's worked in the industrial sector for almost 2
    decades, I also spec fuses/breakers for the protection of the wiring and
    device depending on the application. I don't recall ever fusing for
    protection of personnel.
    All the breakers in my SD panel in my home are sized based on the wire
    gauge and not the devices connected to wiring. All of the fuses in the
    non-switching PSU's I've used and or build were sized to protect the PSU
    itself (components).
    Wonder what else he's going to try and tell us this time.
  20. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    In article <uxAX0VMVFHA.616@TK2MSFTNGP12.phx.gbl>, <Vanguard> says...
    > > it
    Actually the OP stated, later, that he found a fuse blown inside the PSU
    once he opened it.
  21. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Another human life saved.. wow..
    Mike Hall
    news:MPG.1ce978dfea9f8d829896b3@news-server.columbus.rr.com...
    >> > it
    > once he opened it.
  22. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    In article <ek3F7XMVFHA.2664@TK2MSFTNGP15.phx.gbl>,
    richardurbanREMOVETHIS@hotmail.com says...
    That's not right, if the motor is drawing too much current, there is a
    reason, and continued running will generate excessive heat, which is
    worse on a vent for an explosive environment. Heck, even the heaters
    could kick-out a motor before the fuses did in some cases - where the
    fuses were sized wrong.
  23. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    I would have wanted to have the motor draw too much current, and run for
    another minute. That could be the difference between a massive explosion and
    loss of human life OR the opportunity for the plant personnel to vacate!
    Regards,
    Richard Urban
    news:MPG.1ce97a9593718fd49896b5@news-server.columbus.rr.com...
    >> 10HP
    >> an
    >> motor
    >> destroyed
  24. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    In article <uzIQQhMVFHA.2768@tk2msftngp13.phx.gbl>,
    I would have been afraid that the load could be caused by a shaft
    bearing or some other physical condition that could lead to
    sparks/excessive heat.
    We used double exhaust systems in our grain systems, same in the cement
    systems, in case one purge system didn't work.
  25. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    We designed in double and triple redundancy, but the final safety stage ran
    till the last outcome - whatever that may have been!
    Man, I would have hated to have to tell 20 widows and widowers that their
    loved ones were dead because a $3.00 fuse blew and the exhauster went single
    phase at 1/3 speed!
    Regards,
    Richard Urban
    news:MPG.1ce9821b3e0cffe49896b7@news-server.columbus.rr.com...
    >> and
  26. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    In article <OBWKXrMVFHA.3292@TK2MSFTNGP14.phx.gbl>,
    mike.hall.mail@sympatico.ca says...
    Mike, just in case you misunderstood my reply, I was also agreeing with
    you. I've not seen much out of Tom that makes sense.
  27. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    He's out checking his books now (-:
    Regards,
    Richard Urban
    news:MPG.1ce982886ba079469896b8@news-server.columbus.rr.com...
  28. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    I didn't misunderstand.. :-)
    I was just so glad that the little fuse in the PS saved a life, is all.. lol
    Mike Hall
  29. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    In article <#DBYC6MVFHA.3636@TK2MSFTNGP14.phx.gbl>,
    Yea, it was funny of him to tell me and a couple others that UPS's don't
    protect from surges/transients, and then change the story to cheap UPS's
    is what he meant.
  30. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Yes, I saw that!
    Regards,
    Richard Urban
    news:MPG.1ce9886b877990129896ba@news-server.columbus.rr.com...
    > is what he meant.
  31. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Being a former electrician your AC circuit is not grounded. No amount of
    surge protection will help you . Surge protectors rely mainly on the
    circuits ground fault to discharge a surge in the line when it happens.
    Peter
    Please reply to newsgroup for the benefit of others.
    > Hi all,
    > unknown make.
    > 2 x Optical drives
    > TIA
    > Rob
  32. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    On Mon, 9 May 2005 04:39:39 -0500, "Jim Macklin"
    Hi Jim,
    Generally speaking the power from the electrical company is good.
    No other electrical probs.
    No heavy draw or fluctuation of lights either.
    I haven't tried a name brand PSU as I have been too frightened it will
    get fried like the others. Also, up to this point the supplier has
    been replacing the PSU's under warranty.
    They will no longer do this, :-) lol.
    I'm really wondering if it is a problem with the case.
    Especially since the damage seems to be happening when switching on
    the machine.
    Cheers.
