Archived from groups: alt.comp.periphs.mainboard.supermicro (More info?)
I tried to upgrade a system (which I built 3 years ago) from a single 2.4GHz Xeon processor (533FSB) to dual 3.06GHz Xeon processors (also 533FSB) on the Supermicro X5DEI-GG motherboard. The processors are identical stepping codes. Both have 1MB L2 cache.
After installing both processors, the system refused to POST. No beeps, no video, just dead.
I removed the 2nd processor and the system booted fine. It recognized the processor at the 3.06GHz speed.
I swapped the processors and the 2nd processor worked fine when installed as the only processor in the system.
I do not believe that the processors are bad, since they each work properly when installed as a single processor in the system.
No matter what I did, the system would still not POST with both processors installed in any arrangement.
The BIOS displays that it is version "7.00.xx" on POST. The system has a beefy Antec Truepower 550 watt power supply with all of the proper connectors. The system has been running successfully for several years.
Does anyone have any suggestions as to how I can get both processors running in this system?
Hi, I am having a similar problem, I bought a 7043-8M Super server and installed two 2.8 GHz Xeon, and when I power it up, it shows no video only a beep code, I checked the beep code and it says "Memory not found" I had installed a 1 GB Kingston module (a tested one). I have not try to power it up with only one processor though, but I think its something else because both processors are fine.
