ASUS TV-FM CARD 7135 Won't work on an AMD Sempron System
Motherboards
- Windows XP
Last response: in Windows XP
Leo
May 21, 2005 10:53:15 PM
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
It's a brand new card on a relatively new system. When I insert it the
system hangs without even beeping. I tried moving the card to a different
slot on the motherboard -- same thing happens.I tried the card on another
system and it works fine.
Could this card be incompatible to this particular motherboard? It's a
Biostar M7VIG400 KM266 SKTA from a Tagar system with an AMD Sempron 2400+
CPU and 512MB RAM
Thanks for any help..
CPU and 512MB RAM
More about : asus card 7135 work amd sempron system
peter
May 22, 2005 4:22:02 AM
Hi,
Update the mobo BIOS and chipset drivers may help.
Peter
> CPU and 512MB RAM
Hi,
Peter
> CPU and 512MB RAM
Leo
May 23, 2005 4:40:37 AM
I couldn't find a newer BIOS version so I tried installing a slightly older
version. It's still doing the same thing. I guess I should find another
card. I'm a little pissed off that a system that 5 years old has no
problems, but a much newer sytem boot up nor won't even give a diagnostic
beep. Oh well.
"Peter" <Peter@discussions.microsoft.com> wrote in message
news:5332469E-D035-4834-863C-20721A0A01F2@microsoft.com...
> Hi,
> Peter
>> CPU and 512MB RAM
beep. Oh well.
> Hi,
> Peter
>> CPU and 512MB RAM
- Is there any reason an AMD sempron processor won't work with windows 8.1? - Forum
- Will Asus HD 7770 2GB AMD Radeon Graphics Card work in my system? - Forum
- Can a dell and a ASUS video card work together in the same system? - Forum
- Will Intel mini-PCIe wireless cards work in my AMD system? - Forum
- Asus GTX 750ti card wont work - Forum
peter
May 23, 2005 4:40:38 AM
Leo,
http://www.biostar.com.tw/support/bios/bios.php3?model=...(7.x)
latest BIOS Version Vig0916bs4.exe dated 2004/10/05
VIA chipset drivers:
http://www.biostar.com.tw/support/driver/chipset.php3?i...
or try the older version 4.43 from viaarena.com:
http://www.viaarena.com/default.aspx?PageID=2
Note: disable any antivirus softwares before flashing the BIOS and install
the chipset drivers.
Proper procedures to update BIOS and chipset drivers:
1. Boot into BIOS and then disable any virus protection in BIOS, if any;
save and exit BIOS setup.
2. Strictly follow the mobo user manual to update the BIOS.
After BIOS is successfully flashed, load the opyimized setup default.
Make any configuration in BIOS to suit your requirement and then save
3. After windows loaded, close any application and make sure the antivirus
softwares is not running at the background.
Install the VIA 4in1 drivers Version 4.43 downloaded from viaarena.com.
Follow the prompts and restart at the end of the installation.
Pls post back to NG for the outcome
Peter
> beep. Oh well.
> > Hi,
> > Peter
> >> CPU and 512MB RAM
Leo,
Peter
> beep. Oh well.
> > Hi,
> > Peter
> >> CPU and 512MB RAM
Leo
May 30, 2005 9:20:18 PM
I've updated both the BIOS & chipset with the latest to no avail. I've also
sent email to a Biostar rep (carol@biostar.com.tw) four days ago, but I not
receive a reply yet.
I'm thinking of getting the ASUS tv tuner listed below instead.
VC-CP-THEATER550 CP THEATER 550/ATI REAL-TIME
HARDWARE MPEG2 ENCODING
news:B019CE05-F964-4DD3-86F3-94C949042055@microsoft.com...
> Leo,
> Peter
>> older
>> beep. Oh well.
>> > Hi,
>> > Peter
>> >> different
>> >> another
>> >> 2400+
>> >> CPU and 512MB RAM
> Leo,
> Peter
>> older
>> beep. Oh well.
>> > Hi,
>> > Peter
>> >> different
>> >> another
>> >> 2400+
>> >> CPU and 512MB RAM
peter
May 31, 2005 12:36:01 AM
leo,
Are there any other PCI cards other than the Asus tv card?
How do you configure the BIOS settings for PCI device?
Does the BIOS recongnize the Asus tv card in BIOS?
Peter
> > Leo,
> > Peter
> >> older
> >> beep. Oh well.
> >> > Hi,
> >> > Peter
> >> >> different
> >> >> another
> >> >> 2400+
> >> >> CPU and 512MB RAM
leo,
Peter
> > Leo,
> > Peter
> >> older
> >> beep. Oh well.
> >> > Hi,
> >> > Peter
> >> >> different
> >> >> another
> >> >> 2400+
> >> >> CPU and 512MB RAM
Leo
May 31, 2005 5:54:44 PM
BIOS PCI settings weren't changed because I didn't notice any setting that
needed to be changed. I did stick a firewire card before and it was
recognize by the system. But with this card nothing happens other than the
fans making noise. There are no beeps, no messages on the monitor, NOTHING
else! It seems like something is preventing either the motherboard or the
CPU from posting.
news:44631CE7-549A-4728-A3B4-35FA0961525D@microsoft.com...
> leo,
> Peter
>> also
>> not
>> > Leo,
>> > install
>> > any;
>> > default.
>> > save
>> > antivirus
>> > viaarena.com.
>> > Peter
>> >> older
>> >> another
>> >> diagnostic
>> >> beep. Oh well.