    Rob
  33. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    I pulled the case and found a fuse that now resembles a used
    firecracker which I guess came out of the PSU. (the PSU has a bottom
    intake fan with large gaps).
    I am going to take Leythos's suggestion and investigate which fuse on
    the PSU is blown. I may have to get someone who knows what they are
    looking at to examine it, :-).
    I am in Australia and the mains is 240VAC.
    The power leads have no fuses.
    Thanks again and I will post the outcome for anyone who is interested.
    Rob
  34. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Be careful poking around with/in power supplies, there are
    rather large capacitors inside that can hold a lethal charge
    for some time (weeks perhaps) and they need to be properly
    discharged before you try to work inside. They will also
    fry any meter you connect checking for resistance.
    You can check for a shorted screw by using a DVM set to
    resistance (ohms) and checking for continuity (0 ohms) where
    the parts should be grounded together, or infinite
    resistance between electric circuits and the case.
    news:73ru71p7dvmje37fag1hskidvu34m30jv2@4ax.com...
    used
    has a bottom
    which fuse on
    they are
    interested.
    | Rob
    | >In article
    UK so suppose it
    be a problem.
    good assumption
    such.
    | >> "Leythos" wrote:
    | >> > In article
    I've seen connected
    INCOMMING POWER IS
    computer that's
    is it a fuse on one
    else.
    provide, but you
    the screws mounting
    the installer will
    short a trace
    and that none are
    screws.
    over them short
  35. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    That fuse usually means you are drawing too many amps from the PSU. You
    are overheating and overloading the PSU. See my other post regarding
    the use of cheapie power supplies and why you cannot simply rely on the
    stickered wattage rating. It also shows that you are using cheapie
    PSUs. The better ones use a reset circuit that will reset after awhile
    (when the heat dissipates). A fuse is cheaper.
  36. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    In article <u#p6bgKVFHA.2520@TK2MSFTNGP09.phx.gbl>, p51mustang[threeX12]
    @xxxhotmail.calm says...
    Most computer PSU's use CAPS on the DC side and they don't have more
    than 20+ VDC on most of them, the caps will also discharge in a short
    amount of time due to the way a PSU is designed.
    Now, if we were talking the HV circuit of a monitor/TV, I would agree
    with you completely.
    As with anything electrical - always disconnect power before working on
    it and make sure there are no unsafe powers still available.
    The screw, also connected to the chassis, should be a short to the power
    supply ground, at least the screw eyes in many boards are also grounding
    pads and will be the same as DC ground for the PSU. In many cases, due
    to capacitors and other devices you can't get an infinite ohms reading
    testing like you describe.
    The best method is to take the motherboard back out of the case and see
    if it's been improperly installed.
    Since he mentioned a blown fuse inside the PSU, it would stand to reason
    (since he said it's not on the AC Side) that he has an intermittent
    short somewhere - as in a case/screw or wire missing insulation.
  37. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    In article <OvhjkzMVFHA.2124@TK2MSFTNGP14.phx.gbl>,
    > When I was in Electronic school, courtesy of the Navy, we were in our 3
    > phase section of training. We each had out own work module and fuse box.
    > After coming back from coffee break one day a young fella a few seats down
    > picks up the three phase leads and says "I wonder if these are hot?". He
    > then touched two of the phases together. He woke up 3 days later in
    > intensive care.
    I was in AT (Avation Electronics Technician) training in Memphis around
    84, I saw things like that once in a while during my 3 months there :)
  38. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Why do codes call for protection of that wire? A wire
    destroyed by too much current causes fire. Fires threaten
    humans. The wire is protected by fuse firstmost because a hot
    and burned wire creates a threat to human life. We are not
    first worried about the wire. We first worry about the
    human. A primary function of fusing is protecting humans from
    failure. Fuse may perform other secondary functions. But its
    primary purpose as even defined by codes is human protection.
    Fuses typically blow after hardware has failed. Fuses
    typically do not just protect hardware.
    Why would that fuse inside his power supply blow? Hardware
    damage has already occurred. Did the fuse protect the power
    supply from damage. Not likely. The fuse blew after damage
    existed.
    Next you will tell us how some UPS provides protection that
    its own manufacturer does not even claim to provide.
  39. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Why do we fuse vehicles wires? Fuse also protects those
    wires. But again, the primary purpose is to avoid car fires -
    a threat to human life. Overloaded wires cause fires - a
    threat to human life inside that car.
