Archived from groups: microsoft.public.windowsxp.hardware (More info?)
Hi,
I'm an unhappy owner of a Maxtor 160Gb hard drive (6L160P0). I'm
unhappy because I'm not able to make it use the UltraDMA mode, but only
the slow PIO4 mode. I have WinXP Pro sp2.
My motherboard is an Asus A7A266 with Alimagik1 chipset (North bridge
Ali M1647, South bridge Ali M1535D+) with the latest BIOS (1013 beta).
I also have a Samsung 40Gb hard disk that works perfectly in UDMA5.
I tried uninstalling and reinstalling IDE channels from device manager,
but I still have PIO4.
I checked BIOS, setting either "Auto" or "Manual" in HD configuration
(manual udma6, udma5 etc...). No way.
I downloaded Ali/Uli integrated drivers v2.096, then I enabled mini-IDE
driver (v1.5.10) modifying the "install.ini" file and installed it. No
success, hd still uses PIO.
Now in device manager under the IDE ATA/ATAPI controllers I have "Ali
M5229 PCI Bus Master IDE Controller".
I tried forcing UDMA changing "MasterDeviceTimingModeAllowed" and
"MasterDeviceTimingMode" keys in registry (ffffffff and 10010), nothing
to do.
I tried downloading and installing the old Ali UltraIDE driver
v4.0.0.8, which simulates SCSI drives using IDE units. IT WORKS! But:
standby/hibernate function doesn't work anymore and my DVD unit cannot
read disks (it returns I/O errors). Plus I read from other people that
there are many problems with CD/DVD recording.
Hardware is OK, cables are 80 pin, all settings are perfect.
I think I'm not the only one who has these problems, I'd like to know
if there is a solution to this. Will Ali distribute new drivers to
solve this problem? And when? I purchased this Maxtor HD to work with
video, but in PIO mode there's no way to do it. It's almost useless!!!
Thanks all.
Hi,
to do.
Thanks all.
