A problem I can't solve: USB
Anonymous
a b V Motherboard
April 28, 2005 11:58:39 PM
Archived from groups: alt.comp.periphs.mainboard.soyo (More info?)
Error from XP: High speed USB device plugged into non-high speed USB port
Soyo KT-400 Dragon Ultra Black edition.
Any ideas?
More about : problem solve usb
Anonymous
a b V Motherboard
April 28, 2005 11:58:40 PM
port
> Any ideas?
If you are using the 2 rear mounted ports, they are only USB 1.1
The 2 lime green pin headers located next to the last PCI slot
are the USB 2.0 ports.
Andy
Anonymous
a b V Motherboard
May 2, 2005 9:09:54 PM
All the USB ports on this board support USB 2 as long as your operating
system supports or has been updated to support USB 2. In reality the 2
lime green pin headers will only support USB 2 if you use a USB 2
compatible cable and port setup.