    What happens if the power amplifier outputs excessive
    power. Well clearly something inside that amp has already
    failed. The fuse did not protect from the failure. It is
    simply disconnecting as a result of the failure. Maybe it
    will protect more transistors from failing in succession. But
    a failure existed before the fuse blew.
    The fuse blows typically when hardware has already failed.
    #1 reason for fuses? Human safety. Why do we fuse to protect
    wires? Again, number one reason to is avoid wire fires -
    human safety.
    Your links were for circuit protection devices such as TMOVs
    - not for fuses. Circuit protection devices are not fuses.
    > a hi-fi power amplifier or CB or computer power supply are there
    > to protect circuits.. some will be fast blow, some will be slow
    > blow, and some are thermal types..
    > and if you had followed any links on the URL given to you, that
    > would have become patently clear to you too..
  40. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Right. You protect the DEVICE, which in turn may save someone's life - or
    not!
    I have NEVER seen a fuse protected device prevent someone from getting
    electrocuted if he stuck his hand in the control panel and grabbed a 220v
    terminal, have you?
    Therefore, a fuse does not protect human life directly. The human protection
    is ancillary to protecting the DEVICE!
    Regards,
    Richard Urban
    news:4280EA60.5420BCE0@hotmail.com...
    > existed.
  41. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    I said fuses protect human life. I did not say humans will
    always be protected by fuses. But when a fuse blows, its
    number one purpose is so that humans are not harmed.
    Fuses are installed to protect humans. That does not mean
    fuse will protection human from falling in the shower. That
    does not mean a fuse always protects humans. But still fuse's
    primary purpose as even defined by code is to protect the
    human.
    Returning to the original point - the fuse in a power
    supply blows because hardware has failed. The fuse did not
    stop hardware failure. It will stop further damage (ie fire)
    as a result of that failure. Its' #1 purpose - to protect
    human life. Protecting additional hardware may be ancillary
    to its primary purpose often because that ancillary function
    is necessary to protect human life. But a fuse did not stop
    power supply damage. The damage occurred. Then the fuse blew.
    A line cord fuse as used in UK does not protect the
    hardware. If blows after damage has occurred. So that damage
    does not harm humans, the fuse blows.
    > life - or not!
    > getting electrocuted if he stuck his hand in the control panel
    > and grabbed a 220v terminal, have you?
    > protection is ancillary to protecting the DEVICE!
  42. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Good show. Thanks to powers that be (ie Mickey Mouse), you
    can now demand royalties for something like seventy five years
    - unless someone with deep pockets decides to sue. But then
    that is a different 'human safety' issue using different
    protection devices.
    > Hey! That phrase was copyrighted. You may send your check
    > to..................... (-:
  43. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    In article <4280EA60.5420BCE0@hotmail.com>, w_tom1@hotmail.com says...
    > existed.
    You are such a lamer. The fuse blew because the load was greater than
    the rated value of the fuse for a longer period that the rated time for
    the load.
    It has nothing to do with Damage, it could simply have been an
    undersized fuse in a product lot/batch or it could be an over-loaded
    power supply, or a peripheral in the throws of going bad (but not
    "damaged").
    I don't have to tell you anything, you know it all, and I've never
    stated that a UPS does anything in relation to the vendors documents,
    I've only made my many years of using quality UPS devices in the
    experience of many conditions present in this group.
  44. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    A few basic facts that Leythos forgets. Overloaded power
    supplies have dedicated functions to protect themselves AND
    without damage. And without using fuses. This function was
    industry standard even 35 years ago. Industry standards even
    demand it. The overloaded power supply must work just fine -
    no parts replaced - after the overload is removed.
    No fuse to protect power supply hardware from overloading.
    There may be fuses to stop a wire fire. But Leythos again
    demonstrates knowledge before learning facts. Power supplies
    (and stereo power amps) contain internal protetion so that
    overloading does not damage the equipment. Fuses are too
    crude to accomplish that task. But a fuse can eliminate fires
    that might harm humans after semiconductor failure has
    occurred.
    "Lamer" - Leythos is again demonstrating a wealth of
    supporting technical facts - complete with numbers. Just what
    I would expect from junk science reasoning.
    > the load.
    > "damaged").
  45. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Boy, you do have a one track mind. Perchance did you screw up years ago
    while you were learning and severely cause injury, or worse, to someone!
    That would explain it.
