Archived from groups: microsoft.public.windowsxp.hardware (
More info?)
The RealTek Audio AC97 indicates you have "onboard" sound on the
motherboard - just a microchip on the m/board that processes sound, rather
than a dedicated sound card you plug into a PCI slot.
"jenny" <jenny@discussions.microsoft.com> wrote in message
news:A76BBC1E-21CB-490D-893C-6222CB78D60C@microsoft.com...
>I dont know if its becuse your explaining a different version of windows (I
> have xp), but the control panel isnt set up like that. HOwever, I've been
> through all the microphone parts and have made sure they're not muted and
> the volume is up. Also my default recording device is Realtek AC97 Audio,
> if
> thatm helps? And under sounds and Audio Device properties, it wont let me
> choose advanced settings. Anymore ideas?
> "Star Fleet Admiral Q" wrote:
>> If you got sound coming out, you have a sound card, and most if not all
>> sound cards are capable of sound in (line in, MIC or both), but it may be
>> muted via the software.
>> In control panel, Click on Sounds and Audio Devices, Advanced, Options,
>> Properties, and scroll down and put a check mark next to "microphone",
>> click
>> OK - the Play Control windows underneath should now have a "Microphone
>> Panel", afterwards make sure the Mute box is not checked, then adjust
>> sound
>> to desired level.
>> Star Fleet Admiral Q @ your Service!
http://www.google.com
>> Google is your "Friend"
>> news:F3086EBF-4FCC-47E2-8777-90FA5D6A5A52@microsoft.com...
>> > HOw do i find out if my computer contains a sound card. I seem to have
>> > problems recording, even though i have a microphone. I've tried
>> > plugging
>> > it
>> > into the line in on my screen and mic socket on the system unit, and
>> > there's
>> > nothing being picked up.