>> >> > Hi,
>> >> > Peter
>> >> >> the
>> >> >> different
>> >> >> another
>> >> >> It's a
>> >> >> 2400+
>> >> >> CPU and 512MB RAM
CPU from posting.
> leo,
> Peter
>> also
>> not
>> > Leo,
>> > install
>> > any;
>> > default.
>> > save
>> > antivirus
>> > viaarena.com.
>> > Peter
>> >> older
>> >> another
>> >> diagnostic
>> >> beep. Oh well.
>> >> > Hi,
>> >> > Peter
>> >> >> the
>> >> >> different
>> >> >> another
>> >> >> It's a
>> >> >> 2400+
>> >> >> CPU and 512MB RAM
peter
May 31, 2005 8:11:47 PM
Hi,
It may be conflict with the on-board vedio chips of your mobo.
You said it worked with other PC. Does the PC using on-board vedio chips or
using a AGP display card?
Pls post back to NG.
Peter
> CPU from posting.
> > leo,
> > Peter
> >> also
> >> not
> >> > Leo,
> >> > install
> >> > any;
> >> > default.
> >> > save
> >> > antivirus
> >> > viaarena.com.
> >> > Peter
> >> >> older
> >> >> another
> >> >> diagnostic
> >> >> beep. Oh well.
> >> >> > Hi,
> >> >> > Peter
> >> >> >> the
> >> >> >> different
> >> >> >> another
> >> >> >> It's a
> >> >> >> 2400+
> >> >> >> CPU and 512MB RAM
Hi,
Peter
> CPU from posting.
> > leo,
> > Peter
> >> also
> >> not
> >> > Leo,
> >> > install
> >> > any;
> >> > default.
> >> > save
> >> > antivirus
> >> > viaarena.com.
> >> > Peter
> >> >> older
> >> >> another
> >> >> diagnostic
> >> >> beep. Oh well.
> >> >> > Hi,
> >> >> > Peter
> >> >> >> the
> >> >> >> different
> >> >> >> another
> >> >> >> It's a
> >> >> >> 2400+
> >> >> >> CPU and 512MB RAM
Leo
June 1, 2005 3:44:16 AM
Hi,
The card worked perfectly on a A7V400-MX motherboard with on board video.
And it also was recognized on and older socket A KSEM mboard with a 900MHz
CPU. However, on that system I didn't bother installing the drivers for the
card.
I am going try my luck with an MSI card this Saturday. I'll post here what
happens.
news:20E281F6-7147-4716-A77A-3E0AF86D2A0E@microsoft.com...
> Hi,
> or
> Peter
>> that
>> the
>> NOTHING
>> CPU from posting.
>> > leo,
>> > Peter
>> >> also
>> >> I
>> >> not
>> >> > Leo,
>> >> > install
>> >> > any;
>> >> > default.
>> >> > save
>> >> > antivirus
>> >> > viaarena.com.
>> >> > Peter
>> >> >> slightly
>> >> >> older
>> >> >> another
>> >> >> diagnostic
>> >> >> beep. Oh well.
>> >> >> > Hi,
>> >> >> > Peter
>> >> >> >> it
>> >> >> >> the
>> >> >> >> different
>> >> >> >> on
>> >> >> >> another
>> >> >> >> It's a
>> >> >> >> Sempron
>> >> >> >> 2400+
>> >> >> >> CPU and 512MB RAM
Hi,
card.
happens.
> Hi,
> or
> Peter
>> that
>> the
>> NOTHING
>> CPU from posting.
>> > leo,
>> > Peter
>> >> also
>> >> I
>> >> not
>> >> > Leo,
>> >> > install
>> >> > any;
>> >> > default.
>> >> > save
>> >> > antivirus
>> >> > viaarena.com.
>> >> > Peter
>> >> >> slightly
>> >> >> older
>> >> >> another
>> >> >> diagnostic
>> >> >> beep. Oh well.
>> >> >> > Hi,
>> >> >> > Peter
>> >> >> >> it
>> >> >> >> the
>> >> >> >> different
>> >> >> >> on
>> >> >> >> another
>> >> >> >> It's a
>> >> >> >> Sempron
>> >> >> >> 2400+
>> >> >> >> CPU and 512MB RAM
- Asus P8Z68-V PRO wont detect GFX card after 2.5years, other cards work, and this card works in other pcs. help? :[ Forum
- asus motherboard not detecting graphics card or graphics card wont work Forum
- Hello, I have a new Asus GTX 760 DC-II, this graphic card don't work in Intel, but It is working in AMD. Forum
- my asus notebook has missing operating system and won't work Forum
- AMD Mobile Athlon 64 4000+ in ASUS K8N-E mb wont work. HELP! Forum
- Custom PC Build System Check, AMD FX-8350, Asus M5A97, Kingston *GB DDR3, CoolMax 600W ATX PSU, Radeon R7 240 2GB Video Card Forum
- ASUS AMD HD 7750 - will this work with my system? Forum
- Any reason the ASUS Silent Knight won't work on an AMD3 quad core cpu? Forum
- ASUS M5A78L LE with 3x AMD 7950 cards and a oczgxs850 with only 2 PCIE power providers, would it work? Forum
- Does Asus AMD/ATI Radeon HD 5450 1 GB DDR3 Graphics Card work on 450w psu Forum
- ASUS P5E3 Deluxe Motherboard - Quadro FX card won't work in 1st slot. Forum
- SolvedDo NVIDIA cards work OK with AMD [chipset] systems? Forum
- Video card won't work on this system?! Forum
- More resources
Read discussions in other Windows XP categories