    Regards,
    Richard Urban
    news:42813C09.77B7274E@hotmail.com...
    > protection devices.
  46. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Problem of using fuses for hardware protection is their very
    wide range of 'protection'. To appreciate the problem, learn
    about the well understood I^2t curve. For example,
    semiconductor devices will fail in microseconds. A
    microseconds transient that exceeds the fuse current ratings
    by factors of tens will not even blow the fuse. The fuse
    takes tens of milliseconds (or longer) to blow. Fuse only
    blows long after damage has occurred.
    Fuses will do better on equipment that can take massive
    overcurrent for a long times, such as large motors.
    Review the numbers. For example, a 20 Amp fuse for
    automotive protection would conduct 100 amps for 0.5 seconds
    before opening. Or 40 amps for 9 seconds. And this assumes
    ambient temperature is constant. The fuse must be sized to
    not blow also at over 100 degrees F. However the same fuse
    will now require 10% or more current to blow in winter
    temperatures. Then there are waveforms for that overcurrent.
    Then the manufacturer recommends adding another 20% margin of
    safety.
    We have assumed an ideal overcurrent - a square wave. That
    100 amps might take twice as long to trip a 20 amp fuse if
    current only averages 100 amps but really peaked at 200+ amps.
    Variations mean that sizing a fuse for hardware protection
    becomes difficult if not impossible.
    This 20 amp fuse would be selected typically for loads that
    may peak around 10 amps or less just to avoid nuisance
    tripping. And yet a 100 amps short circuit is required could
    make the fuse open in less than one second. IOW the fuse of
    for protection after damage has occurred.
    For UL approval, a fuse must open at 135% of rated power
    within one hour. It must open within 2 minutes is the
    overcurrent is 200%. That means to protect a 1 amp load, the
    two amp fuse (the smallest selected so as to avoid most
    nuisance tripping) would conduct 4 amps through the protected
    appliance for minutes. Or 10 amps for 0.1 seconds. Ten times
    more current through a 1 amp item - where is the hardware
    protection? Does not exist.
    Fuses were not for hardware protection. Fuses are installed
    first and foremost for human safety. These are numbers.
    Others are invited to demonstrate knowledge of numbers rather
    than post "horseshit", "lamer", and other technical facts.
    Fuses are excellent at stopping wire fires. The standard 20
    amp electric wire should handle hundreds of amps without
    damage (and fire). Long enough for a fuse to eventually open.
    But fuses are woefully insufficient at avoiding appliance
    damage. That I^2t curve, well understood by those with basic
    electrical background, demonstrates the problem. Time even
    tens of milliseconds for faster fuses is woefully too long to
    protect electronics - such as a power supply.
    Fuses don't even claim to protect appliances. Fuses are
    installed to blow after a failure has happened. After current
    well exceeds what is normal rated consumption. The fuse
    provides human protection after damage has occurred. Above
    numbers demonstrate that fact. Numbers rather than insults
    demonstrate that fuses do not protect hardware. Fuses blow
    after damage has occurred; for human safety.
    > I want the fuse to blow before damage to the hardware occurs. If
    > the fuse is sized for the hardware's optimal current draw, that
    > is what will happen. Then the hardware can be electrically
    > repaired, the fuse replaced and the machine is again happy.
    > By the way, I have repaired thousands of machines over the years
    > that have blown fuses. With few exceptions they were all
    > repairable and never again blew another fuse. And I am happy to
    > say that no one died in the process. I guess the fuse saved their
    > lives!
    > That is great, but I still fuse to protect the equipment.
  47. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Woww. Such hate. Such acidity even to a little humor. Are
    you sure your name is not Leythos? Lighten up, son.
    > ago while you were learning and severely cause injury, or worse, to
    > someone! That would explain it.
    >> protection devices.
  48. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Hi all,
    FYI the machine has been accepted back by the business who built it to
    be repaired under warranty.
    I have passed on the relevant suggestions posted on this thread and
    hope they pull it down and check it according to your suggestions.
    Thanks again and I will be sure to post the outcome. However it may be
    a couple of weeks?
    Rob
  49. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    In article <m48181l9jhjotoi31gcn1o8gnvfbh87j3l@4ax.com>, none@none.com
    says...
    > Hi all,
    > a couple of weeks?
    > Rob
    Just make sure that you install a quick-acting fuse in the shower matt
    so that you are fully protected from slipping in the shower :)
Power Supplies Windows XP
