G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.soyo (More info?)
On my K7VME, with a fresh install of Windows XP Pro., the machine will
not always load windows. After POST, it appears with the XP splash
screen and then a moment later reboots. This happens on either a
shutdown or a restart. Eventually, sometimes only a single reboot
others a lot of reboots, Windows will load. The temperature of the AMD
2500XP Barton, idles about about 46-50-54(under load).
On Soyo's site, I could only find that a HD transfer or software
conflicts could cause a reboot. I have updated with all the latest and
greatest drivers. And it is a fresh install on this mobo.
I have not flashed the bios as I could not see where it would fix this
issue.
Any ideas? Thank you.
issue.
