Tom's Hardware Forums » Motherboards & Memory » Soyo » HELP please attaching case USB2 and firewire to motherboard
Add a reply
 Word :   Username :
Bottom
Author
 Thread : HELP please attaching case USB2 and firewire to motherboard
Profile: stranger
More Information
Archived from groups: alt.comp.periphs.mainboard.soyo (More info?)
I got some great help for my last questions to these newsgroups, so
I'd like to press my luck and try again:
I am installing a Soyo Dragon 6000 Ultra Platinum motherboard in a
Coolermaster Wave Master case. I don't understand the schematic for
plugging in the chassis firewire, USB2 and audio wires.
1. USB2: The motherboard has two separate places to plug in USB2
wires. Each of the two places has two rows of prongs; one row has four
prongs while the second row has five prongs. However, the case wires
that I think are the USB2 wires have only one row of holes each. (The
five-hole USB2 case wire has red, black, blue, and white wiring, while
the four-hole USB2 case wire has orange, red, brown, and black wiring.
My question is: DO BOTH CASE WIRES GO INTO A SINGLE MOTHERBOARD USB2
PLACE, WITH THE FIVE-HOLE WIRE GOING INTO THE FIVE-PRONG ROW, AND THE
FOUR-HOLE WIRE GOING INTO THE FOUR-HOLE ROW?
2. Firewire: The thick black case wire that I take to be the firewire
case wire has two rows of holes: five holes in one row and four holes
in the other. The row with four holes covers over the LAST HOLE at the
end of the row. The problem here is that the motherboard firewire
place, which has five prongs in one row and four prongs in the second,
deletes one of the MIDDLE PRONGS in the four-prong row, not the LAST
PRONG.
3. On the thick black case wire--on the end that is closest to the
firewire and USB2 ports--there is a loose wire that looks like a
grounding wire. Is that supposed to be attached to anything?
Thank you
Related Pr oduct
Add a reply
Google Ads
