Wireless Connection
Forum Wireless Networking : Wireless General Discussions - Wireless Connection
Archived from groups: microsoft.public.windows.networking.wireless (More info?)
Hello, I have a 2 Pcs' wireless internetion connection, one connected
directly to the router and the other concnected wirelessly. There is no
internet connection problem for both Pcs. But when I play online game, the
wireless one cannot be recognised by other online player (seems to be
incorrect IP posted). If I use this Pc to invite others to join an online
game, they will mistake this Pc to be the PC connected by cable and join to
it. There is no such problem for the one connected by cable.
Please help, thanks.
Sponsored Links
"SK" <SK@discussions.microsoft.com> wrote in message
news:8D3EF182-ADF6-426B-BE5B-539D81275DAA@microsoft.com...
> to
Looks like, as you're currently configured, your router is in NAT mode using
the MAC address of your cable connected machine and is assigning internal
IP's. The cable connected machine would work fine, the other, no go since
your system only has one actual IP address for the rest of the world to see
regardless of how many machines are sharing the line via your router.
I believe in order to correctly connect and play online games from both of
your router connected machines you will need to disable NAT in the router
(It will then act as a hub) and get two seperate static IP addresses
assigned to you by your ISP. Set up each machine as instructed by the ISP
and you'll be good to go. They'll still both be sharing the same bandwidth
so your mileage may vary as far as performance in the actual games goes.
Then again I could be all wrong and something may be possible as a work
around. I'm confident someone will chime in if this is true or to clarify
any errors in what I've attempted to say.
joe
Reply to Anonymous
Tom's Hardware > Forum > Wireless Networking > Wireless General Discussions > Wireless Connection
There are 1163 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
