Archived from groups: microsoft.public.windowsxp.hardware (More info?)
Hi,
I'm using a cable modem on a Win XP machine to connect to the internet. I
would like to set up a Win 98SE machine in another room using some kind of
wireless connection thru my cable modem. Can this be done? If so, what do I
need?
Thanks,
jll
Sponsored Links
You need a wireless router and a wireless PCI card
here are 2 examples but there are many more on the market
http://www.netgear.co.nz/products/ [...] prodID=214
http://www.netgear.co.nz/products/ [...] prodID=236
peterk
It's so much easier to suggest solutions when you don't know too much about
the problem
"jll" <jll@nobodyhome.com> wrote in message
news:BLqpe.33904$nG6.30047@attbi_s22...
> Hi,
> I need?
> Thanks,
> jll
Reply to Anonymous
- 0 +
Like Peterk said you need a wireless router and wireless pci card to install
in the PC. If your in the states Best Buy's Sunday ad listed a Belkin
wireless router for $9.99 after rebates, same one I bought in March from
CompUSA to use with my Compaq notebook. It worked like a charm. I would
suggest getting a matching wireless card, by that I mean from the same
manufacturer although they are supposed to all work together. My Compaq
notebook works at my home with my Belkin and at my neighbors, he has a Dlink
wireless router.
Hi,
need?
Thanks,
jll
Reply to Jimbo
Thanks for the quick response. The router would connect to the cable modem
and the wireless pci card would be installed in the machine in the other
room, right? Do they make a router that could be wired to my PC and still be
wireless for the other?
Thanks,
"Jimbo" <spamnot@spamnot.com> wrote in message
news:%itpe.108533$IO.34738@tornado.tampabay.rr.com...
> install
> Dlink
> wireless router.
> Hi,
> I
> need?
> Thanks,
> jll
Reply to Anonymous
- 0 +
Almost all wireless routers come with 4 external ports that you would
connect an Ethernet cable to. The Belkin I mentioned does.
news:OyLpe.28211$x96.8125@attbi_s72...
Thanks,
> install
> Dlink
> wireless router.
> Hi,
> I
> need?
> Thanks,
> jll
Reply to Jimbo
Great! I'm learning. Thanks again,
news:H44qe.76208$VH2.15575@tornado.tampabay.rr.com...
> be
> Thanks,
>> install
>> would
>> Dlink
>> wireless router.
>> Hi,
>> of
>> I
>> need?
>> Thanks,
>> jll
Reply to Anonymous
The Netgear website has detailed drawings on just such a setup.
I use a Netgear connected by wire to one computer,connected by wire to
another computer and wirelessly with my laptop.
Any computer on the system can access any other computer on the system as
well as connect independantly to the net.
This website has instructions for setting up a home network....either wired
or wireless or both
http://www.homenethelp.com/
I found the Netgear WGT624 router to be really easy to set up and with the
WG511T PC card I connect at 108Mbps.
The manual explained the security settings quite well.
good luck
peterk
the problem
news:2w4qe.42020$nG6.21228@attbi_s22...
>> modem
>> be
>> Thanks,
>>> install
>>> would
>>> Dlink
>>> wireless router.
>>> Hi,
>>> I
>>> of
>>> do
>>> I
>>> need?
>>> Thanks,
>>> jll
Reply to Anonymous
Thanks for pointing me in the right direction. Lots of useful information.
"peterk" <peterk@nomalarky.net> wrote in message
news:Ovvz8GVbFHA.348@TK2MSFTNGP14.phx.gbl...
> wired or wireless or both
> good luck
> peterk
> about the problem
>>> modem
>>> still be
>>> Thanks,
>>>> install
>>>> from
>>>> would
>>>> Compaq
>>>> Dlink
>>>> wireless router.
>>>> Hi,
>>>> I
>>>> of
>>>> do
>>>> I
>>>> need?
>>>> Thanks,
>>>> jll
Reply to Anonymous
Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Wireless connection?
There are 1210 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
